Philips 32PT71B1 TV sound problem
The sound cuts out and sometimes stays out for a long time.
Philips 32pt71b1 tv struck by lightning, i think, no power at all. How do I do it myself?
Posted on Jul 29, 2008
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
It might be due to speaker. if it is ok then check for 1 loose connection in sound section. 2 speaker wire loose. 3 any capacitor in sound section might be faulty. 4 check supply to sound section 5 loose connector in sound section. 6 sound ic might be defective. if not tech.person take help from tv tech. hope this will help. good luck.
Posted on Oct 02, 2007
SOURCE:
91 chevy cav z24 5 spd will not start @ times sounds like no fire other times sounds like no fuel.Replaced fuel pump,timing chain, crankshaft sensor,oil sensor,map sensor,body throttle accel sensor.st
Pull the air cleaner off and crank the engine. If puffs of air come come out of the throttle body when cranking the engine then the timing is not set correctly. Otherwise, after cranking pull a spark plug and see if it is wet with fuel and if so this indicates an ignition problem (coil, distributor/cap/rotor or faulty ECU).
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 02, 2014 | 1991 Chevrolet Cavalier
2002 Jeep liberty headlights cut off and then back on at random times. weather makes no difference nor hot or cold. went a way for a few months and now it has started all over again. hear clicking sound...
the clicking your hearing is the relay trying to stay engaged, its heating up causing the relay to power down, which in turn you lose the lights, the heat is caused by the electrical current supplied to the replay, Not the outside temp , locate that relay and replace it, and your problem should be gone
Aug 10, 2011 | 2002 Jeep Liberty
2000 LHS wont start at times and when it does security light stays on all the time and then car will cut out and shut down....tried new starter but that is not problem
it sounds like the anti theft system is turned on, car will start and die or sometimes not start, have the chip in your key checked it may be bad try a spare key. good luck.
Dec 13, 2009 | 2000 Chrysler LHS
5.1 Surround Sound Cutting Out
HI,
Yes you are right man, this problem occurs only with the cable problem, i can explain you, if there is a receiver problem means you won't get the sound its dam sure,
only if there is a cable problem you will get some noise or sound cut off with the speakers, so you please check the cables properly it will be alright.
Mar 26, 2009 | GE GTD120 System
CAR CUTS OFF, SOMETIMES WON'T START, TRIES BUT WON'T
Could be a fuel inj issue, but it could be other things too. Does the check engine light come on? Does it stay on? Reading the codes if they exist is a first step. Establishing correct fuel pressure is another first step but you need a fuel pressure gauge in order to perform this step. These tools are available at a local auto parts store. You should also invest in the correct repair manual for your car so you have the applicable troubleshooting methods available to follow.
Dec 08, 2008 | 1994 Pontiac Bonneville
No sound
Sounds like poor wiring connections. Also, if one speaker shorts out, ALL speakers will shut off, so make sure there aren't any loose wires behind the radio or at the speakers. Sometimes wires get pinched in the door jamb and create a short as well.
Sep 25, 2007 | Alpine CDE-9843 CD Player
Sound Cutting Out
If you looked for dry connections and found none, there is probably a componet that is intermittant, and these can be tough puppies to troubleshoot, without monitoring the power supply voltages and sittinfg with the unit.
Jan 04, 2007 | Philips LX3000D System
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
Ekse
