Question about Motorola Mobility RAZR V3xx Cellular Phone
Screw protector popped out
When you open the phone there are two rubber pieces on either side of the phone that protect screws. One of them popped out and I dont know how to get it to stay back in place. Please help!
    Scholar:
  • 173 Answers
A lil crazy glue will do the trick
Posted on May 29, 2008
My kenmore washer is a special edition model # 20692001, had a burnt rubber smell won't agitate or spin, what could be the problem? Is it a direct drive or does it have a belt?
no belts that has a coupler in it,it looks like a regular washer,kenmore doesn't make anything the only way to tell who made it is by the first 3 numbers that you didn't add,you need to send full number,you were missing the 110. in front of it,the 110 tells me it's made by whirlpool,on the top console,first if it filled with water and stopped most likely you have a bad lid switch,close the lid and open it a few inches if you don't hear a click when you close and open the lid the lid switch is bad,they don't want the washer to run if the lid is open so if the switch is bad it won't run.lid switch part number 3949238.if it runs,fills and drains but no spin or agitate check the coupling. remove the two end caps,you might need a screw driver to pop them off,remove the two screws that are under the end caps,flip the top console up,with a screw driver pop the metal clips up and remove the lid switch connector,now you can pull the whole frame away,tilt the frame up in the back and pull forward,with a screw driver remove the two clips that hold the pump onto the motor,slide pump off,you don't have to remove the hoses,now most of the time there are two 1/4 inch screws holding the motor clips in place,remove the screws and with a screw driver pop the two clips,slide the motor forwards,now you will see the coupling,it is two plastic pieces with three arms on each piece and a round piece of rubber that goes in between the two parts,usually you'll find the arms broke off and the coupling has to be replaced,if the coupling looks good,rub your hand on the bottom of the transmission where the back side of the coupling is,if you find oil on your hand the tranny is blown and that will be the problem.if it's the coupling part number is 285753A.one more thing if it's the lid switch remove the frame like i said and you'll see the lid switch on the right side of frame,remove the two phillips screws, then there's a 5/16 inch screw holding the ground wire onto the frame to the lid switch,pop the white connector of the switch out of the frame,then there are two clips holding the wires of the switch in place,remove the old switch and install the new one the same way you took the old one out,also if it is the coupling,when you go to slide the motor back in place there are 4 rubber pieces on the back side of motor the line up into the frame,make sure if any are missing to pull them off of frame and slide them back on motor or you'll never line it up.hope this helps,if you need any other help let me know would be happy to help you and good luck with your repair,i use a 7/16 nut driver to bang the coupling pieces onto the tranny and the motor,it's around the same size as the middle of the coupling and works well for me,also put spit or soap onto the motor part of the coupling on the three arms so it will slide into the rubber holes easier.good luck
Sep 21, 2017 | Kenmore Washing Machines
About a rear hatch not opening
Those pads are junk. They are not weather protected. They corrode badly. I believe on yours, you have to got to the back and at the bottom of the hatch panel there is a round plug you can pop out. Insert a screw drive. You will have to catch the release and move it left or right to release the hatch. Once open look at the rubber. There are two screws to remove and replace the controller.
May 01, 2015 | 2010 Chevrolet Equinox
How to open Teac FD-05PUB?
There are two small black phillips screws near where the cable is, take those out. The opposite side from the screws is the cover, it pries off. You can work a flat tip screwdriver in there and see if you can pop it off without damage. Start on the sides.
If you're having trouble with that you can remove the rubber piece going around the outside first. I started where the floppy opening is, you can pry it out with a small flat tip screwdriver then just pull it out. Do the same for both sides of floppy opening.
Then you'll have to take the phillips screw by the motor to remove the drive from the case. There is another small phillips screw holding the cover, remove that and you can work the cover off. Now you can clean the heads.
To put it back together screw the drive cover back on, then screw it back into the case. Put the rubber piece in, then push the top cover back down till it snaps in. Then put the black screws back.
Aug 08, 2012 | Teac FD-05PUB External Floppy Drive
How do i tighten the swing action on my stiener safari binoculars?
These binoculars have a 10 yr warranty, so you may contact steiner (http://www.steiner-binoculars.com/) for repair for a nominal charge, however there is an easy fix: You'll need a small (about 1/4 in) screw driver.
1. remove the objective lens protector. This is the small metal piece on the binocular side that is loose, opposite from the eyepiece(part you look through). It appears impossible to "pop" loose from the outside, but if you slip your finger inside(try not to smudge the lense), you'll feel a significant ridge. You may be able to pull / pop it off with your finger, or a small handle.
2. Tighten the screw that is now exposed. Do not overtighten, just a little tighter than what it takes to keep it from "falling" on its own weight.
