Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Ringtones i cant get my ringtones to play when a call comes in. I set the tone that i want and it says that the call ringtone is set but when someone calls me, the sound is a totally different one. What do i got to do to make it play the ringtone that i want?
  • 72 Answers
Try going into ring styles, then detail for whatever ring style you're using, scroll down and make sure that, if you have the option, Ringer IDs is set to 'on'.
Posted on Oct 18, 2007
  • 36 Answers
Hi, before applying tone, play it & listen, if it plays sound. Resent ur mobiles master setting & apply now. bye
Posted on Oct 03, 2007
SOURCE:
How to change call ringtone on nokia e63
Hi Violin,
I have this steps for you for work around setting up call ringtone. Hope it helps.
--- there should be no prob to set a custom tone if you go to the tone and select options you should get an option to select from a list from the menu otherwise go to profile and select edit then when you come to ringtone select options and you will get options you should be able to select a tone from the gallery
---I discovered something about this problem. It appears that if you have the same phone number assigned to two (or more) contacts the ringtone plays the default ringtone. Once I deleted one of the contacts with the same number, it played the correct custom ringtone. What is strange is that both contacts had the same ringtone. BTW, the reason I had done this was to simplify the voice command to make a call to this contact.
Apr 25, 2014 | Nokia E63 Cell Phone
Downloaded a ring tone with the memory card but when i load it on the phone it will only play as music, can't set it as a ringtone.
Hi friend,
Could you tell me if your cell phone can support the function?
You can check like the following:user profile-General-Customize-Tone setup-Incoming call,then you can see many ringtones in it,Could you see the icon"empty"?If so,you can set the ringtone you downloaded as the ring tone of incoming call.You just need to find the ring tone you downloaded,and transmit it to the "user profile".
But if there doesn't have any "empty" icon,I am afraid that you cannot set it.But you can try to cancel some ringtones ,and replace them by the ringtones you downloaded.
You can get much detailed information in the website:www.1010store.com
Sep 15, 2009 | LG Xenon GR500 Cell Phone
Low ringtone
You might try this:
Menu>Tools>Utilities>3-D tones>3-D ringing tone effects>Off
On my N96 it works.
Nov 10, 2008 | Nokia N96 Smartphone
Using a file in MY Rintone file as my call ringer
When Your Ring Tone Is Highlighted Click on it then click Menu And Select Set As Ringtone. That Will Now Be Your Defaullt Ringer.If You Want It To Be A Custom Ringtone i can't help you with that sorry.
Jun 24, 2008 | Pantech Duo Smartphone
Ringtone problem
You settings are not activated so please refer your phone user manual do the steps by step then it will work fine
1) First save the specific number
2) Select the ring tone
3) Assign the this ring tone for that number
This information help to you othere wise refer your phone user manuals
Jun 11, 2008 | LG VX8300 Cellular Phone
6600 ringtone
go to Profile in Menu
select outdoor
options- personalise
set to------
Ringing Tone-  any ringtone u want
Ringing Type- Ringing
Ringing Volume- Full
Message Alert tone- any tone u want
Vibrating Alert- on
keypad Tones-__________
Warning Tones-_____________
Alert For-_________________
Profile Name-_____________
Mar 25, 2008 | Nokia 6600
Ringing Tone
Just copy the ringtone in phone memory which you want to set. It will give you option to set it as ringtone.
Jan 17, 2008 | Nokia 6600
I have polyphonic ringtones but can set as ringtones
try master resetting the phone if that does not help then have the firmware reflash on the phone.
Aug 12, 2007 | Motorola Mobility RAZR V3
Ringtones not able to be set!
yes u can set ring tone what ever you have in phone memory only( if it in sd card u cant set the tone, 1st move the ring tone from sd card to phone memory with format of Mp3... then u can njoy ring tone
Apr 29, 2007 | Motorola Mobility RAZR V3
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
113 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
