Renault laguna sports tourer 1.9 dci wont start
Try the relays under the bonnet fuse box 4 small black ones in a line, the first 2 from top cut of the fuel pump, and are a renowned cause of 85% of cranking without starting faults on the dci engine swap them over for the bottom 2 .
If it starts, buy 2 from Renault and fit
if the engine still fails to start the egr valve may be stuck closed starving the engine of air, its on the top of the engine at the air intake and has 3 bolts, remove it and clean it with carb cleaner then check its condition, if it appears ok, replace the cleaned one, if not you need a new one or the turbo will blow its seals and the engine will rev and burn on the engines own oil.
beyond this and your diy fixes are at an end without a obd2 code reader.
