Question about RCA TH101 MP3 Player
MP3 Won't Add, Delete, or Play.
Well, my mp3 player worked wonderfully for so long. Recently, I've tried to put songs on it, but it won't let me. When I go to open the "music" folder on it, it does one of two things, it either tells me to insert something into the drive (which obviously I have already) or it does open miraculously. If it does open, I cannot delete any of the files or copy new files onto it. When that happens, I always get the same error message. "Cannot (delete/copy to/etc.). Parameter is incorrect." I have no clue what that means. When I turn my mp3 player on, it says there are no files on it, but if I go into the memory space in the menu, it says I have 1.2 out of 1.5 mb filled.
  • pathfinder97 Dec 24, 2007
    my mp3 player says no file an if i check in on my computer it has lots of music
5 Suggested Answers
SOURCE:
SOURCE: Mp3 player won't let me add or delete files
Hi, well these MP3 players can b real finicky. what you could try first is to Uninstall the program & drivers, and then re-insert the MP3 into ANY OTHER USB port but the one it was in.. and when/if it detects it, point it to the driver CD and reload them.. At this point ya may be OK... If NOT, then perhaps ya MP3 player has gone faulty.. they seem to go toes up for no reason? I have seen lots at my shop.. Another thing to try, is a Format of the device... Ya will lose all ya data tho :( not the best option.. but it may be ya only other option, after ya tried all the rest. To do so folllow the instructions in ya manual. Good Luck.
Posted on Aug 03, 2007
HulkSmashNow
  • 5 Answers
SOURCE: how do i delete songs
My suggestion is switching the file transfer protocol from MTP to MSC by accessing it under the Menu. Once you do this, when the Lyra is plugged into the computer, it will appear as an external hard drive. Format the hard drive and then drag and drop your songs and/or directories of songs onto the Lyra. This is what I do, as I never use Rhapsody, URGE, or even Windows Media Player or MusicMatch to upload songs onto my RD2763. Hope this helps!
Posted on Aug 30, 2007
sandrew
  • 2961 Answers
SOURCE: deleting music files
you should be able to explore your mp3 player in my computer, and explore each folder but when the windows are open click at the top files, options, view and select show hidden files as the mp3 songs already on the player may be hidden.
Posted on Sep 09, 2007
  • 37 Answers
SOURCE: i can not add or delete files/songs on my mp3 rca5200
FIRST OF ALL CHANGE YOUR FILE ATTIBUTES. IT MIGHT BE READ-ONLY. YOU CAN CHECK THE ATTRIBUTES BY RGHT CLICKING ON A PARTICULAR FILE AND GO TO PROPERTIES. NOW UN-TICK THE READ-ONLY ATTRIBUTES AND CLICK OK.
NOW YOUR PROBLEM MUST SOLVED. IF THE PROBLEM STILL EXIST JUST PUT YOUR MEMORY CARD INTO A CARD READER AND THEN YOU CAN ADD OR DELETE SONGS EASILY.
MOST OF PEOPLE USESIS A CARD READER FOR A SPEEDY FILE TRANSFER BETWEEN YOUR MEMORY CARD AND A LAPTOP.
HOPE THIS SOLUTIONS HELPS U.
PLS. RATE MY SOLUTION.
NICE DAY.
KETAN.
Posted on Feb 17, 2009
If we add songs to mp 3 player it won`t show songs when it on
MP3 players can only play music files that have been converted to mp3 file format. For instructions on converting music file, please click on this link and follow my instructions :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Nov 08, 2010 | Sony NW-E405 MP3 Player
Cant play back tracks no data
Did you add songs to it yet? To add songs to it plug it in the your computer and import the songs to it. If it still won`t work rebuild your data base. Doing so well factory reset your Walkman and fix any bugs in your Walkman.
Jul 17, 2010 | Sony Network Walkman NW-E005 MP3 Player
My Sansa Fuze won t recognize certain songs
you need to check the format the songs are in, try putting them in mp3 format
Mar 28, 2010 | SanDisk Sansa Fuze MP3 Player
File Format Not Supported
The songs that you recently tried to add were either from: iTunes, DRM-protected WMA's, or songs with expired licenses - none of which will play on your Philips. Go ahead and delete the non-working songs off of your GoGear. When you re-rip the songs from CD, move the mouse over the Rip tab in Windows Media Player 11, click the black arrow under the word Rip, and go to Rip Options --> Format --> Mp3. Now, re-rip and then reload the songs.
-Tha Mp3 Doctor
Jan 31, 2009 | Philips GoGear Flash MP3 Player
Mp3 won''t work
I've never heard of audio CD being block before from playback. Try this:
Reset your Ipod back to factory settings.
Drag and drop your songs from Itunes into your player. Do not use playlists.
Playback the songs from Itunes using the Ipod player as the file location. If playback is working, undock you Ipod from the computer and play again using the MP3 player.
Dec 02, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Can't delete songs
i had a problem like that once all you have to do is format your mp3 player go into media player under the sync tab and click format only problem is that you have to put all your songs back on it again
Jan 02, 2008 | Memorex MMP8565 MP3 Player
Corrupted files
all i can say is try to format the mp3
Aug 06, 2007 | SanDisk Sansa e250 MP3 Player
I need to delete music off my mp3 player
YOUR NOT GOING TO HAVE THE OPTION ON THE MP3 PLAYER, YOU WILL HAVE THE OPTION WHEN YOU LOAD IT TO THE COPUTER. ALL YOU HAVE TO DO IS RIGHT CLICK ON THE SONGS THAT YOU WANT REMOVED AND SELECT DELETE. I HOPE THAT WORKS FOR YOU. THE IPOD ISSUE I HAVE NOT CLUE SORRY
Apr 05, 2007 | SanDisk Sansa c140 MP3 Player
Please Help: Im Desperate!
hmm... try hooking it up to the pc, go to my computer find the mp3 click explore go to music and select it all and delete it then try again it might help
Mar 20, 2007 | SanDisk Sansa c140 MP3 Player
Won't play the songs i put into my sansa e250
You might have to take the product back because you might of corrupted it. I corrupted mine just recently and I had the same problem. If you decide to get another one, don't unplug the MP3 before it's done saving.
Jan 10, 2007 | SanDisk Sansa e250 MP3 Player
RCA TH101 MP3 Player Logo
49 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
