Question about Panasonic CT-36HL43 36" TV
Panasonic CT-35HL43 36" TV has NO power
I have no power, no front power light, nothing. The set worked fine on Friday afternoon and when returning home Sunday...zip. Nothing I can do resolves the issue. I tested the power supply and all is go. Any ideas?
  • 5 more comments
  • Anonymous Jan 29, 2008
    I have the same problem with the CT-36SL13. Turned it off went to work, came home pressed power nothing ! Its only four years old and i need a damn crane to take it to a shop .
  • sagesteve Feb 28, 2008
    Same problem! CT-36SL13. 5 1/2 years old. Turned off last night, this morning NOTHING! WHERE is the fuse located? I took off the back but could not find it.
  • Allgonquin Mar 15, 2008
    Same problem, same set CT36SL13. Went to turn it on today, will not power up. Working fine up to today. Unplugged for an hour, no change.
  • Maxli Mar 21, 2008
    1. Push the power button, hear some sound (from relays?), the light is on, hear some sound again, the power is off.
    2. Push the power button, no response.
    3. Pull the power cord off, put it back.
    4. Repeat step 1.
    Checked the fuse inside the TV. It is ok.
    Please help. Thanks
  • Anonymous Mar 29, 2008
    Exact same problem. Worked great then not at all.
    Someone mentioned replacing the fuse? Where is this located an can it be done by a non-tech?
    Thanks.
  • Anonymous Apr 29, 2008
    I came home today and found that My TV would not power on. I checked the power line and it was fine. The set would no power on with the remote or when the power button is pressed. Is there a possible solution?
    James.
  • burnzieboi4 Jun 24, 2008
    tv switches off after a while when the signal seems to be interfered with.
It could be the ac fuse gma 6.3 amp my ct-36hl43 did the same thing cost a dollar for the part 99 dollars laborer [email protected]
Posted on Feb 25, 2008
  • 3 Answers
I bought the fuse at Radio Shack for 5 dollars and replaced the fuse myself. The set now works fine. It cost me more in the gas to go and get the fuse than the entire repair cost. There are screws on the back of the tv that you will need to remove. Once you remove the screws you will need to PARTIALLY remove the back cover. It was not necessary to remove the entire back cover. If you look into the back where the power enters the television you will see the fuse. It is small, so look carefully. MAKE SURE THAT YOUR TELEVISION IS UNPLUGGED! I repeat. MAKE SURE THAT YOUR TELEVISION IS UNPLUGGED! Pull the old fuse and replace it with the new. Cost me about $10 total.
Posted on Jul 29, 2008
Same problem. I have the CT-32HXC14. I agree, you need a crane to move this thing!
Posted on Apr 24, 2008
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
As set is dead & you have checked power supply then check for hor. section.
Posted on Oct 01, 2007
SOURCE:
My Panasonic CT-27SC14 tv won't turn on. worked fine last night. The cable box does but nothing happens with the tv..whether I use the remote or the power button. Unplugged it from the power source and...
hi,disconated from AC main. if you know bit of repairing tv and soldering? this what to look for main power board. 1 x dry joints 2 x leaky capacitors just remember when changing cap's make sure to use the 105' and same value.
Feb 04, 2010 | Panasonic CT-27SC14 27" TV
32'' Panasonic television. Power switch does not turn the set on.
1 It appears that connecting cable is faulty. Normally when you connect and push the power switch the standby light should lit. Try the cable on another appliance and see its function. Also switch on the TV and try to switch it on with your remote control.
Nov 19, 2009 | Televison & Video
My Panasonic HDTV will not turn on
Mine did the same thing. Did you find out what to do?
Oct 11, 2009 | Panasonic CT-26WX15 26" TV
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
Something is shutting down the power supply, most likely from over current
Feb 13, 2018 | Panasonic TX-28CK1 28" TV
No Power on Panasonic 36HX42
The TV cannot sustain power - well the good news is, it is on the POWER SUPPLY section inside the TV
Jun 18, 2008 | Panasonic CT-36HL43 36" TV
Tv wont turn on
stephster, check to see if you have a reset button on the back of tv good luck-hope this works for you
Nov 05, 2007 | Panasonic CT-36HL43 36" TV
Panasonic TX14S2T
What are the symptoms? Is the set dead? Please clarify
model number from back of set...The red power light coming on means the AC fuse is OK, but the B+ fuse may be bad. If that
is true,check the horiz o/p xistor and get back to me....T.
Oct 20, 2007 | Panasonic CT-27G14 27" TV
Panasonic CT-36HL43 36" TV Logo
218 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
