Question about Energizer Rechargable Battery with Charger
Energizer charger not charging batteries
Hello. I have an Energizer Battery Charger that can charge up to 4 AAA or AA recharble NiMH batteries. I have used this once and it charged the batteries that time, but didn't fully charge them even though I had them on the charger the recommended time. I have not used this charge in maybe a month and have plugged it in every outlet of my house and it still will not charge the batteries. Should I just attempt to go to the store where I bought it and just exchange it? I've tried to hunt down the manual online since I can't seem to find it at my house anywhere, so I am unsure if I continue to search online for it or give up and just exchange it. Any advice? Please let me know...preferrably through email: [email protected] Thanks, Sweety051785
  • 4 more comments
  • Anonymous Dec 15, 2007
    lost the manual and are not sure how to use it. t is a fifteen minute charger for AA and AAA batteries
  • Anonymous Jan 08, 2008
    my energizer charger is not charging my batteries
  • nikkichicki Feb 06, 2008
    I have the same type of charger, and it just blinks red. and it won't charge the batteries either. V. frustrating.
  • Anonymous Feb 20, 2008
    I have 2 of these chargers and neither of the LED's work.... I doubt they are charging my batteries either. I always thought you can trust Branded makes..... I guess cheaper maybe best afterall.
    Any solutions?
  • rosemarygo Mar 27, 2008
    me too. the battery light just blinks red.  I have energizer battieries. tried different outlets.
  • golder Jul 22, 2008
    Same deal for me it worked a few times but now seems completely dead. I measured a voltage between the + #1 cell terminel and the - #2/3 terminal but all other combinations measure nothing.
    I don't see any solutions here!
    Top Expert:
  • Energizer Master
  • 85,160 Answers
It is most likely the batteries are no good not the charger
Posted on Mar 25, 2017
3 Suggested Answers
SOURCE:
  • 8 Answers
SOURCE: Energizer CHDC charger suddenly not indicating if charging or not
It sounds like the PC Board which provides the circuitry for the Charger's indicating light is malfuntioning. If you have a DC volt-meter, you can check the Charger's output voltage, and then the Battery voltage to determine if your charger is functioning.
Hint: If the Charger has an output voltage, but the Battery's voltage is less than its rated voltage... it's time for a new battery.
Posted on Mar 23, 2009
philman357
  • 33 Answers
SOURCE: energizer CH2PC-UK battery charger' how long do i
Charge time depends on the mAh capacity of the batteries (should be listed on the package, or the side of the battery) most AAAs are under 900mAh so 2 hrs should be sufficient, but AAs vary greatly in capacity so heres a link to check after you look up your mAh rating
http://energizer.com/SiteCollectionDocuments/pdf/rechargeable/CHDC.pdf
Posted on Jan 14, 2011
I have a wii system and use the energizer nimh battery pack with the wii charger. When I put them in the charger it flashes red. Reminds me of my camera battery charger, but I have learned how to reset...
I have this issue with one of the batteries in my set. (Purchased last summer). It is a PL-7522
It seams to be the battery, as I have tried combination of charging ports and controllers. The other battery seams fine.
Dec 24, 2010 | Energizer NiMH Compact AA/AAA Battery...
How do I place 2 batteries in charger instead 0f 4?
Hello. Just place the two batteries together at the far left, or at the far right to charge them.. Just do not place them in the middle, or with an empty space between them. here is a link to the instruction sheet for your future reference http://data.energizer.com/PDFs/chdc_instructions_english.pdf
Nov 17, 2009 | Energizer NiMH Compact AA/AAA Battery...
I have an Energizer E2 Slider battery charger, Is the green light supposed to stay on when charging. Does it shut off when charge complete.
all chargers show a light of some colour when charging , green or red , depending on make of charger , when the battery is fully charged the unit monitor this and automatically switch of to stop from over charging , a safety feature that has to built in for safety reasons ,
Jul 19, 2009 | Energizer NiMH Compact AA/AAA Battery...
WORKING INSTRUCTIONS FOR NIMH CHARGER NO LIGHTS COME ON NOT GREEN
one problem here could be the contacts btetween the batteries and the charger , had a similar problem myself and found bu using a very small , mean small too , you can slightly bend out the contacts and hopefully presto , contact has been made , lights come on and batteries are charging , make sure its not plugged into the wall when you do this , and only use very slight pressure on the contacts
Jul 04, 2009 | Energizer NiMH Compact AA/AAA Battery...
Energizer +AA NIMH Batteries consumed quickly
There are many grades of batteries under the same manufacturers name. They have a different Ah rating. The lower the Ah the shorter the time they will last.
Mar 02, 2017 | Energizer Duo Battery Charger for AA and...
Energizer Rechargable Battery with Charger Logo
2,374 people viewed this question
Top Energizer Electronics - Others Experts
philman357
philman357
Level 1 Expert
Bill Boyd
Stephen Miller
Are you an Energizer Electronics - Other Expert? Answer questions, earn points and help others
