Question about NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive
Nexxtech 3.5" Hard Drive Enclosure (NHDE35)
Wiil this encloser work under Windows Vista? I'm thinking of buying it.
  • 3 more comments
  • Anonymous Apr 02, 2008
    My HP computer with vista will not operate my NEXXTECH 3.5 Harddrive or my harddrive from my old computer is damaged ?
  • AGALSGUY Jun 01, 2008
    MY Nexxtech 3.5" Hard Drive Enclosure (NHDE35) IS NOT BEING RECOGNIZED BY MY PC. WHEN I PLUG IN THE USB2 WIRE INTO USB2 PORT I GET MESSAGE THAT READS: "YOUR UNKNOWN DEVICE CAN PREFORM FASTER IF IT IS PLUGGED INTO A HIGH SPEED PORT." I AN USUNG A NEW PC WITH WINDOW VISTA HOME EDITION. SEEMS I CAN'T GET PC TORECOGNIZE IT REGARDLESS OF WHAT USB2 PORT I USE. CAN ANYONE HELP?
  • xpladox Dec 15, 2008
    I'm having the exact same issue with Vista. I turn on the Nexxtech and my computer will show a usb connection but seconds later it will disappear. This will continue on and on.
    With Windows XP I used to install everything that wasn't "certified for XP" and never had many problems. I guess this is a situation where when the man says it ain't for Vista......it ain't for Vista. Too bad.
    If anybody has an alternate solution I'd love to hear it........
  • Anonymous Dec 30, 2008
    I'm using Vista, and it's not working for me. I have the jumper set to master and when it is plugged in, it registers it with the device connected noise, then it disconnects it quickly.
    That's what I get for buying a 2nd rate product though.
  • Anonymous Jan 11, 2009
    not true.. it IS compatible with vista because my dad is running it on his vista machine. it works 100%, yet i am having that problem where it is set on master, and once connected, i hear the device connected noise and then the disconnect noise, this then continues to cycle until i power off the device
I'm not saying this will solve all problems, but it solved it for me. I am running Vista and got this to work following someone's instructions from another forum.
The slot in the enclosure that you plug the hard drive into has one set of holes fewer than the hard drive has pins. This means you can plug the hard drive in two ways "left" and "right" if you will. I had to plug my hard drive in so that the unused pins were farthest from the power cable that plugs into the hard drive.
Incidentally this made the screw holes line up better, too.
Posted on May 29, 2009
It is not compatible with windows vista.... i am tech support from nexxtech
Posted on Aug 30, 2008
    Problem Solver:
  • 8 Answers
Try setting the jumper on the HD (in the Nexxtech enclosure) to "master"...It worked for me!!!
Posted on Jul 22, 2008
I just bought one of these tonight, at first it didn't work but I did not put the jumper into the master slot, and then it read.
Using Vista Premium.
Posted on Jun 21, 2008
    Novelist:
    Champion:
  • 382 Answers
The enclosure will not have anything to do with an operating system. If the computer youre using utilizes USB, and you have USB drivers installed ( other USB devices work ), then there will be no issue, if the enclosure has USB. If the drive has firewire, and your computer has firewire, and you have the proper drivers installed, there should be no problem. Basically, you're asking a hardware question. The NHDE35 has usb2 ports. Vista supports USB2. If youre computer has USB ( which is backwards compatible ), it will be fully compatible. Hope this helps.
Posted on Oct 02, 2007
Kill Vista! Useless thing.
Posted on Oct 09, 2008
Finally obtained the proper cable to reconnect the NX2 Nexxtech devise with an enclosed 3.5" hard drive. The devise is not recognized and I can not access the external devise. Please advise.
Posted on Apr 08, 2010
  • fddicent Feb 27, 2011
    These enclosures have a tendency for the pcb that provides power to the drive to fail. I have one and the case powers on and the light comes on fine, but if you listen carefully or power it on while the case is open, the hard drive never powers on/spins up. Everything else appears to work fine and windows (xp) recognizes that a hard drive device is trying to install and it appears in device manager as a device w/out drivers installed. This is not the case in my situation and probably others. The hdd is not getting power. Period.
