Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
Tv wont turn back on
I have a Sony trinitron and a few days ago it kept turning off by itself and id turn it back on and a few minutes later it would turn off again. Then the picture started to disappear and the turning off would come quicker and now the tv makes a click when you try to turn it on but it doesnt turn on. The light where it says stand by/timer keeps blinking, but i dont know where the manual is so I cant look there.
  • 6 more comments
  • kdixon37 Dec 02, 2007
    TV wont turn on standby timer light flashes 2 times
    what can I do to fix it?
  • hvalle00 Dec 02, 2007
    My Sony TV stopped working one day. The TV will not turn back on, only the standby red light blinks a few times, but the TV stays off.
  • Anonymous Feb 19, 2008
    Standby light is on...TV makes a clicking sound and will not turn on.
  • KM81 Feb 23, 2008
    TV goes off by itself. PIcture is hazy when initially it is turned on but after a few seconds goes off. Standylight is still on though
  • Trini Jens Apr 04, 2008
    Sony 27" KV-27FS100....clicks when attempting to turn on but just not responding......timer blinking......technician cannot locate the problem......please help....Jenny
  • Anonymous Apr 12, 2008
    My Sony Trinitron will not turn on. There are no blinking lights. Nothing. Several days ago it just shut down. Help.
  • kathyryan200 Nov 13, 2008
    Tv picture goes out but not the sound. i have to turn it off and then back on for the picture to come on.
  • bibidlt79 Jan 29, 2009
    I have a sony wega 34" tube flat screen from 2004. TV clicks on but sounds like it shuts down. Has a continious 6 blinking series. Please help!!!!!! Open to all suggestions. Thank you
TV will be on for 2 hours sometimes, or 20 minutes then goes off, standby bottom is flashing. and keeps doing that over and over.
Posted on Jan 24, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
Seems to be bad contact in the soldering of the main board
depening on no of blinks we can give the exact circuit
Posted on Feb 12, 2009
Go to http://www.iwaynet.net/~nesda/SonyBlink.html. This is a guide to what is wrong with your t.v. It is a self diagnostic index. Count the number of blinks or of there are none, and it tells you what the problem is. This is for a Sony Tinitron xbr.
Posted on Nov 12, 2008
I have a sony trinitron 32" tv had same problem with 3 blinking lights i purchased a replacement transformer lot2196 from thunmbs up ltd uk for £22 including postage and a transistor from ebay 85p and this has sorted it but now cant reinstall built in freeview hope this helps and hope someone can help me
Posted on Jul 04, 2008
Sony Trinitron won't turn back on...timer/standby light is blinking
Posted on Dec 16, 2007
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
It seems to me there is a loose connection in the oscillator section. some capacitors in that section have gone faulty. also change the switches in the front panel so itself on& off problem will be solved. please you can write me here if you face any problem. if you are not tech person get the help of tech to do it. hope this will help good luck.
Posted on Oct 02, 2007
My sony trinitron tv sometimes turns on then right back off or turns on volume only then few days later it works fine. whats up?
Check for any loose solder connections in the main power regulator section of this TV. It will be very difficult to detect loose solder terminals, as they will be microscopically small to ***** eye. It is best to re-solder all the suspected solder terminals by applying a little more fresh solder to each solder terminals.
Oct 26, 2012 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Here's my suggestion , unhook all the external components to the TV and leave the TV unplugged for more than a few minutes (a day/overnight). The next day plug the TV into the wall outlet (not the powerstrip) without anything hooked up to it, and turn it on. See if it comes on. Sometimes unplugging for a few minutes/hours is not long enough for it to reset itself.
Dec 28, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sstandby light blinks & doesn't turn on.
Unplug TV from the power outlet and let it sit for a few minutes, then plug it back. It sould work normally after that.
Apr 28, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KV32HS420
Good day.
I believe there may have been some parts that were burned out due to high voltage. There are cases where insects such as lizards penetrated and got stuck then got stuck then got electrecuted inside. You can open the back cover of your unit or better, refer to the repairman.
chris
Mar 25, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hii.... first I like to know the chassis of yor KV27FS100..
sound like problem with regulated parts block.....and can more helpfull if you count the blinking of the LED....sony have selft diagnostic at the LED Blinking.....
I hope hear from you soon....
Thank's
[Vrya]
e-mail : be_cek@yahoo.com
Feb 23, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
258 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
