Question about Motorola Mobility i880 Cellular Phone
Nextel i880 battery will not hold a charge even after on the charger all night as soon as i take iy off the charger it beeps and says low battery
  • 4 more comments
  • Anonymous Dec 14, 2007
    My Battery will not hold a charge even after on the charger all night as soon as i take iy off the charger it beeps and says low battery
  • eddybullride Feb 06, 2008
    Same as nick411. Unit will not charge.
  • kwon Mar 03, 2008
    ok, ive got the same problem, today i got a i880 and when i plug it in to charge it says full battery but as soon as the charger is detached it says low battery, i called the place i got my phone from and they said to charge the phone for 8 to 12 hours and the problem should be solve. I did that and guess wat it still doesnt work,
    wat can i do to solve this problem
  • Anonymous Apr 24, 2008
    i have recieved 2 new i880 and neither one of them will charge it will show full battery untill i take it of the charger then it showes its going dead and yes i let it charge for 12 hoursĀ
  • dogygdogy1 Apr 25, 2008
    mine is the same pro dude did u get yours to work if so let me know just im me my s/n is dogygdogy1 i relly need this phone to dya so if u can get u help?
  • Anonymous Apr 01, 2014
    Samsung S720C keeps beeping/vibrating when the battery is low and even the charger is connected
I had the same problem with the i880 that I brought off ebay (the seller said the battery was brand new). I found out that the battery was a fake! The F**kin battery is fake. My roomate has a motorokr and it uses the same battery. I compared both batteries and found that there were differences in thickness and the sticker was put on backwards. Just get a new battery and make sure it's REAL. People are making fake batteries on ebay!
Posted on Feb 18, 2008
After sending in my i880 units to Motorola for repair which did not solve the problem, I was certain it was the batteries I was buying from a low price cellular equipment/assessory site, where I purchased seven BT60 batteries for $12 each. Every one had the same issue (would not charge), so I ordered more batteries from the Nextel site for $40 each, and no longer had any problems.
Posted on Feb 17, 2008
I had this problem , my mini smart card thing was bad, i kept putting it in every new phone they sent me and kept getting the same problem till i realised it was the mini smart card
Posted on Feb 13, 2008
I have the same problem. The battery that you have is not the right kind. There are 2 types of batteries, a white and black. In my case i have a white one and its not working right so the company i bought it from is sending me the black one. Take a look at what you have and go from there.
Posted on Feb 12, 2008
SOURCE:
FAULT CODE SAYS BATTS ARE LOW AFTER CHARGING
hi, lets work on the assumption that your scooter is correct in saying the batteries are low, why is that ? , well you need to look at the charger and if possible try another charger , the other thing that could have happened is the charger fuse has blown, this is located on the tiller stem
If you are convinced that the charger and fuse are okay , look at the batteries, just because it a new scooter does not mean it new batteries ., let me explain let say your scooter has been assembled a year ago, batteries fitted , now the batteries have not been touched during that period , that in itself can kill batteries or as soon as you start charging them they give up.
I have seen this happen on many occasions.
Please rate my assistance
Regards
Jan 03, 2013 | Pride Pursuit XL PMV
My battery will not hold a charge, Even when plugged into the charger. What do I do to fix it?
I suggest you remove the battery and put it in a similar phone and charge with your charger to see if it will hold charge.
If it does, i means the battery is still good. but if it does not, it means the battery cell is dead and the battery will need to be replaced.
The problem could also be the charging port of your phone, it may be bad and not charging your phone but if it is charging it, it means the cell of your battery is dead and will need to be replace.
Just check the battery, charging port or the charger, one of either of this three is bad.
Take care
Apr 20, 2010 | Nextel i860
Sell nextel i9 i877 i876 i880 i580 phone
GOSTARIA DE SABER COMO TIRAR CODICO ESPECIAL DE NEXTEL
Jun 03, 2009 | Nextel i860
UPSIDE DOWN SCREEN IN MY I880 NETEXL FLIP PHONE
take the battery out of your phone with the power on. then try to turn it back on and see what happens. if still a problem take it to a sprint store. they can replace it.
Mar 31, 2009 | Motorola Mobility i880 Cellular Phone
Where is the usb port on this phone
http://nextelonline.nextel.com/NASApp/onlinestore/en/Action/OSBrowseAccessoriesDetail?PHONE_ID=I880G&categoryRefName=Data+%26+Connectivity
solution to this problem is that the USB is on the connector
its an accessory
-->pt_accessories_en.gif Data & Connectivity for the i880 by Motorola (Choose a different phone) spacer.gif Motorola USB Charging Data Cable - Item # NNTN5405 nntn5405_l.gif Easily link your phone to the USB connector of a computer or PDA, use your phone as a wireless modem and more. The cable also features an integrated charging port so the phone can be charged while simultaneously performing data operations. The charging port can be used with compatible standard, rapid and vehicle power chargers.
Jan 24, 2009 | Motorola Mobility i880 Cellular Phone
I NEED HELP WITH MY I880
i got the same f problem
but i change the baterie and guees what! the new baterie dont take the charge, something wrong with the phone,
Apr 28, 2008 | Motorola Mobility i880 Cellular Phone
Battery wont charge
make sure its the right part number. there are 2 bt60 batteries, snn5782 for nextel(ic series, i880), and snn5744 for motorola smartphones(ming, Q,)
Mar 08, 2008 | Motorola Mobility i880 Cellular Phone
Motorola Mobility i880 Cellular Phone Logo
251 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
