Question about Zanussi WJS1397W Front Load Washer / Dryer
Drum Bearings. I need to know how to replace the drum bearings on my WJS1397 washer/drier. As far as i can make out, this is a difficult job best left to proffessionals. However, money is not abundant at the moment (we will struggle to find the money for the part on its own!!!) and this isnt the first time ive ferteled with this washer, so i must do this job myself. Any help is appreciated.
  • 94 Answers
I recommend first of all ordering a repair manual. Or at least see if the parts come with detailed instructions on how to take out the old and install the new. You will probably have to replace the entire outer drum assembly. It's much more expensive in parts to do it that way than to just replace the bearings and seals, but much much easier and faster. Personally, I've replaced the entire drum assembly and also tried to replace just the bearings and seals. In the end I wasted the money on the bearings and seals and got an new assembly. I'd recommend just going for the new assembly and saving time.
Posted on Oct 01, 2007
SOURCE:
Bearing replacement
One of the biggest jobs to do on a washing machine. Remove the drum from the machine, remove the washer drum, knock out bearings, replace drum spider (shaft) fit the new bearings, and drum seal, put everything back together again. Job for a experienced engineer.
Oct 03, 2014 | Washing Machines
Hotpoint wma46 drum bearing failed
The drum sits on a shaft, just like the front wheel on a car. There are 2 bearings, one each side of the drum housing. Usually the inner bearing water seal fails and the bearings begin to rust, causing it to become noisy. Once the water is that far, its not long until the outer bearing goes. At some time in the process, you will begin to get a water leak from the rear of the drum that will get progressively worse.
You can change the bearings and I work with professionals who claim that they can have a drum out, bearings swapped and back in within 45 minutes. I've never got it down below an hour and a half on a machine I know well and you will need, if not SPECIAL tools, then a tool of some description to knock out the old bearings that are pressed into the drum. This is a job for the hardened DIY enthusiast and a pig of a job if you've never done it before.
Bearing sets cost (depending on the machine, the supplier and how many you buy) around £25 in the UK (About $40). Calling out a guy to do the job will easily quadruple that cost (He will probably come with a refurbished drum, swap it out and then take yours away to refurbish).
With this information, you now have to ask yourself if it's worth the effort on a machine that may be reaching end of life anyway.
Typically, the noise will get SCARY and the water leak annoying long before the machine actually fails to work. My advice would be take this as notice that your machine is about to go to the scrap yard in the sky and start looking for a replacement before it croaks on you at an inappropriate moment.
Jun 21, 2011 | Hotpoint WMA46 Front Load Washer
My partner's Hotpoint WT960 makes very loud grinding sound when spinning. I suspect the drum bearings are gazacked. Do I need to change the drum support and bearings & seal or just the bearings? Is it...
Hi Joe.
A lot depends on construction of drum.
Remove the top cover and look at the plastic outer container, if it is a one piece consonstruction, then unfortunately you cannot fit new bearings, as it it comes supplied as a complete unit.
However, if you can see the 2 drum halves held together with screws, then you can fit new bearings.
You will not know if the spider or drum shaft needs to be replaced until the it is stipped down, a fifty- fifty chance
It is an involved repair as it entails removing the whole container from the cabinet, and do not fit any other bearings than the genuine ones.
It comes as a bearing and seal kit from Hotpoint.
WWW.HOTPOINTSERVICE.CO.UK
Good luck
Dec 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
Noisy bearing while spinning
The seal in the drum has failed allowing water to leak into the bearings causing them to rust. Once the bearings are no longer round, the bearing noise will get louder. To replace, the washer needs to be taken apart and the drum needs to be removed in order to replace the bearings. Can be a difficult and expensive repair. Get a few estimates before deciding whether it is worth reparing. Sorry.
Oct 04, 2010 | Maytag Neptune Washer
It sounds like the drum bearing needs replaced it squeals lik, is
No, not usually, not that expensive as far as parts, can be time consumeing, but not a difficult job, check all the drum support rollers,bearings,bushings, slides what ever is used in your model.
Do a quick once over observation while in there, check belt, pulley, idler,etc., clean out fire causing lint and other foreign matter that shouldn't be there, and then you should be good to go for a while.
Good luck !
Jan 24, 2010 | Maytag Neptune MDE4000 Electric Dryer
Washer sounds like gears are grinding
you have defective washer drum bearings, very common on these front load washers, this is a very difficult job to replace these bearings, suggest you have a professional do the job for u....
Oct 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Drum bearings need replaced
you can try to replace just the bearings yourself .. big job but if you want to do it check out tonytool.
you can replace the entire drum assembly with bearings already in but the parts alone are over $500.
I have the same problem and will buy a new washer !
Jul 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Hotpoint wd420
if the drum is tight to turn ,then the main bearings have probably seized, or their could be something fast in the drum. Remove belt, and try to turn the drum by hand , it shuold be free with no resitance.
If it is noisy or feels rough, then the bearings have gone.
Sep 01, 2008 | Hotpoint Aquarius WD63 Front Load...
Basket on washer shakes
Try lifting the inner drum to check if there is any movement between the inner and outer drums, also turn the drum and listen for any grinding or scraping sound from the rear of the drum. Its possible that your bearings have gone out & need to be replaced. The job is far from easy.
Jun 17, 2008 | Washing Machines
Drum will not rotate
im confused as to why you think no drum rotation would be caused by bearings. typically worn bearings would cause noisy spin. only if bearings were completely seized would that cause no drum rotation. can you rotate drum by hand? if so bearings are not seized. can you hear motor rotate when you select spin? if not, then likely cause is motor brushes. do these simple tests and get back to me if you want. and bearings are quite difficult to replace on this machine
Apr 26, 2007 | Zanussi F1045W Front Load Washer
Zanussi WJS1397W Front Load Washer / Dryer Logo
141 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
