Will not brown the top
1. Make sure the browning contol is set to at least 4.
2. Let the iron pre-heat at least 4 minutes
3. Carefully, touch you hand to the top with a quick touch or about 1/4" away.
4. The top and the bottom should feel the same. CAUTION THEY ARE VERY HOT
5. If the top isn't very hot the element inside isn't working.
6. Unplug the unit and let it cool
7. Remove the top lid cover with the assembly screws
8. Remove the element shield under the lid
9. With the element exposed, chech the wire connection to ensure no lose connections
10. With volt meter connect to the element, plug the unit in CAUTION ELECTRICITY CAN KILL!
11. There should be 110 house voltage at the element terminals
12. If not power is seen. disconnect the power and the meter.
13. Reassemble the shield and lid.
14. Remove the control panel from the front face of the iron
15. Locate the adjustment knob electrical terminals
16. Locate the supply side terminal and the output terminal
17. MAKE SURE THE POWER IS UNPLUGGED
18. Inspect the thermostate control for any lose wires or debrie entrapted in the contacts area.
19. Clean and re-inspect the thermostat, then reassemble.
20. If the units still fails to work, unplug it again to check the contacts in the rotational housing
21. At the rear of the until locate the area where the wires are routed from the front panel control to the top rotational housing
22. Closely inspect the area where the wires are routed to the top of the unit.
23. If any of the wires seem worn replace them.
24. After inspecting the heating elemement, its connections, the temperature control and the wires routed to the top of the Iron - you should have found the problem. To further troubleshoot you will need specialzed equipment that could be hazardous such as a cheater plug to apply house current directly to the top element to ensure that it is functioning. If this is done and the element still does not heat then the element is bad.
