Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Lense Cover Stuck
The lense cover on my camera has become stuck somehow. I didn't drop it or anything, but I had been taking a lot of pictures and I went to turn the camera on again, but the lense cover only opened halfway . The camera still takes pictures, but the edges are black because the picture has to be taken through the slit in the lense covers. Any ideas? I'm kind of out in the middle of nowhere away from a camera repair shop..
  • margedbq Mar 21, 2009
    I have a Canon PowerShot A630, the lens cover suddenly opened only part way. The pictures can only be taken through part of the lens, and have black edges. It neither opens nor closes completely. I had just taken a picture, went to take another, but the cover got stuck.
    I understand this is a common problem with these Canons. I'd love to know of others who have the problem.
  • NotSoTechie Mar 24, 2009
    I have a similar prblm with my sd750. Was at a beach, switched on the cam and d lens cover opens less than halfway!! Tried to open the lens by switching the cam multiple times. Didn't drop d camera as far as i'm aware. Didnt try clicking pics so not sure if it works.
    However, when i hit the play button i can see all the pics that I have taken.
    Is this a problem with the IC or motherboard?? Please help.
  • Canon Master
  • 4,738 Answers
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and be aware this will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Posted on Nov 25, 2007
  • 4 Answers
Switch off, take out the battery and insert the battery again might help. Regards Raman
Posted on Oct 01, 2007
My lens is stuck out and it will no longer take pictures. It is brand new!
The lens has either been hit, dropped against something, or the camera allowed to turn on while in a pocket/purse/case. The lense drive gears are plastic and not entirely substantial and require care - which most people especially teens and 20's don't give them. Once in this condition, they're done for. You can attempt to contact Fuji for repair, but you'd be responsible for the cost unless they're feeling especially nice that day, since there's simply no way for the lense to become jammed during normal operation - unless the lens is bumped or hit while open.
Since these camera require total disassembly, from the back forward, to get to the lense assembly, it'll be cheaper or near it to replace it than to repair it. Take it as lesson learned, and treat the next one with more care. NEVER touch the lense when open, NEVER allow it to bump anything, NEVER drop it, NEVER place it in your pocket or purse unless the power button is protected from being accidentally turned on.
Aug 22, 2011 | Fuji Photography
Turn the power off and on again
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
I have the same problem
Hi:
If you did not drop it, you probably have some dust or small particles around the outside of the lense. They prevent the lense from fully opening. The lense cover might have the same problem. As a result it is stuck.
When the lense open up try to clean around the lenseor the cover. If it opens, but not all the way out, try to pull it out NOT too hard.
When it opens, try dust off. Make sure you do not force too hard on all of the steps above.
Good LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 23, 2009 | Samsung Digimax S630 Digital Camera
Lens are stuck out. screen says "lens error"
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can not take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard for a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal. Make sure to clean the outside of the lense when fully open and keep it clean always. If this did not help, read 2.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inspect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on the camera and your camera would be back to normal.
Good luck!!!!!!
Jun 11, 2009 | Olympus FE-270 Digital Camera
My easyshare m1063 will take pictures, but the pictures dont show
I have an easyshare and there's a 2 part lens cover that closes when you turn it off and opens when you turn it on - normally. Mine only closes one part of the cover when I turn it off and opens when I turn it on. Kodak said I could send it in but I may have sat on it and caused it to malfunction. In which case they wouldn't cover it. Yours sounds like it's not opening at all. Look at the lens, and if you see a flat black cover with a wavy line instead of glass when you turn it on, yours is stuck shut. If it's still under warranty they should fix it unless you sat on yours too. Consumer Reports rated these a best buy but somehow this problem fell through the cracks of their testing.
May 28, 2009 | HP Photosmart M525 Digital Camera
My canon SD850 IS digital camera is not even a year old and well taken care of. I thasnt been dropped and is already broken? What do i do...everytime i turn it on all of the sudden the lense is stuck poped...
Take a look at the suggestions at the top of page 122 of the Advanced Camera User Guide. The suggestion is that the cause may have been that the camera was still on when the memory card/battery cover was opened. Try closing the cover and then turning the camera off and then on again. Hope this helps.
Jack
Nov 26, 2008 | Canon PowerShot SD850 IS Digital Camera
My camera's display is black when I try to take a picture, and all the pictures I take are all black. How do I fix this problem?
Your digital signal processor is bad or your lense shutter is stuck on the inside. A stuck lense can be fixed by replacing the lense barrel. Check out Camera Shy Anna on Ebay stores. They can fix your digital camera.
Nov 25, 2008 | Cameras
Olympus Fe-220 Lense.
i dont think so..i think this is a generic problem for the fe210 just like mine. it would not shoot and only black screen in the view finder... my brother in law brought it to a technician and they replaced the lense assembly.
Jul 06, 2008 | Olympus FE-210 Digital Camera
Lens stuck help anyone
if you feel that the camera is making effort to extend the lense out and the lense is still jammed, get the help of a repairer.
Sep 15, 2006 | Sony Cyber-shot DSC-W70 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
341 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
