Question about HP Pavilion zd8000 Notebook
HP Pavilion zd8000 unexpected Shutdowns
Can anyone tell me why my laptop shutsdown unexpectedly after roughly 20 to 30 minutes turned on. I don't think its an overheated problem as the fans are going. Please help
  • Rhonda_rcb Dec 02, 2007
    My Hp Pavilion zd8000 shuts down and goes black without warning. I have used compressed air to clean it and also use a cooling pad under the computer, but still the fan constantly runs and the computer runs hot.
    Any suggestions?
    Thanks
The heatsink assy. is cloged up with dust and free flow of air has been restricted. This will cause CPU to overheat ,shutting down issues.Use a can of air and blow it all out..
Posted on Nov 24, 2007
A bit late, but here goes. It probably *is* overheating, even with the fans going. Easiest and cheapest way to find out is to go to your local supply store and buy one of those cheap platforms that raise your laptop up a bit to allow better circulation underneath. I was having the same problem, bought one, and it hasn't shut off since.
Posted on Nov 16, 2007
    Brigadier General:
  • 6,966 Answers
Hi, There might be 3 possibilities why your laptop is shutting down: 1. You have a shortcut key in your keyboard that is pressed (accidentally or reacting to other keystrokes) that is configured to shut down your laptop; 2. You have a virus that is programmed to shutdown your laptop after a pre-determined amount of time; and/or 3. Your battery and/or AC adapter is no longer capable of supplying the power needs of your laptop. A few things you can do: a. Verify/Check if you have enabled any key stroke shortcuts for a quick shutdown; b. Check your Control Panel, Power Options, Advance tab, for any autoshutdown features, disable; c. use a known good/updated anti virus program and scan your drives. It might also be a good idea to run a program similar to Ad-Aware to scan for malicious ads; d. Charge your battery overnight and see if the problem persists. Or run the laptop with the AC adapter always plugged in to the mains and to your HP Pavilion ZD8000. Hope this be of some help/idea. Post back how things turned up or should you need additional information. Good luck and kind regards.
Posted on Oct 01, 2007
  • 3 Answers
You need to remove your motherboard from its base and clear out the dust bunnies properly.
If you do not want to do this, sell it to me.
Posted on Dec 09, 2007
Because it over heats, clean it out
Posted on Oct 11, 2007
6ya staff
SOURCE:
Hp pavilion a6110n pc windows 7 pro unexpected shut down
This Falut is your Window please TAke A new window
Aug 08, 2012 | HP Pavilion a6110n PC Desktop
I have an HP Pavilion Notebook. Quite unexpectedly, I went to turn my computer on, and the screen never came on. The lights on the keyboard lit up, but not the screen. I let it sit for a day, turned it on,...
Hi tecarter...
Hook your laptop to an external monitor and see if the screen comes on...if it does then your lcd screen is faulty and needs replacment.
If it does not come on then re-download your video driver/s.
If that does not work.
Maybe your lcd inverter or backlight bulb is faulty and needs replacement.
Please take time to rate me thumbs up
Sep 14, 2011 | HP Pavilion dv1000 Notebook
Laptop shutsdown unexpectedly
It shutsdown because your Computer is overheating so its protecting it, i recommend you cleaning your fan it must be clogged with dust bunnies, open it on the bottom grab a blower and gently bow away dust
Jun 04, 2010 | MSI MegaBook S250 Notebook
How do I fix blue screen unexpected shutdowns on laptopsCQ60
Download the latest video chipset driver from intel web site and it will fix the problem.
May 20, 2010 | Compaq Presario CQ60-220US PC Laptop
I have virtical lines on lap top
Once you start to get vertical lines on your LCD screen, it's usually time for a new screen. I would check first by running an external monitor just to be sure it's not the video card.
May 19, 2010 | HP Pavilion zd8000 Notebook
My hp pavilion dv1000 fan turns on for a little bit then turns back off.Do I need to replace the fan?
Are you having any problems with the laptop overheating or shutting down unexpectedly?
Generally the fan should only run as much as it needs to in order to maintain an optimal temperature. the fan will be turning off as the laptop will be cool enough. if however, the laptop is very hot to touch you may have a faulty sensor telling the fan the laptop is cool when it isnt. this generally leads to the laptop crashing or shutting down though if thats not happening i recommend contacting HP for guidance.
it is most lekely functioning properly if you arent having any other adverse effects
Thanks
Dec 21, 2009 | HP Pavilion dv1311se PC Notebook
Acer aspire 5000 unexpected shutdowns, random, fan running.
Hello
Thank you for using FixYa.
Have you cleaned out the airvents and fan area. these build up with dust and if the unit gets too hot it will shut down unexpected
Also always use on a hard surface so the airvents are kept clear
thanks
Richard
Nov 17, 2009 | Acer Aspire 5100-3357 Notebook
Replacing a keyboard on an HP Pavilion ZD8000
Here is the site I use when repairing laptops and get stuck. This tells and shows what you need to do. Good luck and have a good day.
http://www.insidemylaptop.com/take-apart-hp-pavilion-dv6000-laptop/
Jan 31, 2009 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 Notebook Logo
2,358 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
