Question about SanDisk Memory Media
Need to format my memory card
I had my memory card out of my phone for 6 weeks and now when i put it in my phone it says that the disk is not formatted but before i took it out it was working what do i do its a 2gb sd micro i dont want to have to buy a new one can you help me format it please
Re: need to format my memory card
I have a SD HC memory card in my canon, but when I plug it into a kodak machine at walgreens to print out photos, it says it can't read it. It also happened when my friend tried to plug it into his computer. What's wrong?
Posted on Dec 19, 2007
    Brigadier General:
  • 6,966 Answers
Hi, Your post "help me format it please" could be done by your own phone. Normally format is one of the setup functions within your phone. Alternately, you can use a memory card reader attached to a PC and the format command of the PC's OS will also work since the it will detected as a Removable Device/Storage. Please be reminded that by formatting a memory card, all its contents/data will be deleted. Hope this be of some help/idea. Post back how things turned up or should you need additional information. Good luck and kind regards.
Posted on Oct 01, 2007
0 characters
3 Points
Greetings! I have a SanDisk M2 memory card for my
-u- can always contact geek patrol tell them what -u- -r- going through they may have the answer -u- -r- looking for//
Oct 29, 2013 | Memory Cards & USB Flash Drives
I have a san disk 2gb memory card for my nokia phone, i took my memory card out for the first time as i wanted to put the pictures from it onto my computer, everything worked fine, however when i put my...
you can not format your card without loosing data on it. The solution is to copy all the data to your computer, format the card (in your computer, still) and then copy the data back.
Hope this helps,
Jul 10, 2011 | SanDisk 2GB microSD Memory Card
Memory card not formatted when we put inside the card reader,pl. give me to solution for which how we can format.
Well, formatting it immediately is not recommended. There might be quite a lot of reasons that may cause this kind of format error problem saying memory card not formatted. Check out this article memory card not formatted - how to fix & recover to learn more the right fix step by step. Best regards.
Jan 28, 2011 | SanDisk 2GB Secure Digital Memory Card
Once put in phone it states that I need a disk error check
some card gets corrupted when put into phone while the phone is on so try inserting the card by switching the phone off. Try formatting the card and try.
Jan 12, 2010 | PNY 2GB microSD Memory Card
Memory card
Does your phone itself have enough memory to store your videos. If so, put the card back into phone, create a folder in the phone memory and transfer the vids from card to phone. When done, put the card back into PC and format it (Quick Format if poss). When done, put it bach in phone and transfer vids back. Now put it in PC, it should read a card which it formatted itself! Ian.
Sep 19, 2009 | Kingston 2GB Secure Digital Memory Card
San Disk 4GB Misro Sd No apparent memory
Preformat : By Fix-shad0w
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from or
Open up 'My Computer'. You should see it under the list of available drives.
Check its contents first to make sure that you have the right drive.
In 'My Computer', right-click on the drive and choose 'Format'.
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Apr 05, 2009 | SanDisk 4GB microSD High Capacity Memory...
My new 8gb sandisk says it is not formatted and I can't format it
well i heard on another website - that because the memory card can hold alot of memory, the computer doesnt accept it, so you need to use a usb memory card reader, ebay sells it for like £1
Mar 31, 2009 | SanDisk 8GB microSDHC Memory Card with...
what kind of phone is it, my phone came with a mini-sd card adapter. just get an adapter and connect to computer to format.
Mar 15, 2009 | SanDisk 4GB microSD High Capacity Memory...
1gb sandisk memory card.
1st plug in the memory card into the computer. Go to start , then my computer . Locate the drive that has your card . right click on it and format the removable disk. This will clean the mini memory card back to it's new condition.It will also empty it so make sure your files are saved on your computer. Try again to put music on.
Jan 28, 2009 | SanDisk 1GB microSD Memory Card
HI there, I have a scan disk memory card 1G when it is in the phone (nokia 3500c) it told me ... "memory card not formatted". So i format it ... but it keep telling me that the card need to be formatted...
If you can, plug the memory card into your computer, open it for viewing and delete all files on the card.  Then put it in the phone and format it.  This is the only way I can think to do it.  At least this is what I had to do.  Good Luck.
Jan 08, 2009 | SanDisk 1GB microSD Memory Card
Memory Cards & USB Flash Drives Logo
85 people viewed this question
Top SanDisk Memory Cards & USB Flash Drives Experts
Brian Sullivan
Brian Sullivan
Are you a SanDisk Memory Card and USB Flash Drive Expert? Answer questions, earn points and help others
