Question about Samsung DynaFlat TX-P2775H 27" TV
Audio there is no audio coming from the speakers which i hope it's attached to it. i try to fiddle with the sounds control on the menu bar.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
It is not remote problem please check the following 1 speaker or its wire for loose 2 check supply to sound section 3 check loose contact or loose part or print. 4 check for loose connector 5 check audio ic 6 check for signal to sound section ic is coming. hope this will help.
Posted on Oct 01, 2007
My new Vizion tv has a vizion sound bar, the sound comes out with an echo, how do I correct?
Your TV speakers should be turned all the way down or off when you use a separate sound system such as a soundbar. Using them with the soundbar may cause echoes and the TV speakers do nothing to improve the sound.
Look at your TV's audio menu. If you can, turn the TV speakers off completely at the menu. Also see if you can set the analog audio output to "variable." This will allow you to control the soundbar's volume with the TV remote.
Jul 08, 2017 | Echo Computers & Internet
Tip
How to computer capture a sound card
<p>Record and recording the sounds through the computer sound is a relatively simple procedure that only a free space on the hard disk, suitable software and a short profile of TRS cable is required. Windows computers usually come with an audio recording program, from the entertainment equipment a program is found in the Start menu. <br /> <p><br /> <p>1. Turning off the computer speaker's audio jack of your computer's sound card. <br /> <p><br /> <p>2. Attach the small RCA cable into the sound card speaker output. <br /> <p><br /> <p>3. Connect the other end of the RCA small correction to the microphone port on your sound card. <br /> <p><br /> <p>4. Start the Sound Recorder program from the Start menu. Click the Record button. Tell your computer to the sound you want music or video progress bar to take to indicate when the movie is ready to play. Click the Record button, which will continue to record. <br /> <p><br /> <p>5. Click the File menu in the Sound Recorder program and select "Save As". Enter a filename and click Save. <br />
on Jun 22, 2011 | Computers & Internet
No sound from TV but if we connect headset sound comes from headset what is the solution
Check the settings in the "Audio" section on the menu on the TV. Check to make sure the TV speakers are in the "on" position in the menu and that the "Analog audio out" on the menu (if there is one in the menu), is set to "variable" if you are controlling the volume with the TV and not a sound bar.
Jan 23, 2016 | Televison & Video
Sound breaks. have to fiddle with volume button
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
hope this helps
Jun 27, 2011 | Altec Lansing VS2121 Computer Speakers
Toshiba VC-L2B Remote Control Sound volume bar is moving up and down, but there is no sound out of speaker.
Check to make sure the wiring between the sound bar and your audio source is hooked up correctly. Check the source to see if it has it's own volume control. Many TVs require external speakers to be enabled in the "audio" section of your TV's "Settings" menu.
May 04, 2011 | Toshiba VC-L2B Remote Control
I am trying to turn on my radio on the computer but i'm not getting any sound. please help!
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Oct 11, 2010 | Dell AS500 Sound Bar Computer Speakers
Internal speaker only beeps no real sound will come out.
just install the audio driver on your driver disk that comes with your laptop...Hope this works! ITTech7574
Aug 28, 2009 | HP Pavilion dv9000z Notebook
Hooking up a sound bar to a 42'' flat screen panasonic can't get any sound from sound bar.
Go into the "menu" of the Panasonic TV toggle down to Audio and speakers and turn them "off" this turns on the monitor output from the preamp section. If you still have an issue, post a comment and I'll walk you thru troubleshooting. Hope this helps
Jun 24, 2009 | Audio Players & Recorders
TV Audio out to HRT 5650 receiver
You may need to enable the fixed audio output line level from the TV. Some TV`s require you to enter the AUDIO menu/setup selection on the TV remote controller, and then enable the AUDIO OUTPUT Jacks, this will turn off the TV built in speakers and engage the audio RCA Jacks.
Feb 15, 2009 | Yamaha HTR-5650 Receiver
Amp and sub bass playing through all speakers
You need to go into the setup menu and find out if the radio has a sub low-pass filter that redirects the bass to the pre-out for the subs, and away from the main speakers. Fiddle in the audio menu.
Apr 15, 2007 | Xtreme Sound WMS336 CD Player
Samsung DynaFlat TX-P2775H 27" TV Logo
61 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
