Question about Filter Queen Majestic Canister Vacuum
Switch replacement reassembly
I replaced the foot switch and need instruction on how the metal foot piece assembles with the little spring. Thanks, skosh
  • rayhill44 Mar 10, 2009
    Filter Queen vacuum cleaner was disassembled and forgot how to reconnect high low switch to motor wires; Old brown model 88 578F; can you advise?
    President:
  • 1,673 Answers
Maybe this picture will help:
Posted on Mar 13, 2008
SOURCE:
I need a you tube showing me how to replace the handle release. when I pick up the vacuum by the handle the vacuum head flops down
If you remove three screws you can remove the assembly with the foot pedal. Look at how it is installed closely in the assembly, including the spring, shaft and pedal. Disassemble it and install a new foot pedal exactly the same way you took it apart.
Feb 15, 2016 | Riccar 8000, 8900 Series Metal Agitator...
Does anyone have "duct" assembly instructions for Dyson DC 24? (Not the owners assembly manual)
Google Dyson. co On the drop down window, find your model, type in Dyson DC 24, at bottom of page click on shopping info, click parts. you can order from there.
Oct 19, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
How do I fix the foot pedal assembly for the handle release on shark vacuums?
You should call cust service. Call may still replace it.
Aug 04, 2014 | Shark Vacuums
Switch Assembly
one spring larger goes on the red on /off small spring goes on the little white piece
Apr 05, 2014 | Dyson DC40 Multi-floor Vacuum DC40
How do i replace the on off switch on Hoover U6485900
Make sure the power cord is disconnected! There are two sets of three screws one needs to remove. The first set hold the handle assembly to the sweeper body (there are two near the back of assembly and one in front). The second set is inside the cavity that hold the vacuum powered cleaning tool. There are two at the bottom of the cavity and one at the top. Refer to the Assembly Instructions in the Owner's Manual for help. One can then remove the power leads from the on/off switch, push the switch out, and insert a replacement switch. Pay attention to the color of the wires because some switches apparently work with models having 2 black wires (H-28161075), others with a black and yellow wire (H-28161074), and others with connectors to the wires. Reassemble the sweeper reversing the dis-assembly process outlined above.
Jan 02, 2014 | Hoover U6485900 Bagged Upright Vacuum
S5602 shut off
The switch is probably broken. try a flat screw driver up under the foot switch and see if the little button is missing. If the foot switch is not making a click sound when pushing on it the switch is broken. I have found on some of the vacuums I've worked on the on/off switch is not broke. There is a little button about the size of a candy cig and 1/4 " tall and there is usually a rubber spacer with a spring that holds it up off the switch. If one or both pieces are missing that's your problem.
Dec 19, 2013 | Vacuums
Electrolux 2100 foot switch
The owners manual is HERE: http://www.aerusonline.com/service/manuals.cfm
But it does not show the inside of the foot/power switch
Mar 03, 2009 | Vacuums
Replace power switch - Electrolux Epic series 6500
well, i post an answer in the wrong field, and i can't find it, so i will type one more time.
slide two vinyl side pieces off, and remove top halves. remove two screws from the switch, and remove it from top halve. between switch and outside button is a plastic rocker, which is broken. you will find two broken pieces, one spring for the rocker piece, and one small plastic rod, which goes inside of the spring for support. i do not know if part is available, but you can for quick fix like me, turn the switch on by the hand, assemble unit, and plug in, and plug out from the wall. whay? i dont have electrolux store close by.
john
Feb 21, 2009 | Electrolux Epic 6500 Vacuum
In need of a picture of the on/off switch for Dyson DC17.
This is over a year too late, but perhaps this will help other people in your situation. Here is how the switch assembly should go together:
Feb 01, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Filter Queen Majestic Canister Vacuum Logo
167 people viewed this question
Top Filter Queen Vacuums Experts
CJ C
CJ C
Marvin
Marvin
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