3. Pop the lens protector back on the object lens.
Oct 19, 2011 | Steiner Safari Binoculars
Makes noise on spin cycle.doesn't spin
.most likely you have a broken motor coupling part number 285753A and it's around 20 dollars.unplug the washer.on the top console there are two phillips screws that have to be removed,on whirlpool washers they have them in the rear one on each side,remove them and flip the console up.with a screw driver pop the two metal clips,put the screw driver in the hole and on top of the clip and push back to the wall,the clip will pop out,next you'll see a wire connector to the left of the right clip,unplug that,this is the lid switch wires.open the lid,grab the frame and lift up and pull back,remove the frame of the washer,on the bottom you'll see the pump,with a screw driver remove the clips and slide the pump off the shaft.then remove the two screws and pop the two clips off the motor and pull out the motor.on the back of the motor you'll see the coupling.most likely the three arms will be broke off,the other side of the coupling will be on the transmission.remove that part and the rubber piece.next tap on the new coupling on the motor shaft the other part on the tranny shaft.slide the rubber piece on the tranny part of the coupling and then line up the motor coupling so it fits into the rubber and both pieces are interlocked in the rubber.before you do this check the rubber pieces on the corners of the motor,if any are missing pull it off the frame and slide it back on the motor or you'll never get it back together,slide the motor back on and put the washer back together.the coupling breaks from overloading the washer
Feb 14, 2011 | Kenmore Washing Machines
Washer drains but is not spinning
most likely you have a broken motor coupling part number 285753A and it's around 20 dollars.unplug the washer.on the top console there are two phillips screws that have to be removed,on whirlpool washers they have them in the rear one on each side,remove them and flip the console up.with a screw driver pop the two metal clips,put the screw driver in the hole and on top of the clip and push back to the wall,the clip will pop out,next you'll see a wire connector to the left of the right clip,unplug that,this is the lid switch wires.open the lid,grab the frame and lift up and pull back,remove the frame of the washer,on the bottom you'll see the pump,with a screw driver remove the clips and slide the pump off the shaft.then remove the two screws and pop the two clips off the motor and pull out the motor.on the back of the motor you'll see the coupling.most likely the three arms will be broke off,the other side of the coupling will be on the transmission.remove that part and the rubber piece.next tap on the new coupling on the motor shaft the other part on the tranny shaft.slide the rubber piece on the tranny part of the coupling and then line up the motor coupling so it fits into the rubber and both pieces are interlocked in the rubber.before you do this check the rubber pieces on the corners of the motor,if any are missing pull it off the frame and slide it back on the motor or you'll never get it back together,slide the motor back on and put the washer back together.the coupling breaks from overloading the washer.happy new year
Jan 02, 2011 | Whirlpool LSR5132PQ Top Load Washer
How do i replace flex cable on a razor phone can u show video
Ok..#1.take the battery out..
then youll have to remove the 2 screws that hold the modem part of the phone in.gently pryup on the modem ,on the side with out the usb charger port..slip a thin flat tipp screw driver in there and slide it towards the bottom of the phone. there are littler plastic clips carefull not to break them.then youll see where the bottom of the flex cable plugs in.unplug it.then flip the phone over,in the 4 cornors of the screen side of the flip there are tiny little rubber plugs. pop them out and undo the screws in there.near the top of the screen there is a little slot on the right side of the screen ..gently pop the cover off the screen..unplug the flex cable from the screen.and carefully remove the screen.be careful not to damage the buttons on the sides of the screen.then close the flip and turn the phone over..looking into the battery part of the phone,on the top right hand side of the hindge there is another little screw,remove that.then again turn the phone over and stick a flat tip screw driver into the open hole and pop the chrome roller out.then very carefully youll be able to seperate the 2 halfs. look on the back side of the keyboard youll see little metal tabs folded over that holds the key board in place..the keyboard and the flex cable are one piece, just revers the procedure to replace.." BE VERY CAREFUL RUNNING THE FLEX CABLE THREW THE HINGE AS IT CAN DAMAGE VERY EASLY." IF YOU NEED MORE ASSISNT CONTACT WWW.PHOENIXTEC.CA they are very helpful
May 11, 2010 | Motorola Mobility RAZR V3
How to change the back light
Open the rear door and look for 2 pop-off caps on the suspected tail light assembly covering philips screws. If you remove both screws, the tail lightassembly becomes quite loose.
The last step is to give a firm tug, directly backward. The whole assembly is held in place with three small plastic clips (round cone shaped devices pushed through holes in the rear body work with a rubber "washer" protecting the paint).
You have to pry them loose from their insertion mounts to remove the assembly. A firm tug works well, but don't pull to the side or you may break the clip (or clips), and then have to replace those too. Once you've pulled the assembly off, the lights are easily accessed and replaced.
To reassemble, simply reverse the process.
[Note: there is no cover for the bottom screw on the rear door hinge side. It is exposed. There are two possible bolts on the bottom side of the door; the one for the tail light assembly is the one you can remove with a philips head screw. It can be accessed by opening the door and fitting a screw driver through the opening behind the door.]
Nov 07, 2009 | 2004 Honda CR-V
How to remove front driver side door panel (2000 ford expedition)
There is a triangular piece, at top corner, covering a screw behind the mirror. Remove that screw. Remove the piece that covers the handle and remove the screw holding the handle to the door. Look through, where door handle was and remove another screw just above where the handle was. This screw is holding the panel to the actual door. Pop the cover off for the automatic door locks and disconnect them. Lift the panel in an upward direction.
Nov 25, 2008 | 2000 Ford Expedition
Display panel on dv9040us has opened up
Could you post a picture of your problem? The issue is probably that the screws holding the monitor mount to the rotating piece have stripped and come out, and the small piece that is meant to stay screwed in is spinning freely. This can spread that area out and pop open the monitor casing.
You can pop off the small rubber "feet" that go around the monitor to gain access to the screws. You may be able to position the monitor in the correct angle and screw it back in with a precision screw driver. If this was the problem then this is most likely a temporary fix. If the screw has come out once, then the groove is stripped and it will happen again. You'll either need a new screw or most likely a new hinge in the future.
Regardless, try posting a picture and I'll be able to help you more.
May 12, 2008 | Computers & Internet
Motorola Mobility RAZR V3xx Cellular Phone Logo
27 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
