Question about Audiovox DV1201 System
Audio out connection
I have connected audio out from Audiovox to TV. However, when I play DVD I cannot get any sound out of TV speakers.
  • 93 Answers
How did you connect it? With SCART, RCA cable, or what?
Posted on Oct 03, 2007
Why? no sound from the speskers at all.
There are a few things that could cause no sound and although some are obvious I'll got through them all..
1) Sound is on Minimum
2) Sound is Muted
3) No Power to Subwoofer
4) Speakers connected Incorrectly or Faulty
5) No AUDIO IN connections to TV-IN or AUX-IN
6) Incorrect Input Source is Selected (See Below)
Connecting audio from TV
When connecting the audio output from your TV to this Home Theater Audio System, you will have the sound of the
TV output on all the speakers. It will enable you to enjoy the multi-channel surround sound capabilities.
Use an audio cable (red/white - not supplied) to connect the TV IN jacks on this DVD system to the AUDIO OUT
jacks on the TV. To listen to the sound, press TV on the remote control as the sound source that you want to play.
Connecting audio from an audio/video device
This DVD system provides analog and digital audio connection. You can connect the audio output from an
audio/video device (e.g. VCR, Cable/Satellite Box) to this Home Theater Audio System in order to enjoy the
Use an audio cable (red/white - not supplied) to connect the AUX IN jacks on this DVD system to the AUDIO OUT
jacks on the connected device. To listen to the sound, press AUX/DI to select "AUX" as the sound source that
you want to play.
Or
Use a coaxial cable (not supplied) to connect the DIGITAL IN jack on this DVD system to the DIGITAL OUT jack on
the connected device. To listen to the sound, press AUX/DI to select "DI" as the sound source that you want to play.
Please leave feedback
Cheers
Andy
Apr 27, 2011 | Philips HTS3450 System
I have a 32 "
Check how you have the satellite cabled. I suspect that you have the video from the satellite to the TV but the audio cable going directly to the stereo. You probably have the DVD audio and video going directly to the TV. (I'm assuming you have the 32LA30rq and not the 32LA30rqd which has a built-in DVD and thus has the audio connection inside the TV.)
Since you don't mention which connection you are using for the DVD player and for the satellite, I will just mention the basics. If your DVD player is connected to one of the HDMI ports, that cable carries audio and video between the TV and the DVD player.
Devices that use component video cables use two separate cables. One cable with two sets of three RCA plugs carry the video; a second cable carries audio with 2 RCA plugs on each end. When you connect these, you do not have to connect the audio to the TV. (Similarly, a composite video connection can be modified for one line with the video signal going to the TV and the audio cable going to a speaker system.)
If my solution is correct, you may want to rearrange things. You can connect the satellite audio out to the TV audio in at the same location as you have the satellite video in. Then connect the TV's audio out (to the right of the component 2 in and above the coax audio out) to the stereo. Then switch the TV speakers off to use the stereo - Menu > Sound > Other Settings > Speaker On/Off. Then both devices will play either at the TV speakers or the stereo depending on the state of the TV speaker setting.
The manual is available here: http://tv.rca.com/product/manualdown.asp?modelnum=32LA30RQ .
I hope this helps.
Jan 20, 2011 | RCA Televison & Video
I just bought a Samsung HD LCD 32 in TV and want to play it through my Home Theatre System. I set the TV to external speakers, put the HTS in aux mode, but I don't get sound. My old Samsung SDTV would...
If you do not have a manual for the machine down load one at http://www.samsung.com/us/support/downloads/LN32B460B2D
It will show you how to set up a Home Theater Connection
Connecting an Amplifier / DVD Home Theater
TV Rear Panel
1 Audio Cable (Not supplied)
Amplifier/DVD Home Theater
1 Connect Audio Cables between the
AUDIO OUT [R-AUDIO-L] jacks on
the TV and Audio Input jacks on the
Amplifier / DVD Home Theater.
When an audio amplifier is connected
to the AUDIO OUT [R-AUDIO-L]
jacks: Decrease the volume of the TV
and adjust the volume level with the
Amplifier's volume control.
Each Amplifier/DVD Home Theater has
a different back panel configuration.
When connecting an Amplifier/DVD
Home Theater, match the color of the
connection terminal to the cable.
Nov 29, 2010 | Samsung LN32B460 32 in. LCD HDTV
I cannot get sound from the tv through the surround sound, speakers all tested and work ok and dvd sound comes through ok when playing dvd, radio works fine also, worked fine 2 days ago with sharp tv, have...
Hi, You have to make sure you are using the "audio out" from the dvd/surround into the "audio in" on your TV also in some case TVs will need to change the "input" with your remote to see where you connected your dvd/sur also some TVs have a switch for "n" or "off" for internal speakers and also you could have that option in your audio menu on your TV, Hope it help, good luck. Mike
Oct 19, 2010 | JVC TH-G30 Theater System
Audiovox DVD Home Theatre System Sound Issues
check the audio settings make sure they match where you plugged the source. and if all of your sources run into the tv first you will need to have an audio out to the reciver
Apr 25, 2010 | Audiovox 150W DVD Home Theater System -...
Installed new 1080 plasma tv can't get sound from home theater system
A home theater system usually consists of a dolby digital stereo amplifier and 5 to 7 speakers.
Turn your stereo on and select the source that delivers video to the TV (DVD, VHS, Game, etc.). The video may be connected directly from the device to the TV, but the audio should connect to the stereo system (DVD, VHS, or other input). This way, the source audio is sent to the stereo and it provides the big sound to match the picture. Otherwise, you'd have to connect the source audio to the TV and let it's comparably tiny amplifier and speakers provide sound - that comes up short.
When playing a DVD, select the DVD input on the TV *and* the DVD input on the stereo. If you do not connect the audio to the DVD input on the stereo system, you'll have to connect to the TV, otherwise nothing will be heard.
Sep 17, 2009 | Audio Players & Recorders
Sc-pt660 + 46pz85u = NO SOUND!
Don't worry about sending the TV audio to the Panasonic. Just send a digital audio signal from the cable box to the Panasonic.
DVD - Panasonic connected via HDMI
TV - Panasonic connected via HDI
cable connected to cable box and TV. But you will not really be using the cable connection to the TV (TV Tuner) since you will want HD feed from cable box through HDMI input on TV.
You aren't concerned about feeding the TV speakers because your audio will always come from the home theatre.
Note that some components don't feed audio through HDMI, in which case you will need to use optical digital audio.
Sep 08, 2008 | Panasonic Home Theater System System
Connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Jan 18, 2008 | Bose Cinemate Digital Home Theater System...
Sound Problems with HD TV
get the digital audio optical cable and connect the to the tv- got it working tonight
Oct 07, 2007 | Samsung HT-Q100 System
Help
you cannot get your tv to play surround sound through the speakers, but if your tv has either a scart 21 pin socket or an audio out, you can fit a scart to phono adapter and connect the phono plugs to the audio left right input on your sound system, likewise if you have audio left and right output(phono) on the tv, connect to audio in on your unit. You should have a choice of output channels on the system menu, similiar to DVD/video1/video2 or output 1 and 2 or auxilliary 1 and 2
Jun 04, 2007 | Audiovox DV1532 System
Audiovox DV1201 System Logo
125 people viewed this question
Top Audiovox Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Andrew Taylor
Andrew Taylor
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
