Intel PENTIUM-4 865GV CHIP MOTHER BOARD  Motherboard
Program interface
posted by chris442000 on Oct 01, 2007
I have 4 programs that i use and like but the trouble is the interface is to big to fit my monitor (17")and i can't seem to make them smaller. I have tried to reduce with my curser but the whole interface moves but won't reduce, I have checked the resolution and it is set to 600X800.My windows boxes will go to any size i want but its the programs that won't resize.
My operating system is P.C XP.
thank you in advance for any help you can give me.
Chris Kelly
Comment posted on Oct 01, 2007
Hi Benimur
I followed your advise and everything is working great, I can see the whole interface now instead of just some of it.
Thanks for your time and help.
Chris442000
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
FixYa! (100)
Benimur
Rank:Guru Guru
Rating: 87%, 2802 votes
Perhaps the developers of that program has set that to be the maximum size in relation to your Screen resolution.
Maybe what needs to be done is to increase you screen resolution to something like 1280 X 1024 or at least 1024 X 768. This could be done by:
1. Right click on any clear are of your desktop;
2. Click on properties;
3. Go to Settings tab;
4. Set your Screen Resolution to your desired size (1280 X 1024, 1024 X 768 or whatever is comfortably acceptable to you and your video/monitor);
5. If within capability of your video card/monitor, you can also adjust you Color Quality to the Highest (32bit);
6. Click on Advanced button;
7. Click on Monitor tab;
8. Select highest Screen refresh rate (maybe 85 Hertz) within capacity of your video card & monitor;
9. if a selection or setting does not work, pressing escape will revert you back to the previous setting;
10. Apply, OK.
Hope this be of some help/idea. post back how things turned up or should you need further information.
Good luck and kind regards.
Rating Locked! (?) chris442000 has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on program interface:
I don't want to Accept this solution
Can you Help with these Motherboards problems?
Motherboards
I have a mother board of VIA P4M266 AND I WANT TO UPDATE...
Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
10 pitidos
Loading problems.
Repair Service
Find Motherboard Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
