Question about Lexmark X4270 All-In-One InkJet Printer
X4270 fax, printer machine
When I go to send a fax, the paper is in the fax machine, I type int he number and press start and the fax wil not go, it just keep telling me to put hte number in again or press select.
  • 1 more comment
  • Anonymous Mar 03, 2008
    same problem
    same problem
  • Mark Taylor Mar 15, 2008
    Exactly the same problem - any clues anyone?
    President:
  • Lexmark Master
  • 2,022 Answers
Pls check the no is it correct or not and see the all the buttons of no are working fine .bye
Posted on Oct 01, 2007
SOURCE:
Need paper work on hoe to use my fax machine
Please visit the Lexmark website for the Lexmark X4270 User's Guide. This contains detailed instructions on how to use your printer's features and functions.
I hope this helps.
Jan 01, 2012 | Lexmark X4270 All-In-One InkJet Printer
How can I send and receive a fax from Lexmark x4270.?
You can send faxes via the operator panel, the All-In-One Center, or the fax driver.
Using the Operator Panel:
  1. Make sure your All-In-One is switched on.
  2. Load up to 30 sheets of your original document face down in the ADF (Automatic Document Feeder). Note: When you load small paper sizes, place your document in the center of the tray and adjust the paper guides to the edges of the paper.
  3. On the operator panel, press Fax.
Using the keypad you can:
  • Enter the fax number, and then press Black or Color.
  • Press Speed Dial, and then:
- Use the arrow keys to scroll through the list to find the number you want, and then press Black or Color. - Use the keypad to enter a two-digit number (viewable in the upper left of the display), and then press Black or Color.
The All-In-One scans your document and sends your fax to the number you entered.
Using the All-In-One Center:
  1. Make sure your All-In-One is attached to a computer.
  3. From your desktop, double-click the Lexmark 4200 Series All-In-One Center icon. The All-In-One Main Page appears.
  4. Under Productivity Tools, click Fax an image or document.
  5. Follow the instructions on your screen to complete the task.
For a more comprehensive guide on how to send and receive faxes using your Lexmark X4270 printer, please refer to the Lexmark X4270 User's Guide.
Aug 17, 2011 | Lexmark X4270 All-In-One InkJet Printer
Can send faxes but not receiving them and yes there is paper in fax
Make sure the correct fax number is assigned on the printer. If you have an answering machine connected to the same line as your fax, configure it so that the answering machine picks up first then the fax. For more information, please refer to this article: Change Number of Rings on Inkjet AIO to Alleviate Issues with Answering Machines.
If you have a voicemail feature associated with the fax line, please disable the voicemail. Voicemail feature and the fax will not work together in the same line.
Jul 05, 2011 | Lexmark X4270 All-In-One InkJet Printer
I haVE ONE NEVER MADE A FAX CAN YOU GIVE ME THE STEPS ON HOW TO MAKE ONE QUICK MY DAD JUST PAST AND I NEED TO SEND FAX AND I DONT NO HOW MY DAD DID IT ALL THE TIME PLEASE HELP
How to fax: 1. Load your original document face down in the ADF. Adjust the paper guides to the edges of the paper. printtech_49.jpg
2. On the control panel, press Fax. 3. Use the keypad. Enter the fax number and then press Black or Color. The All-In-One scans your document and sends your fax to the number you entered.
For more information, you can also refer the the Lexmark X4200 Series User's Guide. I hope this information has been helpful. Thanks.
Jan 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
How to send fax from lexmark x4270. lost instructions
  1. Make sure your All-In-One is on.
  2. Load up to 30 sheets of your original document face down in the ADF. ascanld2.jpg
Note: When you load small paper sizes, place your original in the center of the tray and adjust the paper guides to the edges of the paper.
  1. On the control panel, press Fax.
  2. Use the keypad to:
  • Use the arrow keys to scroll through the list to find the number you want, and then press Black or Color.
  • Use the keypad to enter a two-digit number (viewable in the upper left of the display), and then press Black or Color.
Aug 29, 2009 | Lexmark X4270 All-In-One InkJet Printer
Brother Inteifax 775 will not send fax
change the mode from TAD to F/T by pressing mode button on panel
Thanks
May 19, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Fax problem
Pending faxes are faxes whose transmission has been delayed either deliberately or unintentionally. Normally, when a fax cannot be sent at the first attempt, the fax machine will redial the recipient's number. If you choose to delay sending a fax, the machine will send it at the time you select for transmission. During the delay period and at any point up to completion of the call, you can cancel the delayed transmission by deleting the fax from the Pending Faxes queue. To do this:
Press the Fax button on the operator panel and then press Options (once only). The Pending Faxes menu will be displayed.
Press Select. If a fax is pending, the printer will display Cancel Fax (the fax number you dialed appears below these words).
Press Select to delete the pending fax.
In response to the Are you sure? prompt, press 1 for Yes ( 2=No).
Press Options (once only). The Pending Faxes menu will now display None.
Feb 16, 2008 | Lexmark X4270 All-In-One InkJet Printer
Fax
i need simple instructions to operate the receiving and sending of fax information on this lexmark 4270 fax machine .
Jan 16, 2008 | Lexmark X4270 All-In-One InkJet Printer
X4270 lexmark printer hook up
I have a lexmark X4270, I'm having a problem with the fax machine, the display keeps displaying "clear paper Jam", however there is no paper jam. I'm also not being able to recieve or send any faxes. I'm low on ink, would this prevent sending faxes? Any suggestions?
Nov 06, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
46 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
