Question about LG WM-2277HW Front Load Washer
LG WM2233H Washer
Filling the soap dispneser, in particular the BLEACH dispenser and doing a load of wash the BLEACH dispenser does not empty. Therefore do a whash of whites with bleach and follow with color load, the color load is destroyed. Does anyone have an idea? Thanks for the help
  • 2 more comments
  • Anonymous Nov 17, 2008
    I have the same problem with the bleach. I have destroyed several color loads because of this problem. Also, my detergent dispenser is filled with water after every load. Irritating to have to dump the water after spending $2500.
    I have the same problem with the bleach dispenser. I have destoyed a few colored loads because of the problem. Also have a problem with the laundry soap dispenser. The water never drains from it, so I have to empty it out into the washer in order to start my next load. Irritating.
  • Anonymous Mar 16, 2014
    LG Tromm Washer bleach dispenser not emptying
  • Anonymous Mar 20, 2014
    Soap not leaving dispenser
  • 69 Answers
Most likely the small electric motor that moves the water injection pipe on to the various outlet mainifolds has stripped its plastic gears, afraid the only solution is a new soap dispsener assembly
Posted on Oct 01, 2007
SOURCE:
WATER & SOME OF THE BLEACH DOES NOT DRAIN FROM THE BLEACH COMPARTMENT AFTER EACH WASH? HAVING TO PULL DRAWER OUT & EMPTY REMAINING BLEACH & WATER EACH TIME BEFORE NEXT USE. WHAT CAN BE DONE?
Your washer is designed to purge the bleach dispenser between loads. For example, if changing from bleach to no bleach. The residue is normal.
Apr 27, 2016 | LG WM2487H Front Load Washer
The bleach dispenser keeps filling up with water (I am not using it) and I don't know how to empty it - and why is it filling up?
You have a leaking water valve that dispenses water into the bleach cup. You will need to replace the water valve to stop this problem.
Good luck
Jul 08, 2011 | LG WM2487H Front Load Washer
Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
Jul 20, 2009 | Washing Machines
Bleach Dispenser not relaesing bleach during cycle
I have the same model # and same problem!!!
Worked fine for few months and then it started.
Sears technicians came twice but couldn't fix the problem. Now they have ordered a new dispenser door. Sears said they changed the design. Will see if the new door will work. Hope that helps.
Jan 12, 2009 | LG WM2455 Front Load Washer
Whirlpool duet empties soap, bleach and fabbice softener as soon
soaps goes right in normal, bleach and fabric softer you can't go past max line line it will dispense."less soap plz"
Nov 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bleach not always being emptied, bleach marks on clothes, bleach sometimes runs right out when you fill it.
The dispenser works on a siphon principal. If you over fill the cup it will start the siphon and empty before it should. If that's happening you're using way too much. You only need about a tablespoon of soap, softner and bleach for a full load.
Aug 11, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROM STEAM WASHER-WM2487 HRM
You are probably using too much soap and softner. You only need about 1 Tablespoon of each for a full load with a front load machine. Run it with nothing it in except bleach. If you see bubbles inside that means there's left over soap in the tub. Keep running it empty (with bleach) until you don't see bubbles anymore then start using less soap and softner.
Jul 31, 2008 | LG WD-14124RD Front Load Washer / Dryer
Smell on towels
It's good that you are using HE detergent but you're probably using way too much. To test this run the washer empty (no soap) and if you see bubbles inside that's left over soap that's still in the unit. If so, keep running it empty until the bubbles are gone then start using only about 1 tablespoon of soap per load. The washer uses about 1/10 of the water so you need to use 1/10 of the soap. Use the same amount of softner. The excess soap and softner build up in the unit and cause the smell.
Jan 18, 2008 | LG WM-2277HW Front Load Washer
Bleach dispenser
This compartment works on syphon action caused by the water when filling, rmove syphon cover on dispenser bos or try pooring boiling water into compartment, this will usually resolve
Dec 09, 2007 | Maytag Neptune MAH5500B Front Load Washer
LG WM-2277HW Front Load Washer Logo
779 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
