My air runs inside the house but the fan outside is not turning...I shut everything off and turned it back on but out side i here 1 click then nothing...what is my problem??
Comments:
Oct 01, 2007
- this is central air unit.. my return is in the laundry room with the water heater, and the unit outside is the one not working...the air runs in the house but the fan doesnt work outside
Oct 01, 2007
- could the fuses outside be bad?
Oct 01, 2007
- arcoair....i am talking about the fuses in the diconnect outside
Oct 01, 2007
- what if there is no reset?
Oct 01, 2007
- and do i have to take any panels off....also are you talking about outside on that unit
-   I Have a msh 17dv with same problem, just purchased the house and don't know if im doing something wrong or if its broken. unit inside comes on then after a little while defrost and i feel monitor lights flash and don't stop but nothing happens with outside unit. It's really hot can anyone help?-   jorgo2
Nov 27, 2007
-   THE AIR WORKS FINE BUT NEVER GETS WARM EVEN TURNING CONTROLS TO HIGH HEAT. TOOK PANEL OFF AND SAYS HEATER HAS MANUAL RESET BUTTON BUT CAN NOT FIND ANYWHERE. THANKS-   PARKERSAM
Is this a central unit??? is it a split system?(Is their a unit outside(condensor) and a unit inside in the attic,under house, or in a closet??(air handler)
Comments:
Oct 01, 2007
- It sounds like the circuit breaker tripped or there is no line voltage to the condensor
Oct 01, 2007
- Since the late 70's they really dont put fuses in them anymore what brand is the unit outside??
Oct 01, 2007
- there actually are fuses??? I take it the circuit breaker isnt tripped also there may be aliitle red button somewhere near where the 2 copper tubes go in to the unit or around the control panel. So your unit is round right?? There may be no red restet button on some models. Only push it once though its designed to shut it down if the unit is overheating.
Oct 01, 2007
- Dont forget to rate my solution as solved if i answered your question accurately.....Thanks!!
Oct 01, 2007
- its an external reset outside the panels without removing the control panel and a volt meter you cant diagnose much further.
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a...
(More)
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a forced air system. Recommendations from heating contractors include Trane, SlantFin and Weil-McLain. Are these the best choices?
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at...
(More)
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at the lowest price. We stand by and guarantee the quality of our laptop battery.
<a href=http://www.bestlaptopbattery.co.uk/hp/dv1000.htm>Hp dv1000 battery</a>
Our Price: At Bestlaptopbattery.co.uk, you always pay the lowest price. We make this sure by offering our Best Price Guarantee on all our Hp dv1000 laptop battery.
Our Service: We have a dedicated team of customer service executives who are eager to help you save time and money by sharing their knowledge and expertise on batteries and related products.
Your Satisfaction: Your absolute satisfaction is our top objective. We stand by the quality of our battery and offer a 30-day money-back guarantee on all our products, no questions asked. Our products also carry a 12-month full repair or replacement warranty for any form of manufacturing defects.
How can you care Hp dv1000 laptop battery to get the maximum life out of it?
It is a question we frequently asked. It's a valid question since laptop batteries are usually expensive to replace.
First of all, how long should your battery last? 2-4 years is generally acceptable depending on how frequently you use and charge the battery. If you travel a lot and use and charge your battery frequently then you might only get a couple of years at the most out of your laptop battery.
The Hp dv1000 laptop battery are usually made with Li-Ion laptop batteries and the very nature of Li-Ion batteries is that they have about 500-600 charges and last at most about 4-5 years (shelf life). They also have a self-discharge rate of about 1% per day so you need to be sure to charge them at least every 6 months.
I have a Friedrich TwinTemp YL24J35C Air Conditioner/Heat Pump and need some replacement...
(More)
I have a Friedrich TwinTemp YL24J35C Air Conditioner/Heat Pump and need some replacement "latches" to hold the bottom of the Return air grille in place. My local heating/cooling dealer says they cannot get them. Any ideas? I need them badly. The unit looks horrible without the grille!
Works fine on cool; on heat it puts out hot air for a minute or two and then gets stuck in a...
(More)
Works fine on cool; on heat it puts out hot air for a minute or two and then gets stuck in a defrost(I guess) cycle with a strange noise from the evaporator/fan (inside) unit. It is a Rheem branded product I think the salesman said was made by Goodman when installed about 3-4 years ago.
