Question about EliteGroup 741GX-M Motherboard
Power Saving Mode
Hello, My daughters PC has a weird issue. Video goes into power save mode shortly after post (about 10 seconds into Windows XP pro load screen). Here's what I've done so far. * Turned off all power saving features in bios and windows - no difference * Scanned for viruses etc. using several tools - none found * Ran memtest for 12 hours - no errors * Replaced power supply with a spare one I had - no difference * Reinstalled XP from scratch (fdisk) - no difference - worked for a couple of days I'm at a loss, the only thing left is the motherboard I think. Any ideas before I go and buy a new board? Thanks
    Brigadier General:
  • 6,966 Answers
Hi, Offhand, based on your post "...Reinstalled XP ...worked for a couple of days" apparently makes this a software issue and not a hardware problem (motherboard). What was the last software/application that you installed "after a couple of days" before the problem resurfaced? This might be the culprit. Alternately, this may be an automatic update issue with your drivers. Perhaps you can give it one more try and do again a clean/fresh install of Windows but this time turn off the auto updates and load the drivers only from the CD that came with the motherboard. Of course as my own daughter would say, "save yourself the trouble, a new one comes with 12 mos warranty." Hope this be of some help/idea. Post back how things turned up or should you need additional information. Good luck and kind regards.
Posted on Oct 01, 2007
SOURCE:
Xps 8700 five beeps and five beeps starts windows goes to power save mode
Sundeep B posted this July 2013 on the DELL.COM>Community>Support Forums>Desktop>Desktop General Hardware Forum
DEL5 beep error code indicates an issue with RTC power and indicates an issue with CMOS battery. You may try reseating CMOS battery. You may refer to Owner's Manual Here. The location of CMOS battery is as shown below :
The video cards mentioned by you should function properly, however, Dell has tested XPS 8700 only with following video cards :
  • nVidia GeForce GTX 660 GTX 645 GTX 650Ti GTX 660
  • AMD Radeon HD 7570 HD8870
Dec 10, 2014 | Dell XPS 8700 Desktop - Windows 7
Hi. I have a FLATRON W1934S computer. Every time I switch it on it says "power saving Mode". How can I fix it?
Hello, I didn't understand the problem.
1.After switch on and it goes to power saving mode , which can be visibly seen by changing the color of power led from green9or blue) to yellow.
First thing to be done is when it goes to that state "power saving mode" remove the video VGA cabl , and if the unit gives video message "no video signal" which stays for a while and usually goes again to power saving mode , this is OK,
So if there is no video signal on input it should work like this. so you have to check you PC.
Another way is to use laptop or other PC to check the monitor itself.
Hope this helps a bit
Oct 29, 2014 | Computers & Internet
Monitor stuck in safe power mode
"Power Save Mode" but it tells you to press a key or whatever?
were you able to reboot the PC?
if you can reboot the PC but no screen is showing up during Windows load (you can see the hard drive activity LED lighting up and your hard drive spinning), then, youre probably have a broken monitor.
Or if your problem is you cannot wake from power saving mode (after your PC goes to sleep, then its probably just the driver for your video card). VISTA has some issues with certain drivers that the PC cannot wake from sleep. http://www.ezsystemrepairs.com/
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_70466cb634a57543
Jul 01, 2012 | Dell Computers & Internet
My laptop moniter turns on as usual with the proper reading. I start in safe mode as normal..wait about 10 min and screen goes white
hello
"I start in safe mode as normal."
safe mode is not a normal thing during your windows boot sequence :)
if your display works ok until those 10 minutes of safe mode are over i would say that reinstalling your windows operating system will most likely solve your monitor issues :)
Mar 24, 2010 | Princeton Digital LCD17 17" Flat Panel LCD...
I have a dell desktop that my buddy drought to me and I was gonna put a new windows xp os on it and the monitor will turn on then goes into power saving mode??
replug your cables and wirings inside your CPU, if your using a Video card and it goes power saving mode, use the on-board video card if you have, if you dont have try using another video card to isolate the problem.
Feb 24, 2010 | SVA-USA 9005S Monitor
Dell screen (1901FP) won't come out of power saver mode
hold down the Fn and F8 keys, and it worked fine for me. or if your problem is you cannot wake from power saving mode (after your PC goes to sleep, then its probably just the driver for your video card). VISTA has some issues with certain drivers that the PC cannot wake from sleep
Sep 24, 2009 | Dell 1901FPt 19" TFT LCD Flat Panel...
Monitor warning pc enter power saving mode
Are you using usb keyboard and muse. if so your usb ports are dead
Jun 16, 2009 | HP Pavilion a450n PC Desktop
Monitor automatically clicks into power saving mode
check the primary settings for your default video card.
Jun 08, 2008 | Dell Dimension 4600 PC Desktop
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
Flatron L1719S
I think your monitor is unstable. Is it showing power saving when you boot your PC? Does it show something when the Windows XP splash appears?
Jun 05, 2007 | LG Flatron L1750S 17" LCD Monitor
EliteGroup 741GX-M Motherboard Logo
50 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
