Question about Motorola Mobility H700 Wireless Headset
Headset won't connect, even after pairing
I have followed the manufacturer's directions (several times) for pairing the H700 with the Motorola Razr V3, but still can't connect. I've had the H700 about 30 days. It worked well at first, then sporadically. Now the phone recognizes it during pairing and offers to bond, and I select "yes, " give the pin which it recognizes. After that it fails to recognize the H700 and says "can't connect." I took both devices to my local cell store and they couldn't make it connect either. Apparently I can't return it to the place I ordered it from because I no longer have the original packaging. I mayt be able to send it to Motorola for a replacement, but first I thought I'd see if you had any suggestions.
  • IceManNYR Feb 01, 2008
    I have the sane problem. I bought the H700 on Monday and now on Friday the phone sees it and turns the BlueTooth light on the phone on but refuses to connect to the H700..
I was also frustrated by this problem and i found that after recharging the h700 it worked. my phone always locates the headset but if its low on power it will not connect.
Posted on Jul 02, 2008
I'm having the same problem except my message says "seeking motorola h700" and keeps seeking until the h700 goes into powersave mode. I called motorola support and they told me to take it in for repairs( at my cost cuz the warranty is over). I've only used the h700 a handfull of times( I bought it more for optional convienience). I've got to say I'm pretty dissapointed with the durability with this product.
Posted on Oct 08, 2007
SOURCE:
Passcode
The Motorola H700 has Bluetooth v1.2 which is backward compatible with v1.1. The headset works with both Hands-free and Headset profiles and is easy to pair with devices running various operating systems and software. We tested the headset with the Motorola SLVR, Palm Treo 650, the Nokia 9500, the Cingular 8125 and the Cingular 2125, and the headset paired with all devices with ease. To pair the Motorola, turn off the headset first then hold the Call button until the LED ring turns purple, quickly open the boom so that the LED stays solid purple, the headset is now in pairing mode. Use your mobile phone to discover and pair with the headset using “0000” as the default pass code. Call handling between the phone and the headset transferred smoothly and the headset will play notification or a ring tone when a call comes in. When working with the Treo 650, the H700 has an uncomfortably long delay in notifying an incoming call. It starts to ring after the Treo 650 has already ringed 2-3 times. The connection between the phone and the headset is solid. When we paired the Treo 650 to both the Motorola H700 and the Parrot 322 car kit, we can pick up calls on either one and the Motorola H700 worked reliably in this set up.
Hope I helped Dr Reed
Apr 06, 2010 | Motorola Mobility H700 Wireless Headset
Problem with Blackberry Pearl 8100
Did you try deleting all devices paired and then try pairing again?
May 20, 2008 | Motorola Mobility H700 Wireless Headset
Pairing
The same way you did to your Razr. Make sure the H700s microphone are is in the off position. Push in and hold the button on the H700 until the light lights up purple. Release the button and quickly open the microphone button. The light will stay purple and you are now in "Pairing Mode". Now follow the instructions for your phone to pair with a BlueTooth unit. When it asks for a code, use 0000 (that is 4 zeros).
Oct 26, 2007 | Motorola Mobility H700 Wireless Headset
Motorola H700 Problems with BB Pearl 8100
Steps to pair a H700 headset with any bleutooth pone:
  1. Make sure the H700 fully chared (very important)!!
  2. Make sure the microphone boom is folded closed, i.e. power is off!
  3. Hold the call button for 1-5 seconds until the light is steady lit purple
  4. Flip out the microphone boom, the light should stay lit purple!
Now you are ready to pair the headset with your phone, so follow the pairing instructions of your phone.
Note: When prompted for the Passkey; it is most likely 0000 but the correct Passkey should be on the headset accessory instructions.
I must add that indeed my headset on occation (once or twice every three months) also loses its connection with the blackberry (a 8703e) . At which time I have to remove the headset from my phone bluetooth device list, and start the above described steps to pair my headset with the phone again.
Jun 02, 2007 | Motorola Mobility H700 Wireless Headset
Place the unit headset back in pairing mode by holding the call button for 1 to 5 seconds until the light turns purple. Then open the boom. Then try to reconnect .
Apr 19, 2007 | Motorola Mobility H700 Wireless Headset
Trouble connecting h700 to phone
First: When charging the light should be steady. If the battery is less than 20% charged it should be red. More than 20% it will be yellow. Fully charged it should be green. Make sure your microphone is closed when charging.
Second: Have you "Paired" the H700 and the phone? If not you need to. To put the H700 into "Pairing Mode" do this:
Your phone and H700 should now be connected.
Hope this helps a bunch!!!
Jan 04, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
151 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
