Question about Mitsubishi VS-4543 45" TV
MITSUBISHI VS-4543
PICTURE GOES OUT ON MY MITSUBISHI MODEL # VS-4543. I have this Model VS-4543, Tv that the picture goes out, with sound. I smack the side of the tv and the picture comes back most of the time immediately. However, occasionally it has not always come back right away. What could be wrong? What can you suggest for me to look at and determine if it is something I can fix or not? Dale My email is [email protected]
  • david342 Jul 28, 2008
    Yes, I also tried hitting but it did not help
    Genius:
  • 1,694 Answers
PVAT!!Look for bad connects--start w/easy first. Power supply,then vertical IC pins,then regulators.Take your time,be thorough.
Posted on Oct 01, 2007
  • Vista Electronics Oct 01, 2007
    Solder as you go-be careful w/solder splash,
    bridging connects together etc.
SOURCE:
My Mitsubishi. TV model number 4543 played but no picture I can hear the sound but no picture.
check the leads in the back are in the right position -most of these are colour coded -white to white red to red yellow to yellow -otherwise you may have to use a hdmi cable or you may just not have the tv unit in the right settings -read your manual if you have one -these can be quite confusing so just play about with it but try and remember what youve done -otherwise see if unit has a factory preset switch you can push and it goes back to how it was set at factory...
Aug 07, 2014 | Televison & Video
I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Jun 04, 2009 | Mitsubishi VS-4544 45" TV
I have a vs-4543 picture only works part time sound always works
most likely bad solder connection or cold solder connection which is making contact after the set is moved or vibrated doe's this happen right away
or after the set is warmed up
May 07, 2009 | Mitsubishi VS-4543 45" TV
Mitsubishi model #VS-4543
2 THINGS CAUSES THIS PROBLEM ON THESE --- THE BLUE PICTURE TUBE HAS LEAKED FLUID ON THE CIRCUIT BOARDS ,,,THAT 'S BAD
AND SOMETIMES ,WHEN THE VERTICAL CIRCUIT GOES OFF ,,THE SCREEN WON'T LIGHT UP ,,,THAT NORMAL ,,,KEEPS FROM DAMANGING OTHER PARTS
U NEED A TECH TUNICA
Oct 29, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
VS-4543 Mitsubishi 45" TV
Replace red convergence IC,both IC's for solid fix
Jan 12, 2008 | Mitsubishi VS-4543 45" TV
Mitsubishi VS 4543, Picture go out after a few minutes
I usually find that symptom you describe is caused by cracked solder joints on the power regulators or vertical output IC. I have also seen that symptom caused by loose solder joints on the vertical windings up inside one of the yokes. If you have experience in repairing TV's then you can disassemble the set and pull the main chassis, flip it over and resolder all of the parts mounted on heat sinks. If you do not have experience in repairing projection TV's then allow a qualified tech to handle it for you.
Aug 05, 2007 | Mitsubishi VS-60607 TV
TV turns off a second after turning on....
You have a high voltage shutdown problem, look at the threads here on Mitsubishi and you will find your answer.
Dec 09, 2006 | Mitsubishi VS-4543 45" TV
Televison & Video Logo
369 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
