Question about Jenn-Air JCD2295HES Side by Side Refrigerator
I can't get water from my water dispenser
We have a Kenmore fridge with water dispenser. The dispenser is inside the fridge (not in the door like most). Anyway, when I try to get water I can hear a motor or something trying to work. But no water is dispensed. I checked the water supply line and there is plenty of free flowing water going into the fridge. Please help as I think I am pretty handy and can't get support from the people at Sears.
  • 7 more comments
  • kenobi74 Oct 01, 2007
    MY next step is to check if the ice maker is working. The freezer is on top if that helps. I recently put in a new filter, 2 months ago. Would I get water without the filter? Also, if the ice maker works, but the water doesn't what does that tell me. Thank you for the reply, as I do not know much about refrigerators
    It was frozen, Thanks!!!! Should I lower a temp setting (higher temp) to prevent this from happening? Or what causes a freeze. I've had the fridge for two years, and this is the first time it has occurred (I do not belive the temp settings have been changed).
  • kfsjr Nov 08, 2007
    My GE side by side refrigerator has water and ice dispensers in the door. It is three years old. The icemaker works fine but we get no water from the water dispenser. Please help.
  • Anonymous Nov 12, 2007
    I have a Frigidaire side by side that wasn't making ice and the water dispenser was coming out very slowly. I bought a new filter and installed it. The water dispenser iis now fine but it still doesn't seem to be making ice. This happened once before and I called an applianace repairman. He took some tubing in the back off and there was ice in it..He cleaned it out and it was fine...Is that tubing behind a square metal panel???
  • sjray Dec 29, 2007
    Same problem, I haven't changed factory defaults on the temp for either the freezer or fridge...I see the water reservior is frozen...what gives and how canI fix it.
  • jaw407 Mar 09, 2008
    I have a GE side by side refrigerator. The water in the door is not working. It is making ice however water is not coming out from the door. I changed the water filter and even lowered the refrigerator temperature and it still doesn't work. I've read where the reservoir freezes but I don't know where to look for it. Any suggestions would be greatly appreciated.
  • nag45 Mar 25, 2008
    I can't get wate from my dispenser. It is inside the refrigerator not on the door. The ice maker is working perfectly fine. The filter is brand new. It is making a noise as if it the motor is working when I press the dipsenser button. the freezer is on the top and refrig on the bottom
  • chey1001 Jan 01, 2009
    no water on door
  • budpix May 11, 2010
    Dear the dr, I have a jenn air french door, bottom freezer with very low water flow with a new filter and good ice supply. I see your response that something may be frozen. Do I just shut off fridge for a while or turn down inside temp for a bit?
    Thank you
  • 447 Answers
The water tank is probably frozen or the filter is totally blocked does the ice maker work? i take it its a french door bottom freezer? Dont forget to rate my solution as solved if i answered your question accurately.....Thanks!!
Posted on Oct 01, 2007
  • joey  shearer
    joey shearer Oct 01, 2007
    if the ice maker still works than you know the filter is ok and it may be the water valve located in the unit compartment on the back (cardboard cover) what is the model number???
  • joey  shearer
    sometimes if you go on a trip or something and the unit is left with the doors shut for a long period of time it gets just cold enough for the water to make the state change, yes and raise both settings a little warmer you may be very close to 32 degrees with the settings now. And your welcome thanks for the rating!!!!!!!!!!!
I have a Sears side by side refrigerator. The water in the door is not working. It is making ice however water is not coming out from the door. I have changed the water filter. I've read where the reservoir freezes but I don't know where to look for it. I cleaned the coils as they were very plugged with lint.
Posted on Apr 25, 2008
  • wessington Apr 25, 2008
    Where is the damper at?
  • 3 Answers
Make sure that the damper between the freezer and the refridgerator is not broken or froozen open. This has happened to me on my GE Profile side by side twice now (known design problem). Be careful with this as I have read of folks that didn't get this fixed and thier water reservoir froze and cracked, leaked water and flooded thier house. I would make sure that you shut off the water supply until you get the problem fixed!
Posted on Jan 20, 2008
SOURCE:
I have a Kenmore side by side fridge with ice/ water dispenser in the front door. When I push the water dispenser the water comes out the spout but also some comes out behind the spout making a mess. Is...
sounds to me that the line inside of the door is cracked. Their is no easy way to repair that, either the entire door must be disassambled to replace that line,or replace the outerdoor panel with the line embedded into it,to replace the door panel it requires transfering all the compentents fmor old to new door panel, a partial list of things that must be transfered parts from old to new outer door include but not limited to
inner door panel
door gasket
dispenser asm (which cant come out as one piece and must to disassabbled into appx. 20 parts)
wiring
hinges
door handles
Jul 26, 2011 | Kenmore Side by Side Refrigerator
Kenmore 253.52632200 refrigerator water dispenser leak. The water dispenser in front of the door leak water slowly. Sometime it leak a lot and sometime it does not leak
You need to replace the water dispensing solenoid valve located in the back of the fridge and your problem will be solved.
Dec 12, 2010 | Kenmore Refrigerators
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
NO WATER COMING OUT FROM WATER DISPENSER
This could be a bad water valve for dispenser on back of fridge or poor connection in the dispenser control. If you could get me the model number I will be able to help you better. Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Mar 09, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Water dispenser not working on my Kenmore fridge
NO,YOUR RIGHT YOU NEED TO REPLACE THE WATER INLET VALVE ON THE LOWER BACK OF FRIG.-MIKE
Mar 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser...
I had the same problem, in reading a bunch of other similiar issues with various models, the best thing I found was that the water line inside the freezer door is frozen. I had to isolate this portion of my water line from the wall all the way through the frigde. It you unplug, take out screws from he back cardboard cover so you can follow the waterline through the fridge. The valves are pretty easy to take apart/put together. To take apart a valve, just press down on the ring around the valve the pull the connecting apart. To put back together, push the same ring down, then push the connection back together. To check the water flow, plug the fridge back in and have some one push the water dispenser as you check each valve. I suspect the problem is in the freezer door, so you should just check the valve under the bottom left side of the freezer door. From here to the dispenser the water line goes through the door. I used a blow dryer to heat up the inside of the freezer door just behind and below the dispenser unit for about 5 minutes. Try and run the water again and it should work. Good luck
Oct 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Oct 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Jenn-Air JCD2295HES Side by Side Refrigerator Logo
943 people viewed this question
Top Jenn-Air Refrigerators Experts
jasbo
jasbo
john h
Felizardo Erilla
Felizardo Erilla
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
