Question about Canon PIXMA iP4200 InkJet Photo Printer
Canon PIxma i4200 - INK
Ink tanks full but lights blinking and won't let me print as it says no ink in tank. I refilled tanks myself. Help!!! All are full. I'm about to throw it out the window!!! Help!!
    President:
  • Canon Master
  • 2,022 Answers
See may be there is problem with the catridge bcoz it is not sensing the ink level it is bettre if you have other catridge first you check wit that or you try to remove the ink and claen the cartridge and refill it again. bye
Posted on Oct 01, 2007
SOURCE:
It told me that is low on ink. All the lights on
All the ones blinking could be low, you can look at them to see if there's ink, but if you haven't reset the chips on the inks they won't show inks as full, especially if you refill them. When you send a print job the printer window pops up to tell you which ones it thinks are low.
Jan 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
Pixma ip3600 not changing to 2nd black ink tank
you cant swap it for printing you have to refill the empty one
Feb 01, 2009 | Canon PIXMA iP1600 Printer
Error messages: U150 + Ink tank errors have occured
Reset Canon MP600 to the Factory Setting
  1. Press the HOME button.
  2. Use the Easy-Scroll Wheel or the right/left arrow to select Settings, and then press OK button.
  3. Use the Easy-Scroll Wheel or the right/left arrow to select Device settings, then press the OK button.
  4. Use the Easy-Scroll Wheel (B) or the up/down arrow to select Reset settings, then press the OK button.
  5. Use the Easy-Scroll wheel or the up/down arrow to select Yes on the confirmation screen and then press OK.
  6. Press the HOME button to return to the HOME menu.
Jul 12, 2008 | Canon PIXMA MP600 all-In-One InkJet...
IP 3300 refilling of ink tanks possible or not
Yes it is possible, Try injuctions to refill your cartidates.
Feb 22, 2008 | Office Equipment & Supplies
ON THE CHIPS, TRY CLEANING THEM WITH ALCOHOL (70%)
SOME BRANDS YOU CAN SHAKE THE CARTRDGES TO RESET THE INK COUNTER
Feb 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon pixma IP 1500
Seat the print head Below is the procedure for seating the print head and ink tanks:
  1. Open the printer's front cover.
  2. Raise the print head lock lever, and lower the print head lock lever firmly.
  3. Check if the ink tanks are installed properly.
    Ink tanks installed correctly
    Ink tanks installed incorrectly
  4. When installing the ink tanks, push the top of the ink tank until a click sound is made.
    Note: If the ink tanks are not installed properly, paper may not be fed properly, or ink may not be ejected.
  5. Close the front cover.
Dec 04, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
Refilling Ink in Canon Pixma MP830
Hello, I found this in a repair manual for the MP830. summery is to press and hold the stop/reset button for 5 or more seconds. I copied the info from the manual too. The remaining ink amount unknown. [1683] (Applicable ink tank icon) The remaining level of the following ink cannot be correctly detected. An ink tank which has once been empty is installed. Replace the applicable ink tank with a new one. Printing with a once-empty or refilled ink tank can damage the print head. If printing is continued without replacing the refilled ink tank, press the Stop/Reset button for 5 sec. or longer to record the use of a refilled ink tank. Note: After the above operation, the function to detect the remaining ink amount is disabled.
Jul 17, 2007 | Canon PIXMA MP780 All-In-One InkJet...
UNRECOGNIZABLE INK TANKS
Does this model have 'chips' on the tanks? Check for a reset option in the manual or trial and error by switching the machine off then on again whilst holdimg down one or more of the buttons For further help take a look at www.fixyourownprinter.com
Jul 13, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
158 people viewed this question
Clive
Clive
old marine
old marine
Ekse
