Question about Kodak EasyShare C300 Digital Camera
I can no longer take pictures.
When I have tried to use my camera(I've had it about 1 year now, without any problems)lately, a blue screen comes on and says:date and time have been reset/set date and time or cancel. The led either turns black and stays that way, or it shows what you want to look at, but in either case, will not take a picture. Any clues???Thanks alot!
The date and time usually get reset when the batteries are removed or are going flat. the screen can sometimes be black when you turn your camera on but you just need to wait a few seconds and press the 'ok' button- that usually fixes it. as to not taking a picture is says how to fix that in the instruction manual (in mine anyway) so you can probably just refer to that.
Posted on Mar 28, 2008
SOURCE:
When I plug into the usb port to download pictures It shows MSDC on screen
You probably need eather a program or a driver installed in your computer. check your camera web site.
Oct 19, 2012 | Cobra Digital DCA1620
Blurry pictures, flash timing is off
do you use a lenz cleaner on the lenz of the camera
Dec 07, 2011 | Canon PowerShot A520 Digital Camera
My dad has a fuji finepix a500 camera. lately, he's noticed that some of the images on the screen are showing instead as a blue screen with "read error". how can we fix this/what has...
What happens on your camera is related to the pc modifying the image file, hence the camera can't read it as they use different formats to write and read the images.
Can you see the pictures stored on your father's camera on the PC? Because if that's not possible, then the camera has an internal problem and you might have to consider taking it to a repair shop, or even consider buying a new one.
Jul 12, 2011 | Cameras
Lately, I´ve been trying to
Do a soft reset on the phone by removing the battery. I know it sounds dumb but in many cases it works.
Dec 13, 2010 | Ericsson Cell Phones
Camera is 3 years old. Lately I take a picture
All the battery have a life time fixed working hours. Your battery is charged but he complete is working time. Thats why these msg will come. Dont warry use the battery when you see the power going down after a while of charging then change the battery and buy new 1. Good luck.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Canon Powershot SD450 / IXUS 55 Digital...
Blue screen access error when viewing or taking pics or vids
Please try to take as many pictures from memory stick as you can then format memory stick through format option in setup.
Hope this will resolve this blue access issue.
You can use another memory stick like 1GB in this camera.
Mar 13, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Toshiba Model 42HM66 DLP Projection TV
I strongly doubt it's the lamp assy since you can actually see the blue screen. If the lamp failed, you would not see anything on the screen. This blue screen indicates to me that either the tuner is no longer decoding the signal, in improper input has been selected (ie: input 1 is selected while actual signal is on composite 1), or something of that nature. If you are getting audio then the input is selected properly but the video decoder has failed.
If your cable signal is going through a VCR or DVD, disconnect it from there and go directly to the TV (ie: bypass the VCR/DVD). If your picture comes back, there's some kind of problem with your VCR/DVD player.
If you have multiple inputs, try connecting an input signal to another input (ie: video 1, or aux from a dvd player) and see if you get a picture there. If you do get a picture, the whatever input you're currently using has malfunctioned.
Mar 08, 2008 | Televison & Video
SAMSUNG SP-P4251 DISTORTED PICTURE AND THEN SCREEN GOES BLUE
Wow same here but mine is red I know its because of the plasma bulb is wearing out and for my fix is $1000 but I didn't do want to go on so I tried to change the color settings and tried RGB to all 0 and it became fine. Well at least you have a cool blue screen, mine is red.
Oct 29, 2007 | Samsung SP-P4251 42 in. Plasma EDTV
I get a blue screen and it says picture error
A camera that consistently causes errors on memory that worked before being installed is probably suffering from a board level issue. If the camera is under warranty I would definitely send it in to the manufacturer to be fixed. If it is out of warranty this is an extremely hard problem to track down, and probably would require a new circuit board which may very well cost as much as a new camera. It is possible that the problem lies with the connection between the camera's circuit board and the memory card slot. This is an option, but it is only one of many explanations all pertaining to the electronic components inside the camera. David Millier Advance Camera Repair
Feb 15, 2007 | Olympus FE-120 Digital Camera
Kodak EasyShare C300 Digital Camera Logo
55 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
