Question about Fuji FinePix S5000 Digital Camera
Camera doesn't work
When I switch it on, the screen is blue and the words, "NO IMAGE" appear. Nothing else works. I have tried 2 different xd cards and the batteries check out. I have formatted the xd card and wiped the contacts clean.
  • 1 more comment
  • ebssoc Oct 01, 2007
    The camera is in the "photography mode", not the playback mode.
    Is that it? I get a totally unhelpful solution for my $9.95?
    I tried to reset it but it still does not work. Ebssoc
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 114 Answers
Try to reset your camera from the main menu. There must be a reset option in the menus.
Posted on Oct 01, 2007
    Problem Solver:
  • 7 Answers
Sounds like you are in playback mode (Power switch icon is a right pointing arrow). Make sure the power switch is in the "photography mode" the icon looks like a camera.
SOURCE:
I have a J10 fujifilm camera and it currently has an error message: FRAME NO. FULL! I have the following picture card: Fujifilm xD xD-Picture Card M1GB Any advice would be appreciated.
Try formatting the memory card. If that doesn't work, try a different memory card. If that doesn't help, sadly, it's probably time to return the camera if it's still under warranty.
Jul 13, 2011 | Fuji FinePix J10 Digital Camera
Problem with A345 digital camera
Was the camera ever dropped or impacted hard? Any visible cracks on the screen? try turning on the camera without the xd cards.
Jun 13, 2008 | Fuji FinePix A345 Digital Camera
No Image
Please read these/the 2 posts that I posted prior for a similar XD mem card problem, as I firmly believe you are "formatting" your mem card improperly using your home computer instead of "formatting" the card on your camera.
Also the XD type card & size are very important also!!
What you will have to do is read and download the photos you have on that XD card using the same "card reader" you used before and then properly "re-format" that card in your "CAMERA ONLY". This should solve your XD card problems.
PRIOR POSTS:
Kristina,
Not knowing what model Olympus camera you have, or how old it is - your new memory card "format" problem is one of 3 possibilities.
1st - If you have an older Olympus camera more then 4-5 years old the newer M & H series type cards over 256mb will probably not work in your older camera, as by the camera's internal firmware chip design of the camera itself. Some cameras were upgradeable some weren't as to the internal firmware chip as well as available software drivers depending on which computer OS system you were using ie: (WIN98SE, WIN2000, etc). Has to do with the memory card read/write chip speed as well, and also has to do with the physical storage size of the card itself. Some digital cameras were MAXED OUT at 512mb cards, some as low as 256mb. A 2gb card simple won't work in that/your camera in that case.
If you read the camera's user manual it will possibly tell you this, or else go online to www.olympusamerica.com and use this link:
View which cameras are compatible
Select camera model series and scroll down the model # and research the max card size & type you can use (3 basic XD card speed types available - regular XD - M type - H type).
If you are using the wrong type & size card you will need to return that card (if you can) and get the right XD size & type for your camera.
2nd - You should always FORMAT (same as ERASE ALL and FORMAT modes on most Olympus cameras) the new card, or any XD card for that matter in your camera itself. NOT THE HOME COMPUTER!!! The 2 format procedures are not the same!!
If you are re-shooting (re-using) the same XD card over and over again and then downloading the JPEG pix directly to the computer using a USB interface cable there usually is no need to re-format the card again as long as the XD card stays the camera and is not downloaded into a home computer via a "card reader". If you do the latter "card reader" then I would advise doing a card re-format in the camera again just to be safe!!
And lastly - If your home computer recognizes the XD card via a good "card reader" (do not FORMAT the XD card here btw, as you are just checking the card out to see it is GOOD is all), but the camera will not then that is a good sign your camera is OK, but it's just the wrong type & size XD card.
Hope this helps solve your camera XD problem not knowing which model you have.
Best regards,
Frank
AND:
Follow up to previous post:
I didn't have the time to access the exact link below to check on your specific 2004 model year camera because I missed the Fuji camera model part, as I'm brand new to this site - so please forgive my previous oversight here.
I was right though in my initial posted assumption that you bought the wrong XD memory card based on your Fuji FinePix A330 Digital Camera - as to it's older model year - in that your camera is limited to a 512mb memory card.
Make sure you buy the 512mb standard card if you still can find them. Otherwise check with Fuji Corp to make sure the M type card (faster read/write chip) will work in your specific model. The M type cards work just fine in my Olympus C-740 even though it was told to me they wouldn't work at all, but each digital camera is slightly different as to it's internal firmware (BIOS) chip.
See the following camera info for your specific model at the link below under Storage Media:
Steves Digicams - Fujifilm FinePix A330 - User Review
I hope this now clears up any prior confusion from the previous post.
Best regards,
Frank
Feb 06, 2008 | Fuji FinePix A330 Digital Camera
Blue screen
You should check the settings to see which type of memory card you are using, xD versus Compact Flash. The default xD card that the camera comes with is very small and may not support saving the size of image you're trying to capture. If you are using a card with enough memory the card itself might be defective..
Jan 12, 2008 | Fuji FinePix S7000 Digital Camera
Trouble with my olympus u 700.
Hi powerp,
I had the same problem with mine, and was advised by a friend of mine who is a digital buff, that the lens is not it it's right position.
Though it sounds a bit 'hammers to walnuts' kind of solution, his advice cured my mju700.
1/ Remove the battery and xd card.
2/ Hold the camera VERY tightly.
3/ Shake the camera violently for a few seconds (15 or so)
4/ Refit the battery and XD card, and switch on again.
Following this advice, mine know works fine.
The theory behind this is that particles of stuff get into the lens and cause the problems. Be carefull that your camera is always safe when on the beach etc !
I hope it works for you !
Dec 27, 2007 | Olympus Stylus 700 / 700 Digital Camera
Blue screen and lens error
i think its in the flix of your lense,
coz the flixible wire of your lense and motor are one
try to test it!!
there is something wrong in the FW i think!!
Frank!!
Oct 07, 2007 | Olympus Stylus 700 / 700 Digital Camera
Olympus XD card low level formatting help needed
purchase another card (smaller memory and cheaper...as a test). install it. if it works, then read file folder names under windows and then copy these folders over to the 1GB card.
Jun 03, 2007 | Olympus Camedia D-540 Zoom Digital Camera
Olympus C-750 Trouble formatting card
have u tried to format the card on the computer??? try to format in a card reader.... and after on the camera. if that doesn´t work... could be the kind of card, there are diferent kinds of xD cards. good luck
Apr 02, 2007 | Olympus Camedia C-750 Ultra Zoom Digital...
Fuzzy lcd screen with no image at all
I have had the same problem with my s5000 and i have no ideea what is wrong.I had the camera sent to the fuji maindealer to diagnose the problem ,but they would not disclose it unless they will fix it.And that would be for £100! I still dont know what to do ...
Feb 03, 2007 | Fuji FinePix S5000 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
64 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
