Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Lamp switches off
My Mitsu DLP was working fine and one day just went black (approx. 3 years old with light watching)and lamp light went on, so I replaced the lamp. It will ow turn on and the lamp light goes off, but after about 3-5 minutes, it switches off again and lamp indicator comes back on. Sometimes, it just goes from perfect picture to black. Others, the color distorts for a few seconds then goes black. Each time the lamp indicator lights, but it is new. The old lamp did the same thing. Any suggestions as to what problem might be? Thanks a ton...Todd
  • 42 Answers
The problem could lie in the heat sensor that sits just inside the lamp housing area inside your set. Apparently the technician fix is to clip the faulty connector Mitsubishi used when assembling the set and replace it with a soldered connection instead. My fix is simpler and does not require solder. My TV is a 57831 model so it may differ from others but not much if so. Here is what I did.
1.) Remove the two screws holding the lamp door to the set in the back lower right corner of your set.
2.) Follow the set instruction for removing the lamp assembly. it should be unplugged for an hour prior to doing this.
3.) Once assembly is removed, grab your flashlight (if necessary) and look inside the housing. You should see a white rectangular shaped piece attached to the outer frame edge of the opening. Looking straight on, it is located in the upper left corner of the square opening and is held in place by one small phillips head screw. This screw is inserted and installed from the opposite direction and will require the short screwdriver to remove. Carefully remove it and don't drop inside the set!
4.) To make room to move around and do what you'll need to do, you will also need to partially remove the back cover of the set. Mine was limited to just the lower half and was held in place by nearly 20 screws. You don't need to remove all of them but do need to be able to open up the rear enough to access the connecter that sits on top of the upper left edge of the lamp housing. If you follow the two yellow wires from the white sensor, they track back to a small black connector with two black wires on the other side of it.
5.) At this point, you have removed the screw to the sensor. Now you will need to pull the connector wires free from the routing clip on top to free up space for the wire to move freely. Once these two black wires are pulled from the clip, pull the white sensor down from it's position to free it from it's housing and allow the yellow wires to be pulled from the left side of the housing out. If done right, the sensor is free now and can be pulled carefully by the connector at top and out the back of the set.
6.) Squeeze the clip connection where necessary and pull the clip assembly apart. The sensor is now free of the TV entirely and you can work with it separately.
7.) Grab a nail file and work the connector pins a little to roughen the contact points a bit. This is similar to cleaning the contact posts on your car battery.
8.) Push the male end of the clip firmly into the female end until it clicks and then push a little harder to be sure good contact is made.
9.) Do the reverse as done above to put it all back together again and power up!
10.) The message should now be gone.
Posted on Nov 10, 2007
I have a 65 inch mitsu DLP, replaced the bulb 6 months ago.. Worked fine until this week.. Now the TV will power up, turn on, then show a picture for a second then go black.. It repeats this nonstop.. ...
Sounds like the Lamp is over temperature. Either the fan went out or the filter is clogged! You might check the filter first. I hope this will help you...
Jan 07, 2011 | Mitsubishi Televison & Video
My Samsung Dlp model hlt5075s was working great with great picture for last 2 years. This afternoon I went to cut it on and it the three lights on the bottom right started blinking(standby, time, and...
The projection lamp life is over.2 years has not been replace projection lamp,tv on daily watches like 4 or 5 hours a day?u need to replaced the projection lamp.
Sep 12, 2010 | Samsung HLT-5075S Television
My Mitsu 52525 lamp indicator went solid red. I
sounds like the caps on the power board have failed. You can get the V26 DM/Power repair kit from www.tvrepairworld.com which also contains the instructions.
May 12, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Thats usually caused by failed capacitors on the power board. The V26 power repair kit from www.tvrepairworld.com should repair that issue. The kit comes with the instructions on Cd.
Mar 20, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Samsung DLP turns on and off - cycle repeats
make sure put the lamp door back before trying to turn it on because they have switches on them that allow the tv to turn on. If that is ok you probably have a bad ballast.
Call a local tv repair shop to further diagnose the problem.
Dec 10, 2009 | Samsung DLP HL-P5663W 56" TV
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
Jun 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Newlamp went out in 20 days. lamp light blinks. is lamp dead now?
Biggest problem with DLP tv's is they get dirty (the usually have two or more fans...one in the back w/filter and one under the lamp). If air-flow is restricted the life of the lamp is in jeopardy. Verify air flow & clean filter(s). Replace lamp with exact P/N..not those that say they "are equivalent"...they are not. Also, be sure the lamp lens is very clean.
Apr 02, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Black screen with a Blinking lamp in the front
Hi..if your lamp is on but no picture, then your lamp is good. Your problem is the DMD board (digital mirror display board) is bad. This is very common with Samsung DLP.
Mar 27, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung dlp
HLS4266W 43" dlp. In less than 1 yr whining grew worse, but did know what it was. Year passed with warranty and lamp went out. Replaced lamp. Worked for 3.5 hrs. Turned on next day and did not work. Got another lamp, but did not work. Figured out might be color wheel. Replaced it too. TV started up. Watched that night. Turned on next day, heard loud pop. Lamp never came on. Withdrew and reinstalled lamp a couple times to see if that worked. Did not. Currently, with new lamp and color wheel installed, lamp light blinks, but no lamp comes on. What now?
Sep 17, 2007 | Samsung HLN5065W 50" Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
82 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
