Home | JVC | AV-56WP84 56 in. Rear Projection Television | Picture Problem , Son...
JVC AV-56WP84 56 in. Rear Projection Television
Problem for JVC AV-56WP84 56 in. Rear Projection Television
Picture Problem , Sony Projection TV
By rd1ski on Oct 01, 2007
Picture bow's in on the side or bow's in from top to bottom. On the outside of this rounding effect , you can see the color blue , or red . Any tips on what part/parts that need to be replaced
Comments:
Oct 01, 2007
- Thank for the tip , this is a Sony projection KPR46EXR15 , I thought that was is my first message
Same Problem
Dec 27, 2008
-   SAMSUNG PCN5425RX/XAA Red color bows from top and picture has double vision-   ssg_johnsonc
Dec 07, 2008
-   bows in the middle-   chrissy32820
May 06, 2008
-   sony 46 inch kp46wt510-   shirlee7
Best Solution
posted on Oct 01, 2007
Helpful)
Terryfic
Rank: Guru  JVC Expert
Rating: 87%, 1703 votes
Generally, a convergence issue==replace STK
IC's. ( Look for largest heat sink in set )
Further help needed?==provide make,model.
Comments:
Oct 01, 2007
- Convergence PCB is up front,behind speaker grills/access panel.STK 4278L X 2.Also,solder
any/all bad connects on convergence board.
Check both 3.15 amp fuses.Re-install--usually,
no further adjustments needed.
To improve pix quality,remove rear cover--clean RGB lens caps w/soft cloth.
Was this helpful?
Yes
No
Solution #2
posted on May 22, 2009
Very Helpful)
Ecollier2012
Rank: Guru
Rating: 93%, 541 votes
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for JVC AV-56WP84 56 in. Rear
Questions and Unsolved Problems for JVC AV-56WP84 56 in. Rear
Do you recommend JVC AV-56WP84 56 in. Rear Projection Television?
Answer
Answer
lg has no coparated in their customer . customer complain noumber 36714 plasama tv 45 day left and... (More)
Answer
The HumaxPVR-9150T cannot record BBC1 and BBC2
Answer
buzzing coming from the back of the tv not through the speakers even when nothing connected to the... (More)
Answer
mitsubishi WD60735 will not power up when I plug it in just get blinking green light I left it... (More)
Answer
my sony 56" rear projection tv is going black for 15 sec every couple of hours? i have had the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For JVC AV-56WP84 56 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 712
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
