Back to:
Tags:
Camcorders
Generic problem for all Camcorders
Sony Camcorder - charger/battery issue (by 4 users)
posted by pprabhu on Oct 01, 2007
Hi, I have a Sony Camcorder - DVR-HC32. When I switch it on, I get the following error message: "use the InfoLithium Battery pack". I thought it was a battery issue and bought another one from the Sony store, but I get the same problem.
I think it's to do with the charger, since I get a blinking light when connected to the power source through the AC adapter. The light's supposed to be on continuously if the battery's charging properly.
Any ideas?
Thanks.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by alibasbas, posted on Feb 01, 2008
I have the same issue with a Sony Handycam. Basically, when I charge the battery in question, the charging light indicator is blinking. Normally, the light should be steady. When I plugged another battery, the battery charges fine, with the light indicator steady and not blinking. Because of this, I think the cause of this problem is the battery. So how can I fix my battery that is not charging?
Comment by Pahar, posted on Dec 10, 2007
I have a similar issue, any one knows the solution
Comment by jabliss, posted on Nov 10, 2007
go the same problem... got two batteries, one charged with light on constantly, but the other one which is newer and stronger just shows light flashing and doesnt charge. The camera works well with the other battery or cable. Does this mean that my battery is bad, or a bad connection?
Best Solution
posted on Feb 09, 2008
Thanks for Trying (70)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
your battery is dead because you need to take it out after every use. its gay but thats why it doesnt work
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Sony Camcorder - charger/battery issue:
I don't want to Accept this solution
Can you Help with these Camcorders problems?
Panasonic Palmcorder PV-L452 VHS-C Analog...
my camera will not zoom, but it will take pictures (just...
Sony Handycam DCR-DVD108 DVD Camcorder
when i put it on record you can't see anything it will...
Camcorders
A 80 mm DVD-RW was recorded in a Canon Handycam.It can be...
JVC GR D370US - camcorder - Mini DV
I have a JVC GR-D370u video recorder and my windows xp...
RCA CC641 VHS-C Analog Camcorder
we lost our eye piece focus control on this model and are...
Loading problems.
Repair Service
Find Camcorder Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
