Question about Hitachi 50SBX78B 50" Rear Projection Television
Proscan television I go to turn it on and it wont come on. The power button will flash 3 times and thats it. No sound or picture
  • 3 more comments
  • sextynine Oct 05, 2007
    the service# PS52690LX1 and the chasis# PTK188AB
  • mike38 Jan 05, 2008
    i have unpluged it and that all
  • mgray9654 Feb 23, 2008
    have the same exact problem, just happened today. push power button, it will flash 3 times then nothing.
  • hendrickx Oct 10, 2008
    Have the same problem, no picture, no sound. push power button, blinks 3 times then nothing.
    Lamp replaced by repair man, solves the problem for 1 day, then again nothing.
    Ventilator + lamp replaced by same repair man, solves the problem for 1 day, then again nothing.
  • Anonymous Oct 22, 2008
    turn the tv on it flashes a few times then will shut it self off. no picture or sound.
    Genius:
  • 1,694 Answers
Please provide service number--sounds like common transformer failure---
Posted on Oct 01, 2007
  • Vista Electronics Oct 05, 2007
    transformer part # is 227853.
SOURCE:
I replaced the power supply unit on my 50" ProScan flat screen and now it wont even turn on just a clicking sound when you hit the power button.
The replacement power supply could have been installed incorrectly or may have been defective as received.
Nov 20, 2014 | Proscan Televison & Video
Proscan 32LB30QD TURN ON SOUND BUT NO PICTURE
Sounds like a bad inverter thats what powers up the backlights so you can see the picture on the screen. usually its about 85% of the times the inverter if you have pefect audio and remote functions but a black screen in a LCD modeel TV. You can get the inverter board from www.tvrepairworld.com
Jan 12, 2013 | Proscan 32LA30Q Television
TV POWERS ON, THEN BACK OFF
I could be anything but mostly it will be its age, and if its never been cleaned out it could be the bulb failed, power board. dust build up can cause over heating of the parts. even damage them if the dust becomes damp. is there any lights flashing or any leds lite up ?
Jul 09, 2017 | Proscan PS50700 50" Rear Projection...
Why would our proscan big screen just turn off and then not turn back on. Everything else has power. And also when we tried to unpluge the power cord on the back it sparked. Please help. --- model number...
I JUST GOT HOME AN TRIED TO TURN MY JVC PLASMA TV ON. THE TV WILL NOT TURN ON. EVERYTHING ELSE HAS POWER TO INCLUDE THE TV BUT THERE IS NO PICTURE OR SOUND. BLANK SCREEN. THE BLUE POWER LIGHT IS FLASHING ON AND OFF. THE MODEL NUMBER LT-42P789
Jul 16, 2009 | Proscan 19LA25Q 19 in. LCD Television
If i turn off my tv it wont turn back on
This problem is either the TV's software or how the mainboard is distributing power so instead of just unplugging the TV, try a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power/on-off button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
Since hardware either works or it doesn't, your issue is either software or power related since you can get it to work so hopefully the power drain will indicate further.
Mar 25, 2009 | Proscan PS36109 36" TV
My proscan is buzzing and pix is flickering when the power is on.
I found this solution on another review, hope it works
Model Number: Proscan 26" LCD HDTV w/ Built-in DVD Player26LB30QD "pro: good price, TV picture is clear and DVD player is compatible well.
con: sound noise
There was hum when I first turned the TV on, then I followed these instructions (found it from other review) to fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone."
It works,no hum."
Feb 26, 2009 | Proscan 42LA30H 42 in. LCD Television
ProScan 60 " Rear projection T.V..
power supply,safety protection has kicked in
Jun 23, 2008 | Proscan PS60690 60" Rear Projection...
Proscan 26LA30Q-screen will not turn on
This might help you
Proscan 19LA25Q 19" LCD HDTV at Crutchfield.com Proscan 19LA25Q 19' LCD HDTV: Detailed Info, Features and Specs, and Photos. ... Instruction Manual; Product Registration Card; Limited Warranty Card ...
www.crutchfield.com/ISEO-rgbtcspd/App/Product/Item/Main.aspx?i=68319LA25Q - 46k
Mar 30, 2008 | Proscan 19LA25Q 19 in. LCD Television
ProScan wont turn on
PS52690 52" projection TV (CTC188 series) that won't power up. From what I have read here and other places, the most common cause of this is the HV splitter. Actually, when the unit was 3 years old, the HV splitter went out and had to be replaced but it was under warranty at the time. I have found that the part I need is 205064 and runs around $40-$70
A post in another thread said that you could test to see if the HV splitter is really the problem by disconnecting the HV anode (big red wire) from the flyback (not the splitter since that will arc), plug the TV in, power it up, and if the power stays on and you hear sound, replace the HV splitter to fix the problem.
Dec 05, 2007 | Televison & Video
Proscan 27" tv
it is due to power supply failure. 1 check for loose contact in power supply. 2 it might be due to plug or socket loose. 3 switching circuit failure in power supply. good luck.
Oct 07, 2007 | Proscan PS27500 27" TV
Televison & Video Logo
62 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
