Question about SanDisk Sansa e260 MP3 Player
Loading playlist I can't get a playlist from windows media player to load on to my e260. the songs will sync, but the list info won't. The SanDisk help line said that the problem is that XP assigns a drive letter to the e260. It should see it as a "portable media device". How do I change it from a storage drive to a media device?
  • 626 Answers
The XP Drive letter assignment has nothing to do with Playlists. You need to set the device mode to MSC. Settings>Mode or USB Mode>MSC. Then in Windows Media Player (version 10 or higher) enable auto-sync for the PLAYLISTS only, unless you want all the music force fed to your device everytime you connect. You can add to this question for additional assistance. Best of Luck.
Posted on Oct 01, 2007
How to create playlist on e260 sandisk sansa pm3 player
this is from sansa website FAQ... check it too for ur other concers... well i hope this is what ur looking for...
How do I create and transfer playlists into my MP3 player using Windows Media Player 11?
STEP 1 – Create a playlist
  1. Run Windows Media Player.
  2. Click Create Playlist located in the top left corner.
  3. Type in the name of your playlist.
  4. Drag and drop music files into the Playlist Window.
  5. Click Save Playlist to save the list.
STEP 2 – Transfer the playlist to your device
  1. Click the Sync tab on the top bar.
  2. Drag and drop your playlist from the left window into the Sync List window on the right.
  3. Click Start Sync.
Sep 13, 2009 | SanDisk Sansa e260 MP3 Player
Download from audible
hi,
Have you tried connecting to the net and then continue to subscribe??
Feb 09, 2008 | SanDisk Sansa Clip MP3 Player
Problem recognizing songs in sansa e260 mp3 player.
From what I'm hearing you don't have a good driver. If you still have the disk use that. If not google it or something. I have a Sansa e260 as well so I would suggest loading the songs on in windows media player rather that windows explorer. If you open Media Player and then go to sync and it does not recognize your device, then you have a bad driver. If not, then start syncing your songs that way.
Hope everything works,
Fixer Guy
Feb 04, 2009 | SanDisk Sansa e260 MP3 Player
I can't get a playlist onto my Sansa m240. I tried the method described on this site, and the name of the playlist came up, but said it had no files.
Creating Playlist
To create a playlist for Windows Media Player, follow these steps:
1. Launch Windows Media Player.
2. Clear the List pane by clicking the Clear List pane button.
3. Click the arrow below the Library Tab then select Create Playlist.
4. Type in the name of your Playlist.
Loading Content 14
5. Click Songs from Library then drag them from the Details pane to the List
Pane.
6. To rearrange the songs, drag them up or down in the List pane.
7. Click Save Playlist.
Transferring Playlists
To transfer playlists to your Sansa player, follow these steps:
1. Connect your Sansa player to the computer.
2. Select Sync digital media files to this devices using Windows Media
Player on initial connection.
3. Right-click on Your Sansa Player, then select Set Up Sync.
Loading Content 15
4. Select Personal Playlists from the drop down menu on the left pane.
5. Highlight the playlists you want to transfer to your Sansa player, click Add,
then Finish.
6. Synchronization will start as soon as you click Finish. To see the Sync
progress, click on Sync Results.
Dec 05, 2008 | SanDisk Sansa m240 MP3 Player
Sansa e260 won't accept songs
Hi Janworks4u. Question for you... Did your mp3 work fine with WMP 10? I ask because WMP 11 is known for causing problems w/mp3 players. You can try reverting to WMP 10 to see if that fixes your problem. To do this:
click START, click on CONTROL PANEL, ADD OR REMOVE PROGRAMS (look at the top center of the Add or Remove Programs box that pops up for a little square you can click on that says "show updates." Click that box and then scroll down to WMP 11. Click to change/remove. A box will pop up confirming that you will revert to WMP 10. NOTE THIS WILL NOTE DELETE ANYTHING FROM YOUR COMPUTER! All of your music that is in WMP 11 will still be there in WMP 10!
Now you can try to load your songs back on through WMP 10 and hopefully it'll work for you. Good luck!
Sep 29, 2008 | SanDisk Sansa e260 MP3 Player
Sansa mp3 e260
Well, one way of fixing this can be to watch the files sync to your mp3 player and when it starts syncing the unwanted files, just simply press "stop sync". I think i know what you are using and i had the same problem at first. you will make a sync list and click sync but after that list if finished, it will sync the rest of the songs from your computer also, you can just wait for your wanted sync list to be finished and as soon as it begins to sync the unwanted media, just press stop. this wont harm your computer or your mp3 player.
Aug 25, 2008 | SanDisk Sansa e260 MP3 Player
Download music to my scandisk sansa e260
When you turn on the player, select the music menu, and then scroll down until the playlists logo appears - select that and then your playlist name should be there.
If it still isn't there, then the songs that you tried to sync have some sort of licensing restriction on them that does not allow them to be synced to a portable device - wmp will show them as synced, but alas - they will never actually show up on the player.
May 22, 2008 | SanDisk Sansa e260 MP3 Player
Play list
Rhapsody e260:
Playlists can be made on the fly, but you have to play each song you want to add to the playlist in order to bring up the option.
Basically WinAmp is the way to go [here's how:]
First, start up Winamp and add your songs to its library.
You've probably already done this.
Next, create a playlist.
Call it "Exercise" for this example. Drag a few songs from your library to it.
Next, connect your e260 in MTP mode.
It should show up after a few seconds under the
"Portables" item in the Winamp hierarchy.
Right-click the Exercise playlist and send to your e260.
Wait for the playlist and songs to sync, then disconnect your device.
(Optional) go to your e260's playlists and confirm that Exercise didn't show up. If you do see it, then you probably have a future version of the firmware that doesn't have this problem.
Here's the kick.
Turn the e260 off by holding down the power button for a couple seconds until you see "GOODBYE."
Release the power button. Switch the lock slider to the locked position.
Press the power button and keep holding it down. The blue wheel light will come on, and then you'll see the SanDisk logo. Then the screen will go black and you'll see
Key LOCKED
System shutdown Once you see that message, you can let go of the power button. Flip the lock slider to the unlocked position and press the power button again. Now navigate back to your playlists and you should see Exercise!
Fortunately you don't have to go through these hoops with every sync. You can freely edit existing playlists and add/remove music; these actions appear to work fine. This hack is necessary only to get new playlists to show up.
Feb 20, 2008 | SanDisk Sansa e260 MP3 Player
Songs Not Loading On Player
Did you use Windows Media Player to format?
WMP never does a thorough format.
If so, try formatting thru My Computer. Right Click on the Device (e260) and select FORMAT.
Then try transferring your music again.
Best of Luck.
Nov 16, 2007 | SanDisk Sansa e260 MP3 Player
Creating+ Saving Playlists and Doubled Songs
If you open the Sansa as normal Win file directory, can you see them? Is "Show Hidden Files" enabled in the file options?
Jan 01, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
62 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
