TRY THIS SITE ON YOUTUBE.
TYPE IN "removing 1999 Chevy 3.8 water pump at you tube"
step by step video. better than a detailed report.
good luck not a hard job if you can wrench.
Cowcamp
SOURCE: looking for the fuel pump
1994 Chevy Camaro 3.4L V6
Fuel Pump Relay Location
Behind LH Dash Mat
The fuel pump relay is attached foot rest bracket under carpet, forward of left kick panel
Hey My Fellow Member of the Auto DIY World & World I Hope this Brings smiles and A solution to your Problem as it is My Goal and Mission to Help you .. EASY now rejakwilson
SOURCE: Need to know how to install a water pump on a 97 chevy lumina
Hi
1 drain the coolant
2 there will be a pulley with 4 10mm bolts loosen them
3 remove the belt
4 now remove the 4 10mm bolts and remove the pulley
5 that's the water pump there are 5 bolts to remove (8mm)
6 after removing the bolts tap the pulley flange to remove the pump
7 clean the old gasket off the front cover
8 install the new pump and gasket and reassemble
SOURCE: Replacement of Water Pump. 2001 Chevy Cavalier 2.4 L
Stick with me on this
1.Put the car on jack stands
2.Remove the exhuast manifold, Do not rotate the flex cuopling more then 4 degrees od damage will occur.
3.Diconnect the coolant inlet pipe from the water pump outlet hose, Disconnect from the engine, disconnect it from the thermostate housing and remove it.
4.lower the car back down of the jack stands.
5.Detach the brack booster hose.
6.Remove the timing chain cover and the tensioner.
7.Remove the heater outletpiper from the water pump.
8.Remove the water pump cover bolts.
9.Remove the water pump retianer nuts.
Remove the old gasket and clean.
10.On bench. Install the waterpump and cover but lreave the bolts finger tight.
11.Install back in car, leave water pump bolts looseto allow for positioning.
12.Install water pump cover to engine, tighten by hand.
13.Lubricate oringand install metal outlet pipe back into pump, hand tighten.
14a.Tighten the water pump to timing chain nuts
14b.Tighten the water pump cover to water pump housing bolts.
14c.Tighten water pump cover to engine block bolts.
14d.Tighten the radiator outlet pipe to water pump.
15.Install timing chain tensioner.
16.Install exhuast manifold.
17.Install exhuast pipe.
18. Fill it up and bleed the system.
Good luck
SOURCE: need to replace water pump on a1997 chevy lumina
3.1L And 3.4L (VIN E) Engines
To install:
Exploded view of the water pump and front cover arrangement—3.1L and 3.4L (VIN E) engines
SOURCE: How do I change the water pump on a 1999 Chevy
Remove the drive belt.
Remove the plastic cover that is over the pump.
Remove water pump pulley and housing bolts.
Reverse order to assemble.
