Question about Philips VOIP3212 IP Wireless Phone
VOIP will not connect to Skype
When I first installed the Voip 321 it worked perfectly. After a computer restart, although it initialises the base it cannot connect to Skype. When I go to the Windows task Manager it notes the Voip as 'not responding. I have disconnected power and USB for 30 minutes and reconnected; same problem. I have uninstalled and reinstalled with the Skype version 2.0 contained on the Phillips installation CD- still no luck. I'm out of options and ideas. Any help? I run XP and have a reasonably powerful computer with 2g of RAM.
  • 4 more comments
  • Anonymous Nov 19, 2007
    Same thing here. It used to work perfectly, but recently (last succesful call: 20071109) it just stopped working.
    Skype is connected, the VOIP USB Driver says "connected", but I can't place calls or look at my contacts or status from the phone.
  • Anonymous Feb 27, 2008
    Just bought the same phone and am thinking of returning it. Cannot connect to skype. Initialises base unit and then gets stuck on searching for skype. Done all the usual rebooted etc and still no joy.
  • mestre Mar 07, 2008
    Same problem here... My voip3211S/79 used to work ok.. now it just hangs saying SEARCHING FOR SKYPE... I'm unable to make calls.. Any help would be appreciated!!
    Thanks!!
  • macky99 Apr 10, 2008
    This is maddening. Everything about the Philips and Skype sytem are great until the drivers get downloaded. That's when the issues start. I've uninstalled and reinstalled the software twice. Currently, as I'm making a call, I have to quickly change the microphone and speaker settings back to the Windows default settings in order to hear and be heard. Once the call is done, the settings revert to the Philips drivers and iagain have no voice or listening capabilities.
  • Anonymous Oct 10, 2008
    Sounds like I have the same or similar problem. My Voip 321 was working fine and connecting to Skype perfectly. Then, without warning, I picked it up and saw it was ' SEARCHING'. I tried dialing out and heard a busy tone instead of a dial tone. I cannot call via Skype or via landline and cannot receive calls in. It just doesnt ring. I have uninstalled..and reloaded everything.. batteries are fully charged... but still nothing. Please help me out if you can.
  • nikitisis08 Nov 29, 2008
    GOOD MORNING,
    I HAVE XP SISTEM :NEW COMPUTER, EVEN IF THE CORDLESS PHONE CHARGES THE ADDRESS BOOK AND I CAN CALL THEM, I CAN NOT HEAR AND TALK FROM THE PHONE. IT ONLY WORKS THROUGH COMPUTER SO IT IS USELESS AS CORDLESS. PLS TELL ME IF THERE IS A SOLUTION OR IF NOT I PREFER TO KNOW IT AND DO NOT LOOSE TIME ANYMORE IN DOWNLODING SEVERAL TIMES
    BEST REGARDAS
    CASALONE
I am using Omantel,somewhere near
(united Arab emirates) and i've got wireless DSL and my internet is working very good, actually it's perfect but when it comes to skype IT DOES NOT connect AT ALL and if it connects ONCE, it disconnects very quickly
I don't know what to do and i'm fed up with skype seriously and i sent many feedbacks and I was ignored
I tried everything like my firewall, uninstall, quit, restart rooter and i'm using ''Vista''
I'm telling you this because i'm very upset about skype not working,,so WOULD you PLEASE help me with this ASAP
Thanx:))
Posted on Sep 25, 2008
Pl go to computer oip icon will be displayed right click presson autoplay it will say interference by other device press ok you are in business all the best ramram
Posted on Oct 07, 2007
SOURCE:
VOIP 321 will not work with Windows 7
VOIP 321 is working with windows 7. Install the Vista Software. After that you change compatility under properties (right mouse klick) to windws vista and it works fine regards kurt
Sep 08, 2009 | Philips DECT VOIP-321 cordless telephone
I got VOIP 321 This devise is not connecting with skype. The phone kept showing unavailable. I can still use the VOIP 321 as a normal phone but I use more for the skype!! Please help
From what I'm reading on various forums, this is a very common problem. I would call the retailer you purchased it from and ask for support. It sounds like it worked fine with ver 3.8, but many problems with Skype's new ver 4.0. If you can't get it to work, ask for a refund and look at RTX's DualPhone as I'm seeing good reviews!
Jul 30, 2009 | Philips VOIP3212 IP Wireless Phone
Philips 321 voip phone, problem calling out with skype
some things to consider
Have you topped up credit on skype?
dialing code correct uk +44, mobile number +447958475236 ect?
if this does not work look in your manual and reset your phone and try again
regards
Muzzi_123
Apr 04, 2009 | Philips DECT VOIP-321 cordless telephone
Vtec 7100 won't connect to skype
1. Unplug and re-plug the usb cable from the base station to your Skype computer.
2. Make sure Skype is running.
3. Re-install the vtech software (you can download it at http://www.vtechphones.com if you need to)
4. When Skype asks if it's ok to let it connect, do that.
Apr 04, 2009 | Vtech CS5111-2 Twin Phone
Trying to use VOIP-321 with a Belkin Networked USB hub
Fallonje good afternoon,
I wonder if you have a USB port on your computer? If yes, pls plug the VOIP321 into that port. Does it work?
What is the Belkin hub called networked?
Let me know. Many regards, Fred
Feb 12, 2009 | Philips DECT VOIP-321 cordless telephone
Philips 321 voip problem
If you are using this phone with skype and you can't call out and you can't hear when someone calls out, the skype isn't configured properly to use the philips 321.
http://www.p4c.philips.com/files/v/voip3211s_79/voip3211s_79_dfu_eng.pdf
User manual available on above link.
Jan 19, 2009 | Philips VOIP3212 IP Wireless Phone
Contacts unavailable
I have the same problem but what i did is to ru my XP in safe mode with networking and saw that is working ok.
after that, i just locked on which services are working on normal mode and not shown on safe mode.
found the service that was doing the problem (HP netwoking for my HP J6413 printer) and now working on some way to make it load only after the skype and the driver loaded.
Oct 14, 2008 | Philips VOIP3212 IP Wireless Phone
Contact list not available on voip321 handset
Using Skype 3.8.0.180
Go to Menu-Tools-Options-Advanced and give your voip321 access to skype application.
I had the same problem, solved when I allowed the skype phone to access skype.
Cheers
Mar 23, 2008 | Philips DECT VOIP-321 cordless telephone
Trying to download driver for philips skype/land line phone
Click on the following link
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=AU&slg=ENG&cat=INTERNET_TELEPHONY_DEVICES_CA&sct=DUAL_PHONES_SU&grp=PHONES_GR&session=20080710232058_61.8.9.134&ctn=VOIP3211S/79&mid=Link_Software&hlt=Link_Software
Click download for the Vista Drivers. Download the driver to your desktop open the file to install the drivers. Reboot the computer
Plug the VoIP321 back into the computer.
Then on Skype go to Tools then Options.
Click on Advance and manage other programs access to Skype choose allow for the voip321.
Jan 13, 2008 | Computers & Internet
Philips VOIP3212 IP Wireless Phone Logo
505 people viewed this question
Top Philips Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
