Question about Samsung 26.0 Cu. Ft. Side-by-Side Refrigerator, RS265LABP
Not cooling the current freezer temperature reading is 68 and the fridge is also 68 and I set them with -4 (freezer) and 36 for the fridge I tried power cool buttons and leave it for about 4 hours nothing happened. what could be the problem with this?
  • KurtK Jan 06, 2008
    Hello - having same problem as above, but .. fan is turning, compressor is warm/hot to the touch and a 'clicking' can be heard. Any to tell if the compressor is bad or just the relay ?
  • Husker man Jan 26, 2008
    26 cu ft side by side refg, freezer is cooling and can feel cold air blowing in and have ice cudesd but the refer side is not cooling.
  • 473 Answers
Listen for a clicking noise from the compressor. Could be a bad relay on the compressor, sealed system problem, or faulty board.
Posted on Oct 05, 2007
SOURCE:
How do I turn refrigerator back to what temp
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Mar 29, 2015 | Refrigerators
How do I get my fridge to cool in cold weather with buying grill covers?
That is correct, you have reached the thermostat set point. Does not matter C or F. Read the manual it will give you the limits:
The ideal refrigerator temperature is 35°F (1.6°C). You're not hugging the danger zone like you would be at 40°F (4.4°C), and you're distancing yourself sufficiently from 32°F (0°C) that you don't freeze half the stuff in your refrigerator.
Try these links:
At What Temperature Should My Refrigerator Be Set Tips from The Kitchn
What Are Normal Refrigerator and Freezer Temps eHow
What temperatures should keep my refrigerator and freezer set at
Mar 02, 2015 | Thetford Refrigerators
What is the ideal setting for fridge on Bosch KGN34VW20G
Hello John;
My name is Peter. I am a retired Sears service technician. The freezer temperature should be between -2 & + 2 degrees F. The fresh food section should be between 35-40 degree F.
Pick up a inexpensive temperature gauge with a steel shank. Place the temperature gauge in the freezer center. Do not make contact with any food product. Allow 20 minutes and read the gauge. Be quick the temperature on the gauge will drop quickly when you remove. Adjust the temperature control knob according until you reach the desired setting. Repeat this process as necessary. Do the same for the fresh food section.
You only have one source of cooling; the evaporator coil and fan in the freezer. The freezer will meet it's temperature setting first before it opens the fresh food section damper.
A balanced system will save on your electrical bills. The compressor will kick in only when demand is met. Your compressor should not be running continuously.
Oct 23, 2014 | Bosch KGN34VW20G White 280 l Fridge...
Refrigerator is not holding temperature. Currently at 50 degrees set a 7!
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 15, 2011 | KitchenAid KSRP25FNSS Side by Side...
Refrigerator is not working, freezer is working
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 08, 2009 | Maytag MFD2560HES Bottom Freezer French...
Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Refrigerators
Fridge not cooling down stays at 68 degrees
you may be low on freon..thats one thing about fridges if you are low one side will still stay cold while the other side gets warm
Jan 12, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge tempertature
I have the same symptom too - freezer temperature flashes at -2. "Power Freezer" or setting it to any other temperature is not working either.
As a result, no ice being made. Please help!
Aug 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
130 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
