Question about Gateway ONE GZ7108 All-in-One Desktop PC
Hard drive problem
I have a 121 Gb drive which is detected by device manager, but does not show in My Computer. In partitio magic V8.0, it shows this disc as a dynamic disk
  • Anonymous May 17, 2009
    Not working Internet
    Problem Solver:
  • 6 Answers
In device manager, local disk manager, right-click the disk (not the empty area). Select convert to basic disk. it will be done after a warning/confirmation/possibly restart.
Now right-click the empty area, create a simple volume or primary partition.
Posted on Jul 18, 2009
    President:
  • 2,022 Answers
Just right click on my computer go to manage and then go to stogae and then select disk managment it will show the list of hard drive connceted select your drive according to the size. format it and it will show you in my computer. bye
Posted on Oct 01, 2007
SOURCE:
My notebook is not detecting this desktop drive (3.5'' 1 TB external desktop hard drive - verbatim). My other 500 GB external hard drives are properly detected.
Go to Control Panel - Administrative Tools - Computer Management Then go into Disk Management. Hopefully you will see a drive with a capacity of about 480 GB (plus or minus), that's your disk.
Right click on it and select change drive letter and change the drive letter to something that isn't in use.
If that doesn't work or it doesn't show up, go into the Device Manager from the Computer Management screen and see if there is anything under disk drives with a yellow or red symbol next to it. If so, right click it, select uninstall, then unplug the disk drive and plug it back in.
Feb 27, 2011 | Verbatim 1TB SMARTDISK HD USB-FWIRE COMBO...
External HD is not detected by laptop Windows XP
A common issue...I'm sure your hard drive is working fine, Windows is just not giving it an unused drive letter.
1. Insert the device (camera or usb drive)
2. Right-click "My Computer" and select "Manage".
3. Click on "Disk Management"
4. Right-click the item in the list that looks like your camera or usb drive, and then click "Change Drive Letter and Paths."
5. Click "Change".
6. Give it a drive letter that is not being used.
7. Click OK.
The device should work instantly after that.
Feb 09, 2010 | Western Digital Scorpio WD1600BEVS 160 GB...
My verbatim usb external hard drive quit working on only one of my computers. I tried using computer management but it doesn't recognize it there. it does show up as Toshiba in the device manager but...
The brand of your HD is Verbatim, so it should not show up as Toshiba in the Device Manager. Your computer is detecting another device.
Please do not rely on the Device Manager, you have to check the Disk Management instead. If the HD did not show up in the Disk Management, try connecting the HD into another USB ports of the problem computer. It could only be the USB ports of the problem computer is bad.
How many computers do you have? If you have 3 PCs and only one computer is having a problem, then you might need to update the USB driver of the problem computer.
Have a great day!
Sep 04, 2009 | Verbatim 160GB USB FireLite: The "drive...
My slave hard disk is not showing in my computer
Is it formatted ? Does it have a drive letter associated to it? If not then either format it (right click on My computer -> click Manage -> click Disk Management. Now right click the drive if it is showing there and either create partitions and/or format it if it not already formatted.
If it's already formatted, and you just need to assign a drive letter, then in Disk Management, right click the drive and click Change Drive Letter and Paths and assign an unused drive letter, say Z.
Close Computer Management and open My Computer. The new drive should show up now.
HTH,
Deboo
Jan 05, 2009 | Seagate 250GB Maxtor DiamondMax Plus 21...
80 gb wd passport
Maybe it might be that the hard drive is dead , you can test if it works by connecting it to another computer or device (ps3) if it works (reads/writes) you might want to try this http://www.aeonity.com/trialerror .You can burn a live cd (Operating system on cd) and this might detect your drive if its a usb driver problem (used to  detect USB devices).
Oct 08, 2008 | Western Digital My Book Essential Edition...
Samsung 40 GB Spin Point Hard Drive problem
try to use some Hard drive recovery programes or try Paragon partition manager.
Sep 29, 2008 | Samsung (SP0411N) 40 GB Hard Drive
External hardrive problem
you probably need to install some drivers for it before it if you see a question mark in your device manager. wich one i don't know, have to google it yourself. no question mark? then i can't help you at all and am sry for that. gl
Jun 18, 2008 | Western Digital (WD3200JS) 320 GB Hard...
I/O Magic external drive not showing up in computer
Extreme temperatures, either very hot or very cold, can certainly cause damage to your External Hard Drive.  Based upon your description, it sounds like the hard drive enclosure has been damaged.  This would explain why device manager can not recognize it.  Your hard drive is plug-and-play with Windows XP, so no drivers are necessary.  Have you tried plugging it into another computer?
If your hard drive casing has malfunctioned, then retrieving your data is as simple as putting the hard drive inside another hard drive enclosure.  Hard drive enclosures are available at any local computer store, and also available on the I/O Magic website.  Make sure to get the right size enclosure.  Your hard drive has a 3.5" hard drive inside it, which is a standard desktop hard drive.
If you put your hard drive in another enclosure and it still isn't recognized by multiple computers, then the hard drive inside the casing has probably been damaged, and I would recommend contacting a data recovery specialist.
Have a nice day,
I/O Magic Technical Support
Mar 10, 2008 | IO Magic Corporation GigaBank (I250HD35)...
Not detected by My Computer
Go into Control Panel go into 'Administrative Tools', double click 'Computer Management' click on 'Disk Management'. Do you see the hard drive?? Right click on the drive and select 'Format'. If this didn't help, write back and we'll find another way.
Jul 14, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Gateway ONE GZ7108 All-in-One Desktop PC Logo
130 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
