Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
Posted on Apr 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I accidentally hit the time bake button instead of the clock button now my oven will not work. This is a Fridgidire oven model FEF372AS1. How can I cancell the time bake function. I have turned off the circuit breaker and unpluged the oven as well.This has not worked. Any advice would be appreciated. Thank you.
706Cajun
Level 2:
  • Expert 34 Answers
  • Posted on Apr 28, 2009
706Cajun
Expert
Level 2:
Answers
34
Questions
0
Helped
19731
Points
125
Are you getting any codes? Sounds like one of your touchpad buttons is stuck. CAUTION: Turn power off to oven at circuit breaker.  I would take the control panel off disconnect the ribbon from the touchpad and take a pencil eraser and clean the contacts. Reconnect ribbon connector back together. If this does not help write back..
How to set the time on a B7500M AEG oven
To set the time on an AEG B7500M oven, follow these steps:
  1. Press the "Clock" button on the control panel. The display will show the current time.
  2. Press the "Hour" button to set the hour. Use the "Plus" and "Minus" buttons to adjust the hour.
  3. Press the "Minute" button to set the minute. Use the "Plus" and "Minus" buttons to adjust the minute.
  4. Press the "Clock" button again to confirm the time and exit the time-setting mode.
Note: If the oven is in the process of cooking or baking, you will not be able to set the time until the cooking or baking process is complete.
Jan 09, 2023 • AEG Ovens
Accidentally hit the oven clean button while baking
Hello there.
From the manual I got
To Stop Self-Clean any time:
Press UPPER OFF, LOWER OFF or OFF/CANCEL. If the oven
temperature is too high, the door will remain locked. It will not
unlock until the oven cools
Hope it helps/
2answers
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
When pushing the button bake and broil the red light starts to blink on lock ? this happened after i woke 1 morning n noticed there was no time where the clock was, it was all dark n nothing worked, after...
if the clock is blank it's bad and you have to change out the clock assy. if that's your model number MEW5527B it says your part is
WP74009198 and it's around 260 dollars but this must be an older wall oven because nobody has it in stock,you can go here,put your full model number in and go to control panel and look up your computer board or clock assy. same thing
https://www.searspartsdirect.com/model-number/MEW5527BAW/3048/0125300.html
We have a maytag electric range/oven model #MER5770AAW .after baking some french fries ,with the oven open it made a beep and F9 message came up on the panel.everything still functions ,have hit the...
F9 Door Lock Warning Check door lock circuit or Replace Clock. If clock working don't do that.
ck here for the code.
https://www.repairclinic.com/RepairHelp/FaultCodes/31/Range-Stove-Oven
parts here....
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/19-4-93082-/new/Maytag-Oven-not-self-cleaning-MER5770AAW
you can call their 800# or use the chat for more info if needed.
first check that the latch is not a 1/4 or so closed.
open and close the latch a few times.
also you can turn off the breaker for a few minutes
and see if it resets the ecm.
Hope this helps a little
1helpful
Oven won't light, even with ignitor getting red
If your oven won't bake, check these:
Bake igniter
Other causes
Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
3helpful
Lg lre30451sw oven the start button doesn't work
This happened to me on Christmas Day morning & it happened once before. I finally remembered how I fixed it. Push the "Clear" button & then push the "Start" & keep it held in until you see the lock button light up (takes awhile) & then push the "Clear" button again. After I did this the "Clock" worked again - reset the clock to the correct time & push "Start" Then click on "Bake" set your temperature & push "Start". Hope this works for you. It got me out of cooking Christmas Dinner, but I fixed it today!!
Sep 25, 2008 • Ovens
Jennair single oven...
Hey marygilfilen
F8 error is associated system failure. I suggest you need to replace your clock (controller)
Regards
Broil turns ON when pressing BAKE button on RBS275PD Whirlppol oven
Our Whirlpool oven just started doing the same thing!!!! The Delay Start Time (setting it for one minute ahead) and then Start works just fine.  But we fried the tops of three loaves of homemade bread!!!!
Is Whirlpool just a bad brand for ovens?
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
