What video format is requird for my phillips gogear model sa52xx?
Tell me now what philips sa52xx video format supported ?
You can convert most formats for the phillips with the conversion software, Available at the phillips website
You could try to use Leawo Video Converter to convert the video so that it could play on your Philips gogear sa52xx. And the conversion steps are as describe in the article: https://www.leawo.org/tutorial/how-to-convert-mov-to-mp4-with-free-mov-to-mp4-converter.htm
Smv
Do you have the right format of videos for the device? and i believe that that model requires Mp4 format for videos
SOURCE: my gogear wont load
You need to update the firmware to resolve the issue, but here are some pre-steps:
Make sure the hold/lock is not engaged
Try another USB port
Reset the player
If that fails:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
If still nothing:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
SOURCE: Cannot delete playlist folders on my gogear
My gogear SA52XX wont show the names of the songs
SOURCE: My Philips SA52xx GoGear MP4 Player won't start up.
if it has too many songs on it try deleting some of the songs off the player, and if thats not the case, stop using it for a few days then try to turn it on again
SOURCE: Not able to play video in philips gogear pls suggets
Media players need the matching video format: for GoGear Vibe it is SMV.
To convert video from AVI to SigmaTel Motion Video, use the Media Converter Software from the manufacturer. For the videos you'd like to convert, be sure to update video codecs in Windows Media Player 10 or higher.
Vibe players have different display sizes, so you'll need the matching Converter for your player.
When you have the United States version SA5285/37 next site gives all support, including the Arcsoft video converter:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA5285/37&slg=en&scy=US
note
There's and update for the Arcsoft converter, for downloading directly YouTube films:
click on EXTRAS at the top right hand corner of the Arcsoft main screen.
At the pull down menu click UPDATE AND PATCHES, Arcsoft will check
and let user download and install the updated Stream Ripper feature
( streaming videos need flv video codec )
SOURCE: i cant play video in philips gogear sa52xx 4gb ?
wat is the software to down load vedio songs
cuando lo prendo solo queda prendido el logo se queda frisado
i don't know what format the video's have to be in to work
