If this heater is hooked up to automation check the temperature reading on the indoor remote. If it reading over 104 the sensor is bad and the heater will not fire thinking that it is at set temp.
SOURCE: Jandy Lite 2 does not ignite
burners are plug with spider get a wire and bended get it inside the orifices where the gas come out every single one than try now ? magic heater comes on
SOURCE: jandy lite2 heater has fl5 error code, all voltages look good
If all voltage test points are within range, then it's 1 of 3 problems: Power Conversion Plug is faulty; Power Control Board is faulty; or Controller is faulty. Jandy says there is no way to test any of these directly. They recommend that you replace both the Power Conversion Plug (~$35) and the Power Control Board (~$230). Apparently when one fails, it can cause the other to fail as well. They said that unless the Controller has a lot of corrosion on it, then it probably is not the issue.
SOURCE: My Jandy Laars LX 400,000 BTU heater flashes "low pressure"
Once you try to ignite three times in succession, and the heater doesn't sense the presence of flame, the heater goes into "lockout" mode and must be reset to fire. This can be done by pressing and releasing the mode button so that the heater is turned off then returned to the desired mode. So if you were going to "jumper" the pressure switch, (connecting two wires together) make sure you do the reset also. Make sure you don't operate like this, if your pump quit, you could have a melt down. Also If you have anything connected to the fireman switch, it is in series with the pressure switch,and woud display the same thing. There is a terminal with two white wires, if there is a jumper there, then nothing conected, but if there is something connected, make sure it is closed. Also be sure your code was for Water pressure and not air pressure switch. You can download manuals at: www.jandy.com
SOURCE: Jandy Lite 2 LJ will not ignite
water is leaking down onto the burner putting out the heater????
