Northgate Monitor - Model No. KM-718
My Monitor Flickers all the time, it hurts my eyes and gives me headacks, is there something I can do to stop it from doing this?
  • Caboose0013 Dec 16, 2007
    My monitor flickers on and off while i am using it. I have tried changing the refresh rate but it didn't work. I was wondering if LCD monitors have bulbs like tvs and if that could be the problem.
    I have an Envision EN-7100e LCD monitor
On Earth Day Google 'turned off their lights' and made their home page black with colored logo and white lettering. Since then, all my pictures have a green tinge. I've tried auto adjusting and using the menu on the screen itself to fix the problem to no avail. Can anyone help with this?
Posted on May 08, 2008
    Brigadier General:
  • 6,966 Answers
Hi, Assuming that the monitor does not have any problem or defective components/settings, you can try adjusting your PC by: 1. Right click on any clear are of your desktop; 2. Click on properties; 3. Go to Settings tab; 4. Set your Screen Resolution to your desired size; 5. Verify that you have Highest (32bit) setting in your Color Quality; 6. Click on Advanced button; 7. Click on Monitor tab; 8. Select highest Screen refresh rate (maybe 85 Hertz) within capacity of your video card & monitor; 9. if a selection or setting does not work, pressing escape will revert you back to the previous setting; 10. Apply, OK. Hope this be of some help/idea. post back how things turned up or should you need further information. Good luck and kind regards.
Posted on Oct 01, 2007
I changed the battery in my 1998 F150 it was running fine now it doesn't run good it acts like it doesn't want to shift and it bogs down there's no codes in the light's not on?
You can try a drive cycle, see if it helps? There may be an idle relearn, if just idle issue? Usually it will relearn idle on its own by driving.
Drive Cycle Recommendations:
  1. Most OBDII monitors will complete more readily using a "steady foot" driving style during cruise or acceleration modes. Operating the throttle in a "smooth" fashion will minimize the time required for monitor completion.
  2. Fuel tank level should be between 1/2 and 3/4 fill with 3/4 fill being the most desirable.
  3. The Evaporative Monitor can only operate during the first 30 minutes of engine operation. When executing the procedure for this monitor, stay in part throttle mode and drive in a smooth fashion to minimize "fuel slosh".
WARNING
STRICT OBSERVANCE OF POSTED SPEED LIMITS AND ATTENTION TO DRIVING CONDITIONS ARE MANDATORY WHEN PROCEEDING THROUGH THE FOLLOWING DRIVE CYCLES.
For best results, follow each of the following steps as accurately as possible:
OBDII Monitor
Exercised
Drive Cycle Procedure
Purpose of
Drive Cycle
Preparation 1. Install scan tool. Turn key on with the engine off. Cycle key off, then on. Select appropriate Vehicle & Engine qualifier. Clear all DTC's/ Perform a PCM Reset. Bypasses engine soak timer. Resets OBDII Monitor status. 2. Begin to monitor the following PIDs: ECT, EVAPDC, FLI (if available) and TP MODE.
Start vehicle WITHOUT returning to Key Off. 3. Idle vehicle for 15 seconds. Drive at 64 Km/h (40 MPH) until ECT is at least 76.7°C (170° F). Prep for Monitor Entry 4. Is IAT within 4.4 to 37.8°C (40 to 100° F)? If Not, complete the following steps but, note that step 14 will be required to "bypass " the Evap monitor and clear the P1000. Engine warm-up and provide IAT input to the PCM. HEGO 5. Cruise at 64 Km/h (40 MPH) for up to 4 minutes. Executes the HEGO monitor. EVAP 6. Cruise at 72 to 104 Km/h (45 to 65 MPH) for 10 minutes (avoid sharp turns and hills) Note, to initiate the monitor: TP MODE should =PT, EVAPDC must be >75%, and FLI must be between 15 and 85% Executes the EVAP Monitor (If IAT is within 4.4 to 37.8° (40 to 100°F)) Catalyst 7. Drive in stop and go traffic conditions. Include five different constant cruise speeds, ranging from 40 to 72 Km/h (25 to 45 MPH) over a 10 minute period. Executes the Catalyst Monitor. EGR 8. From a stop, accelerate to 72 Km/h (45 MPH) at 1/2 to 3/4 throttle. Repeat 3 times. Executes the EGR Monitor. SEC AIR/CCM (Engine) 9. Bring the vehicle to a stop. Idle with transmission in drive (neutral for M/T) for 2 minutes. Executes the ISC portion of the CCM. CCM (Trans) 10. For M/T, accelerate from 0 to 80 Km/h (o to 50 MPH), continue to step 11. For A/T, from a stop and in overdrive, moderately accelerate to 80 Km/h (50 MPH) and cruise for at least 15 seconds. Stop vehicle and repeat without overdrive to 64 Km/h (40 MPH) cruising for at least 30 seconds. While at 64 Km/h (40 MPH) , activate overdrive and accelerate to 80 Km/h (50 MPH) and cruise for at least 15 seconds. Stop for at least 20 seconds and repeat step 10 five times. Executes the transmission portion of the CCM. Misfire & Fuel Monitors 11. From a stop, accelerate to 104 Km/h (65 MPH). Decelerate at closed throttle until 64 Km/h (40 MPH) (no brakes). Repeat this 3 times. Allows learning for the misfire monitor. Readiness Check 12. Access the ON-Board System Readiness (OBDII monitor status) function on the scan tool. Determine whether all non-continuous monitors have completed. If not, go to step 13. Determines if any monitor has not completed. Pending Code Check and Evap Monitor "Bypass" Check 13. With the scan tool, check for pending codes. Conduct normal repair procedures for any pending code concern. Otherwise, rerun any incomplete monitor.
