Question about HP Photosmart C6180 All-In-One InkJet Printer
HpC6180 I have wireless router and a all in one printer...internet guy came out and upgraded my internet radio....printer has not worked since.#$%^*&^%$#@.....i am NOT a computer guru....Help please
  • Rajil  Kapoor
    Rajil Kapoor Jul 29, 2008
    i have the same problem
    Brigadier General:
  • 6,966 Answers
Hi, Based on your post/description, I will assume that your printer is connected to your network by either by WiFi or Ethernet and not by USB to a particular PC. If it is USB connected to a PC, then it should still work since it is not physically connected to the router. Since your "Internet radio" was just recently upgraded, it is possible that the networking configurations have been changed. Having said that, it is perhaps required that you likewise changed the networking configuration of the C6180 to conform with the new settings. Pls post back with information on: 1. How is the C6180 connected; by LAN to your router or by WiFi? 2. What is your new/current networking configurations (IP add, Subnet Mask, Default Gateway, DNS, Network/Workgroup name)? 3. Do you still have the original CD installer/driver, the user's manual and the quick installation guide? 4. Do you still have the original USB cable that came with the printer? Alternately, you can checkout the installation guide at the HP website ( or go through the installation procedure again using the CD that came with the printer (of course you must initially uninstall the HP C6180). Hope this be of some help/idea. Pls post back with additional information/details so we can figure things out. Good luck and kind regards.
Posted on Oct 01, 2007
I have verizon broadband. their is no modem to conect to. Do I have to by a different router? Problem 2. The router and my wireless printer lost connection, i ran the router set up . the router list the...
First of all are you using verizon fiber connection than you don't need any modem, simply connect cable to router's internet port and configure it as pppoe and for you router page if it's not comming properly check which browser you are using if it's IE 8 there's lot of problem try to use firefox and check if it works but still same problem then need to upgrade the firmware of the router download from upgrade the firmware of the router reset it and reconfigure it for you internet and wireless settings..check and see if it works or not
Jul 22, 2010 | Linksys Wireless-N WRT150N Router
Hey guys could i use my router as a radio to pull the internet signal from a next router without using any cable
With the Linksys router it is not possible. You will need to connect the cable between the two routers. Linksys router will not pick up the wireless signal from the other wireless router.
May be it will work If you upgrade the DD-WRT Firmware. Not sure but it may. consult with the DD-WRT expert before upgrading the firmware.
Apr 22, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Plugging into the router i can get internet access, however when I cannot get wireless access for more than 20-30 minutes before it stops working and i have to power down and power up the router to gain...
Try to upgrade the firmware of the router. Firmware is the software of the router.
Download the latest firmware of the router. Go to the manufacturer's web site and download the firmware of the router.
Open the set up page of the router and upgrade the firmware of the router. Once you upgrade the firmware of the router, reset the router.
On the router you will find a small reset button, hold it down for 30 seconds. release it. wait for 1 minute. Now unplug the power to the router and plug it back in.
Now you will need to reconfigure the router according to the Internet service provider.
Apr 21, 2010 | Linksys Wireless-G WRT54G Router
No wireless on Time-Warner cable. LAN works fine
Yes, from what I understand you need a special router to go wireless with timewarner, just another way coporate America dicks the regular guy.
Dec 18, 2009 | D-Link DIR-615 Wireless Router
Wireless light not on, no wireless signat to computer
Try the following steps:-
1)Connect the computer using an ethernet cable and check the internet connectivity and then go into the router's setting's page and change the wi-fi setting's on the router by changing the channel and security and also enable the wireless router radio from the setting's itself.
2)If it did not work then Upgrade the firmware(drivers) on the router to the latest one available.
3)Even after upgrading the firmware the light status remains the same then restore the router to its default setting's i.e re-set the router and then re-configure it from the beginning.
Nov 27, 2009 | Computers & Internet
Laptop dissconnects offten and takes a while to connect
Great job. Now what you need to do is make sure you are running the latest firmware version.
Try upgrading it by downloading the latest from Belkin's support site for your model.
Nov 18, 2009 | Belkin F5D7230-4 Wireless Router
Green wireless led won't come on
Try upgrading the firmware of your router.
Nov 07, 2008 | NetGear DG834G Router
"The process mdns stopped unexpectedly..."
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Are these printers connected with a LAN cable directly to the router, or are they wirelessly connecting to the router?
HP C8180 has built in wireless adapter and Ethernet according the Website at HP.
If this is connecting to the network wirelessly, check to see that it is connected to the Network, is your router using secure passwords for a connection to the network,
Your printer will need these passwords just as your computers would
If you connect the printer with a Lan Cable, it will be more reliable, and shouldn’t need a password to be on the network. And makes life a little easier...
Your internet provider has nothing to do with your Printer not printing; this is an Internal Network Problem. The settings or your network has changed.
The Printer should have a static IP address
Here is a link to a tip I put together about this subject,
If you need any further assistance, feel free to contact me...
Oct 26, 2008 | HP Photosmart C6180 All-In-One InkJet...
Can't print using HP C6180 Printer via DG834G router
More information is needed to diagnose this issue:
- What form of wireless security setup do you have (WEP, WPA-PSK, etc)?
-have you gone through the steps (, Option B for the wireless setup) to be sure your printer matches these settings? Pay special attention to the section where it says to use the FIRST key in a multi-key WEP setup, and be sure the laptop is also using that key; WEP could be the issue if the laptop and printer are using different keys to connect.
-Did you give the printer a static IP address to request, or are you just letting it grab one dynamically?
-Have you tried installing the printer as wired rather than wireless, then printing from the laptop wirelessly?
Nov 09, 2007 | NetGear DG834G 802.11G Wireless ADSL...
HP Photosmart C6180 All-In-One InkJet Printer Logo
379 people viewed this question
Ben Johnson