My Vista premium machine goes black whenever I plug this external hd into the usb. When I unplug it, it comes back up. I am using an HP laptop. I'd assume that Vista doesn't like this hardware.
Posted on Aug 26, 2008
Im using vista home and it is set as master, still not coming up at all although it automatically installed the drivers
Posted on Sep 05, 2008
I'm trying to implement it on a vista hp machine brand new with vista home premium and it is not functioning. Get a brand more reliable.
Posted on Dec 14, 2007
My Nexxtech nhde35 ext. hard drive is suddenly not working. Now when I plug it in, the indicator light alternately blinks red/blue. The PC does not see the drive at all. Tried swapping to another hard...
Seems most likely that the drive enclosure has failed, since swapping to a different HD made no difference. If so enclosure will have to be repaired, or replaced.
Jan 03, 2011 | NexxTech Portable Hi-Speed USB 2.0 Kit...
No install CD for NexxTech NHDE35
Apple MacOS 9, Apple MacOS X, Microsoft Windows 98SE/2000/ME/XP will support these If your using Vista It wont work, and no upload is available.
Apr 21, 2009 | Computers & Internet
NHDE35 Enclosure
Posted by Decoder1 on Feb 25, 2009 I also had a problem with XP not recognizing the hard drive. The USB Mass Storage Device was reporting a Code 10 (Device cannot start). Ryockey provided the solution in that the drive pins can be offset by one set when connected to the interface. Be careful to get the pins aligned correctly, it worked for me. I also have my drive jumper set for Master. Thanks Robert!
Randy P.S. I am using a Seagate 250 GB HD 7200.7 Ultra ATA
Feb 12, 2009 | NexxTech Portable Hi-Speed USB 2.0 Kit...
External hard drive enclosure
If you had given a password to windows vista on the the failed system. You would not be able to get into you files if they were saved in default folder like Documents >Pictures >music .
You need to use a data recovery sofware to do the job. A local tech would do the same for around 80$.
Thanks
proton
Aug 01, 2008 | NexxTech Computers & Internet
HARD DRIVE ENCLOSURE RECOGNITION BY MY PC PROBLEM
Had the same problem today. I finally noticed that the pin bay on the enclosure was large enough to allow the pins to be offset by one pin set. The open pins were hidden by wires. Once I carefully aligned the pins, everything worked fine.
Robert
Jun 01, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
I too purchased a Nexxtech Hard Disk Enclosure and my Vista-based computer keeps telling me to try a USB 2.0 setup...the USB's ARE 2.0...did you try the setup disk that came with your unit?...I tried on mine but still a no go...I may have to return it to Best Buy & try somrthing different.
May 19, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Can't get file to open off old hard drive
Vista runs NTFS...if your old XP-based machine was not, try converting to it (you'll probably need to put back in the old machine to do it)...I don't think that's the problem though as my older XP-based computer was running NTFS & my Vista-based machine keeps dinging & asking to try USB 2.0...It is USB 2.0,I then tried the setup disk and it says I have to remove the current 2.0 driver already in the Vista (I don't think so!)...I'm thinking that a Vista driver (from whatever sourse) will be needed,,,lacking that I'll return mine to Best Buy and try another brand that supports Vista.
May 10, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
My old Dell HD will not fit in HP w/vista
i see..well..was the old hard drive running xp by chance?..seems that with the new vista, that each application would need to be upgraded with drivers to pull the old data..another option is to use a data recovery service.
Laptop VISTA basic will not recognize 3.5" Nexxtech enclosure as mass storage device
run diskmgmt.msc there it will show all disk drives. if it detects usb mass storage and the hd is not showing. soulds liek hd is bad or jumper set wrong
Apr 28, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Problem setting up Enclosure
Please check if your jamper of the hardrive must be set to primary settings. Or possible your usb connector having lost contact problem.
Hope this will be helpful to you.
Oct 26, 2007 | NexxTech Portable Hi-Speed USB 2.0 Kit...
NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive Logo
2,294 people viewed this question
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Prashant M
Prashant M
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