Note: if the EVAP monitor is not complete AND IAT was out of the 4.4 to 37.8° C (40 to 100° F) temperature range in step #4, or the altitude is over 2438 m. (8000 ft.), the Evap "bypass" procedure must be followed.Proceed to step 14. Determines if a pending code is preventing the clearing of P1000. Evap Monitor "Bypass" 14. Park vehicle for a minimum of 8 hours. Repeat steps 2 through 12. DO NOT REPEAT STEP 1. Allow the "bypass" counter to increment to two.
© Ford Motor Company
Jun 18, 2017 | Ford F-150 Cars & Trucks
My Samsung LED SyncMaster BX1931 hurting my eyes
Well, there are so much good monitors out there.in market.. You can find them easily by searching on internet. So you can try any new monitor to get rest to your eyes..
I am not telling that Samsung is not good, but if you have old model monitor..
Feb 03, 2013 | Samsung SyncMaster Computers & Internet
Dell desktop monitor screen flickers.
The monitor is about to go bad. Replace it. Borrow a monitor from a family member, neighbor or friend just to see if the flickering stops. If it does stop your monitor is bad. If the borrowed monitor flickers, you will need to replace your Video Card in the computer.
May 01, 2012 | Dell Computers & Internet
The monitor flickers
Right click on "Desktop" screen, select "Personalize", click to open "Display Settings", ("highlight") and make all necessary changes to stop the flickering , and improve the visual.
Jan 20, 2010 | Toshiba Satellite Pro L300 Notebook
Menu button doesnt give the menu, also continuous auto adjusting at random times! The adjusting stops when i turn the monitor off and back on. All help will be much appreciated!! >_< Its annoying and...
The constant auto-adjust pop-up is a indication that the power supply is about to die. As the voltage varies the monitor control board momentarily resets and you get the adjust screen. We have a step by step repair guide posted on our web site at: www.ccl-la.com Check he sticker on the back of your monitor for the last letter to determine the version of the E173 that you have. The letters will be either c,f or b.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 29, 2009 | Dell E173FP 17" LCD Monitor
No sound from northgate ez18a monitor
Have you connected a cable (3.5mm plugs at each end) between the mintor and the sound port on the P.C.?
Oct 24, 2009 | Northgate EZ18A 18" Silver 1280X1024 LCD...
Glare is too much for my eyes, need a glare guard.
You can purchase a glare guard from 3m, available from cdw, tigerdirect, dell, 3m etc.
The price ranges from around $53 to $90 but you might find cheaper.
This is one model but there are several
3M™ EF200LB Anti-Glare/Radiation Computer Filter, Black Frame
May 18, 2009 | Gateway FPD1975W 19" LCD Monitor
Monitor flickers with changing colors making it almost impossible to see anything, it started & stopped for a while then after maybe three weeks after it started again ! I tried disconnecting & changing...
I suggest upgrading the OS on these problem terminals to the latest on the wyse website. It might be an incompatibility with the monitor and terminal (might have been fixed in later builds), in which case you will need to log it with Wyse directly, as they will need to test this.
Chances are though you either have a faulty monitor cable, a faulty unit, or faulty monitor. Perhaps even a combination of more than one of these above problems. Try to rule out each bit of hardware before blaming anything in particular.
Try a few different monitor resolutions, colour depth and refresh rates too. Cant hurt :)
Mar 31, 2009 | WYSE Winterm S30 Network Terminal
Eye strain (using LCD monitor)
====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 16, 2007 | Computers & Internet
Computers & Internet Logo
943 people viewed this question
Alun Cox
David Payne
David Payne
