Question about JVC HR-S3901 S-VHS VCR
Loud noise on rewind
I've had a JVC HR-S3901/3911U VCR for a few years now and have had no problems, but last week, I went to rewind a tape (without the video playing), and when it went to go into the high rewind speed, it made a horrible grinding/clicking sound, and then went down to the slow rewind speed so that it takes almost 10 minutes to rewind an hour of tape. I thought it was the tape, but I tried three different tapes, and the same thing happened. It plays and records fine, and rewinds and FF in the slow speed without problems. Tonight, I took it apart, and saw that the same thing happens on fast-forward too, except the tape reels don't move at all, and then it makes the loud noise and the machine shuts itself off. I couldn't figure out what the problem is. Does anyone have any ideas? I'm sure this could turn into a bigger problem if it's not fixed. Thanks!
  • Anonymous Jan 03, 2009
    I have this same problem where the machine makes loud noises in the fast rewind mode. I took it apart and found a spring loose in the bottom of the machine. Does anyone know where it goes? The spring is shaped like a V. Coil with one straight leg and one with a 90 degree bend at the end.
    Thanks,
    David Long
  • pelican810 Jan 03, 2009
    I have the same problem where it makes the grinding noise in the fast rewind mode and then goes into the slow rewind mode. I took it apart and found a loose spring. The spring is shaped like a V. A coil with two legs; one straight and one with a 90 degree bend at the end. Does anyone know where the spring goes?
    Thanks,
    David Long
    Novelist:
    Champion:
  • 254 Answers
You may have an idler gear wheel which has been damaged- perhaps broken/worn gear teeth or something afoul in it's drive mechanisms. Check this idler which sits down in between the supply and take-up spindles. You should be able to see this with no tape loaded. This idler should also move freely from supply to takeup- if it is sticky in movement this could be the problem. If your idler is broken, you may be able to replace it. Check with a service center- or a parts supplier. MCM electronics is one such supplier- there are others.
Posted on Oct 02, 2007
Looking to have the machine rewind then record.... daily.. does it have this feature... I cannot find it....
Hi
I do not know of any vcr that will do this. The timer can be set to record on each day of the week but will not rewind when the tape comes to the end there may be some cctv videos that might do this sorry I donot know Make or Mod No
regards windyhouse
Sep 08, 2010 | JVC HR-S9600 S-VHS VCR
JVC VRC MACHINE HR-S7965 Rewind/fastforward cog slip noise
maybe a broken break band on reel supply (left one) in the vcr !!!
Apr 22, 2010 | JVC HR-J461MS VHS VCR
Repeat recording 5x week for same show
Found the solution in the on-line manual, around p. 33. Thanks.
Aug 14, 2009 | JVC HR-XVC20U DVD Player/VCR
My RCA vcr makes noise when I fastforward or rewind
ADCON4035::
Whenever I had the problem with the "noisy spindles", I just find an old movie, damaged tape,etc but with a good [chassie] body. sometimes the spindles have too much leayway and flip-flop around.It may take more then one 'body' change, but it stops the noise when you find the right size.
May 22, 2009 | JVC HR-S3901 S-VHS VCR
Problem ejecting tapes getting stuck
The take up is not rewinding the tape all the way back into the shell. Check the idler, it's either worn or if it's plastic it is warped from the heat.
Feb 09, 2009 | JVC HR-S6600 S-VHS VCR
I have a HR-J625EA JVC VCR & video cannot be ejected.
this sounds like a sensor problem the vcr thinks the tape has been ejected and then turns off! this will cost more to fix then a new VCR!
Dec 08, 2008 | JVC HR-S9800 S-VHS VCR
JVC HR A62U VCR
I was wondering if you tryed unplugging vcr for an hour then
plugging it back up. sometimes this resits it and it will work fine.
the tape might eject itself out or eject button might work.
Nov 10, 2007 | JVC HR-A32 VHS VCR
Video tape gets eaten on rewind
Does the machine play tapes well? Clear steady picture and all? No tracking bars? wavering sound? Tape chewing is generally a problem with a bad Capstan Pinch Roller, Associated symptoms are as above. Please do recheck or confirm if any of the above problems are also present.
Aug 30, 2006 | JVC HR-VP650 VHS VCR
JVC HR-S3901 S-VHS VCR Logo
453 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
