SOURCE: Error message
Hi toolpusher
Try going to CanoScan Toolbox > Settings and reset the 'defaults' button at bottom... this will restore factory settings and hopefully fix your problem... The other error message you can expect to get is "unable to scan - insufficent memory, check your **** space' (or something similar)... same fix works for both! ...Have had both messages on mine, sounds like a semi-regular conflict on some sort, but seems to be easily fixed. Good luck :-)
SOURCE: KOdak 2500 D -- cannot find target device
Go to Kodak's website and download the scan verification tool (the SVT), and see what it tells you. I use the 2500D with an Adaptec 2940 SCSI controller, and a 50-50 pin SCSI Cable. I use the twain driver from Kodak's website and paperport 9 software. This combination seems to work.
SOURCE: can not Scan to Panasonic KV-S3065C High Speed Scanner
Since you are using USB, you will also need the STI device driver: http://panasonic.net/pcc/support/scanner/download.html#DEV_DRIVER
