When I embroider on my BabyLock Ellageo, it pulls ups several bobbin threads at once, snarling underneath my project and ruining it. I'm not sure if it's related or not, but there's also several times when the top threads are loose and has a bumpy texture. I'm using Robison-Anton rayon thread on flour sack towels, with a ligthweight Sulky tear-away stabilizer.I've just had my machine and embroidery unit serviced, in the hopes it would correct this problem, to no avail. I've done severals sets of these days-of-the week towels, and the problem gets worse as I embroider more.
My Babylock Esante is shredding the upper thread when I'm embroidering (it broke 15+ times during a simple 3 letter monogram). This only happens when I'm embroidering- it sews like a dream otherwise. I re-hooped material, used tear away stabilizer, and Sulky thread.My Babylock Esante is shredding the upper thread when I'm embroidering (it broke 15+ times during a simple 3 letter monogram). This only happens when I'm embroidering- it sews like a dream otherwise. I re-hooped material, used tear away stabilizer, and Sulky thread.
AnonymousMar 16, 2014
I recently had my machine serviced.I recently had my machine serviced.
Are you using an embroidery needle? Such as #80 ballpoint. Also, what type of material are you monograming? Check out u-tube on how to embroider towels, you'll be surprised...no hooping!Are you using an embroidery needle? Such as #80 ballpoint. Also, what type of material are you monograming? Check out u-tube on how to embroider towels, you'll be surprised...no hooping!
You can't post conmments that contain an email address.
This is true. However, there are genertic ones that can be a substitute and work just as well. If it looks the same, measures the same then it will work and cost alot less!This is true. However, there are genertic ones that can be a substitute and work just as well. If it looks the same, measures the same then it will work and cost alot less!
I find the seller of the genertic bobbins will state in their ad if it fits your machine.I find the seller of the genertic bobbins will state in their ad if it fits your machine.
I took my machine and embroidery unit to a BabyLock dealer, and the service man said I'm using the wrong bobbin - I was using a bobbin engineered for a Singer sewing machine, and my BabyLock uses the more expensive, hard-to-find other kind.
Just buy the bobbins for the machine you have, what price a ruined project or hours of frustration ?Just buy the bobbins for the machine you have, what price a ruined project or hours of frustration ?
The Baby Lock Ellageo embroidery machine doesn't have a reset switch, but you can try the following steps to troubleshoot the issue:
Turn off the machine and unplug it from the power source for a few minutes.
Plug the machine back in and turn it on.
Check the power cord and make sure it's properly connected.
Check the fuse and replace it if necessary.
Check the embroidery hoop and make sure it's properly attached.
Check the bobbin and thread and make sure they're properly inserted and tensioned.
If none of these steps work, it may be a problem with the machine's electronics, and you may need to take it to a Baby Lock authorized dealer for repair.
Been there... Most often was due to improper tension settings and the threading of the machine. If it does it all the time double check your threading technique is actually the proper method. Thought I knoew what I was doing only to realize I didn't have the thread properly run through the guides. Makes a big difference. Also helps to use a heavy backing material. Some materails just embroider like junk. For terry cloth I use a thin clear material over the top to keep the small loops from messing things up besides a heavy backing. Could also benefit from an adhesive spray for cloth along with a heavy backing to keep material from moving on you. I have had to debug my wife's embroidery over the years and this is what has worked for us.
Just an FYI-the bobbin thread needs to
match your top thread. The majority of the thread that appears in the
top of your embroidery actually IS the bobbin thread. The machine is
working correctly. Don't use a bobbin full of white thread-instead,
thread a bobbin with the color your doing the embroidery work in to
match and you will have a perfectly beautiful embroidery.
It's okay - it's supposed to do that! The Needle Down button has a different function when you are in Embroidery mode i.e. you have the emb. unit attached. It moves the emb. arm forward for two reasons: so you can cut top-side jump stitches more easily between colour changes (you touch the button again and the emb. arm returns to under the needle so you can finish the design); and secondly so you can "park" the embroidery unit when you are finished. You can then turn the machine off, remove the emb. unit and replace it in the carry case. If you DON'T do this, the emb. arm is not in the right position to fit into the moulded carry case properly.
