Question about Maytag PAV2300 Top Load Washer
Washing machine my washing machine is level and it doesn't matter if we have a small load or a big load but my machine walks(vibrates) across the floor every single time. can you tell me how to fix it?
  • 1 more comment
  • beast93 Feb 10, 2008
    Big or small loads, the machine vibrates and walks. All the springs are in tact.
  • Anonymous Mar 02, 2008
    I have tried everything to level my Maytag, but it rocks and rolls and
    makes a racket on the spin cycle. Had the repairman out, he could
    not find anything wrong, said it was due to the extra heavy spin cycle.
  • ejaalsma Nov 19, 2008
    How Do I replace the snubber on this washer? I already have the checked the springs and found only pieces of the snubber.
    Thanks
    Jamie
    Scholar:
  • 116 Answers
Yes check the springs at the bottom of the machine securing the outer drum to the bottom of the casing.
Also check for excessive dust (plastic usually white) around the bottom of the machine indicating a worn snubber, the whole assembly sits on a saucer shaped plastic bearing or snubber, if this is worn it may cause your problem.
Posted on Apr 19, 2008
  • 57 Answers
You need to take the top off the washer and look at the surrounding springs that hold the basket in the center of the washer. Sounds like one of them is broken.
Posted on Oct 01, 2007
SOURCE:
Unit has VIBRATION REDUCTION TECHNOLOGY but it is walking across floor on spin cycle I have it level
The mounted transportscrews are not removed or a problem with a suspension bracket of the bowl.
Too heavy loaded
Jan 02, 2016 | Samsung WF210ANW 3.5 cu. ft. front load...
Vibrates then starts walking across floor
LG washing machines are very finicky with being leveled, they must be 100% level, and squared up on all sides. Be sure to lock the nuts in place, once you level it, to where it needs to be. They are also finicky with certain floor surfaces, more leveling may be required.
Mar 30, 2010 | LG WD-16115FD Front Load Washer
Washing machine walks
The problem MAY be fixed. I went to http://www.fixya.com/support/t14304-washing_machine_walks_across_floor , made sure shipping bolts were out, then discovered nuts that clamp the feet were loose. They are now tight with unit re-leveled. Testing is in progress.
Oct 28, 2009 | Kenmore HE2 Plus Front Load Washer
On the spin cycle my miele walks acrossed the floor
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 06, 2009 | Washing Machines
WHEN IT SPINS IT WILL WALK ACROSS THE FLOOR
the washer is not getting a balanced load need to adjust the clothes inside so it wont jog
Jun 02, 2009 | Washing Machines
Vibration during spin cycle - "walking" across floor
dear sir/mam
please check the floor level of your washer by using the spirit level,if there is difference please adjust the level by screwing the legs of the washer,then vibration will be stopped.
Jun 01, 2009 | Whirlpool Inglis IP4400 Washer
Washer shaking
first make sure the shipping bolts were removed from the machine, then make sure it is level, then if it still shakes, take your fist and hit it on your head... jk, if you have it on a wood floor, or your floor isnt 100% sturdy, you cant do anything about it besides using anti vibration pads. they wont do that much tho.
Feb 12, 2009 | LG WM-2077C Front Load Washer
Machine knocks and walks when spinning a small load
amke sure it is level and on a solid floor with little bounce.
Jan 23, 2009 | Admiral AAV7000A
Maytag front loader MAH-3 vibrates. Level & on concrete floor.
THERE ARE SHOCK ABSORBERS IN THIS UNIT,SOUNDS LIKE ONE OF THEM IS BROKEN.HOPE THIS HELPS
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
LG Intello Washer DD 7Kg. WD-1460FHD
did you remove the shipping bolts before you starting using it consult your owners manual under installation for location and removal procedures all washers have them to stabilize them during shipping
Jan 02, 2008 | Washing Machines
Maytag PAV2300 Top Load Washer Logo
120 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
