Hi. I am a pro photographer with a Sunpak TR-2000 for Canon flash pack. Quite suddenly, the 7.2v battery pack will not charge past the first green dot of the five diodes. When I plug it in to charge, instead of getting a red or green charge light, I get an orange light that blinks 11 times, pauses, then blinks 11 times, etc. I don't know if my battery is bad, or charger itself is pad of what to do t fix it. I need it for a wedding shoot FAST and don't have the $$$ for a new flash pack. Any help?
SOURCE: sunpak pz 4000af for minolta
The Alpha 100 only supports pre-flash TTL and ADI flash control which are not supported by the Sunpak. The flash should ignite, but automatic controlling of its brightness is not possible.
For more Information about the different Minolta/Sony Flash Metering modes cf. http://www.mhohner.de/sony-minolta/flashcomp_mm.php
SOURCE: NiCad battery not charging
the charger adapter that plugs into the battery pac from the wall has a fuse inside it open it uo and check the fuse has not blown as that's normally the reason i get no light on the pac also using a small enough file clean off all the terminals and check that the spring terminals contacting the circuit board from the plug are not corroded and contacting correctly
SOURCE: How does the Sunpak Auto
When internal cells are fully charged it do not need external ones
http://www.photographyreview.com/mfr/sunpak/flashes/PRD_84012_3121crx.aspx
SOURCE: I'm using a sunpak battery
Check.. Make shure your battery is good ....and check our power supply if is charging also the pin on the connection itself ....