The Broken Thread message usually means that it has started the colour, but the thread has been pulled down underneath instead of making nice locked stitches. Hold onto the thread end until the machine has stopped and beeped for you to cut the thread. This usually solves that problem. Sometimes the thread gets pulled out of your hand so just back up the stitches a few and start over, holding the thread more tightly. Don't tug on the thread - just keep a firm grip.
Designer 1s often cut the bobbin thread too short so that it can't make those nice locked stitches when it starts. You need to take off the hoop, open up the bobbin cover and use your stylus, the tip of a pair of scissors, tweezers (whatever is to hand) to pull the bobbin thread out a little. Instead of cutting it on the bobbin thread cutter, just let it hang outside by 1/8" or so. That way you can be sure there is enough bobbin thread available for the stitch to lock. Don't use the scissors button on the machine after every colour change. Sure, it makes for a tidier back of the embroidery with less work for you afterwards, but if it means you are taking the hoop and bobbin cover off after every colour change then it is not worth it in time-saving. If your machine is doing this - cutting the bobbin thread too short - mention it to your tech. when you machine goes in for its next service. He may be able to tweak the bobbin cutter so it does not cut so close.
Hi, and welcome to FixYa. If I understand your problem, the needle goes in and out of your fabric, and the embroidery hoop moves, but the machine does not actually start embroidering your design right away....did I get it right? If have time to answer a few questions, I can give more accurate instructions.
How long have you had your machine?
How long have you been doing machine embroidery?
Do you have a manual for your machine?
Look at the back side of your design - do you see lots of bobbin thread, or hardly any?
Have you taken lessons for your machine or for embroidery?
When your design is finished, can you where the machine skipped stitches?
Here a couple of things you can try (if you have already):
Make sure you use an embroidery needle, not a universal. In most cases, you should use a size 90. Change your needle after each project. A blunt need can cause your machine to skip embroidery stitches anywhere in the design.
Rewind or replace your bobbin. Make sure you use bobbin thread in your bobbin when you embroider - it is thinner and gives you better tension. If pre-wound embroidery bobbins are compatible with your machine, I recommend that you try one and compare the result with designs sewn using the bobbin thread you've been using.
Normally, you should loosen your tension a little bit when you embroider. When you look at the back side of your embroidery, you should see more bobbin thread than embroidery thread.
I owned an embroidery business for several years, and I have six different embroidery machines of my own - so with a little more info from you, I think I can help.
YIKES - what a nightmare! We can approach your problem two ways, but to determine whether the problem is your machine or your design, I need to know if you have been using one design, or if you've tried to embroidery several different designs and are getting threadbreaks about every 10,000 stitches, no matter what design, needle, thread, and bobbin you use.
Here are some rules you should following whenever you embroider on your machine:
Change your needle and insert a newly wound bobbin every time you start a new project
Use a size Embroidery Needle - size 90 for most projects
Check the backside of your design - you should see alot more bobbin
thread than embroidery thread. If you don't see enough bobbin thread,
loosen your top tension. If the tension is set automatically, change it
manually.
Your design might be the problem. Some designs have WAY to many
stitches. If you haven't already, choose several different designs with
different styles - for example, a monogram, a design that is mostly
satin stitches, a design that is mostly straight stitches, and so on. Sew one or all over and over so you determine whether your thread will continue to break about every 10,000 stitches.
I hope this helps. Machine embroidery is so much fun once you've learned and practiced. I hope to hear from you - machine embroidery is not hard to learn, but there is a lot to learn. Thanks.
If you want to get right to work, skip the troubleshooting and answer as many questions as you can or have time for. It is possible that your problem is the design and not the machine. Try one suggestion at time so you what helps and what doesn't. Questions first:
Is the machine brand new, or new to you?
Do you have your manual?
Do you been embroidering by machine for a while, or are you just learning?
Does this problem occur with every design you sew, or is it one particular design that you are having trouble with?
How many total stitches are in the design you are trying ot sew?
What kind of thread are you using (rayon, poly, sewing?)
Did you buy the machine from a dealer, and if so, does it have a warranty?
Have you taken lessons on how to use your machine for both sewing and embroidery?
Are you familiar with embroidery backings, needles, and threads and how to choose which to use for a particular project?
You probably are in need of a new bobbin case they are plastic and oif you have broken a needle lately it may have gouged the case and the top thread is getting caught and bunching up underneath. Visit www.stevessewandvac.com you can contact them and have a bobbin case sent to you.
