SOURCE: Sansa MP3 Player will not turn on
I had the exact same problem it was after I ran a new firmware update, it flashed on and then turned off and would not turn on or recognize the computer. Solution: Since i didn't have a mini screwdriver to take the battery out, I held down the menu and power button for 15 seconds let go and it powered right up and works great.
SOURCE: Sansa c240 battery issue
Does it indicate that it is fully charged? If it does, I would return it or have it replaced. You have a 1 year warranty from SanDisk. SanDisk Technical Support 1-866-726-3475 If not, try using a different USB port on the computer, preferably one in the back. Best of Luck.
SOURCE: charging the battery by the computer
Reformat the player - the instructions are in your user's manual, which
can also be obtained off the internet at:
http://www.memorexelectronics.com/html/product_detail.php?PID=650#
If that fails, get the firmware upgrade from the above-mentioned website
SOURCE: iopd wheel not responding
I have the same problem and since mine was out of warranty, I decided to try and fix it. I ordered a new ipod nano wheel from ebay for roughly 15 dollars. Search youtube for how to open your nano, which is pretty straightforward. Not as difficult as I thought actually. You can then remove the wheel circuit pad and replace it. It peels right off of the plastic part of the wheel and the metal back part also peels off. They used some sort of sticky back tape, which sounds bad when you try to take it off, but reallty not all that bad. Mine is Gen1, so yours maybe different, just be sure to search fro the right model.
SOURCE: Sony NWZ-E436F won't switch on for more than half a second
Try charging it up on a different computer. It says in the instructions that they cannot guarantee the charging of the battery on personally assembled or modified computers. I had the same problem with mine on our independent computer shop bought PC, but it is charging up fine now that I've plugged it into my hubby's laptop which was bought in a PC supermarket. I hope this helps.
