Question about Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX_FL 520 Fax problem
The fax machines copies perfectly and receives faxes as well, but it does not allow us to send faxes. Every time I have tried, it says "check document". Not even using the fuction "Quick Scan". I have already clean the fax everywhere with an kind of air spray. Thanks for your help.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 171 Answers
THE DOCUMENT SENSOR OR THE DOCUMENT END SENSOR ARE EITHER BAD OR THE SENSOR LEVER IS STUCK OR BROKEN CHECK THESE AND YR PROBLEM WILL BE RESOLVED HAPPY FAXING OMNIPRESENT
Posted on Oct 02, 2007
SOURCE:
Received faxes, cartridge has run out how can I print or send to PC
some new fax machines has, fax memory older models dont, so if your fax machine is old. the fax has been lost, because when printing is one time (dont preserve on fax memory, only the comunication numbers. try talk to your fax senders send again a fax copy,
Jan 14, 2010 | Office Equipment & Supplies
Every time I fax or copy a perfect sheet of paper both the fax received and the copy have a 2 inch wide solid black line on the right. How do I fix the machine?
Have you tried replacing the ribbon cartridge? If that doesn't resolve the problem, then there is a fault with the thermal imaging head. You did say both Recieved faxes and copies, correct? If faxes you send out are clear, then the above mentioned would be correct. Let me know, please.
Oct 12, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
I can send fax out and they arrive perfectly, but it wont allow me to receive any faxes coming in.
If it rings and dosen't answer turn on auto answer. If it dosen't ring check to see if bthe fax is connected to the proper phone line. DickyO
Jun 11, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
Jun 05, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
Do not know how to send a fax
Check the send/receive settings. A lot of times, these all-in-one machines have auto answer settngs so that the fax machine does not answer every phone call with a fax signal. Go into the menu and see if you have auto answer off or on, and then also check to make sure if you need an answer code to answer the fax when auto answer is not on.
Mar 17, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I have the stupidest question. i have a brother fax 560 plain paper fax. Do i load paper face up or down to send a fax? THank you!
just check there wilkl bi mention face up or down .if not mention no problem just make a copy by putting face up and one copy by putting it face down.one time u will receive white copy and one time u will receive print on paper .when u will receive print check this is face up or down .after confirm just send fax
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Able to receive fax but cant send
sleep mode is just a status of the machine when it is in idle mode.you cannot turn this off however you can delay the time before the unit goes into a sleep mode.it has nothing to do when you are sending out faxes.so here are a few things you need to check when sending a fax (1)dial tone by pressing hook/hold button (2) insert the doc into the adf, make sure it will change to "enter fax # and start,or copy press copy (3) dial the number (4) wait for fax tones of the receiving unit before you press start. now if you can hear an operator on the line,that has to be verified with your phone company since brother machine does not restrict incoming and outgoing faxes UNLESS that is restricted from your phone line.
Nov 18, 2008 | Brother IntelliFax-2820 Laser Fax
Receivers complain that the fax is light/unreadable
More than likely (since the problem is with sending and copying only) the mirrors inside the fax machine need cleaning. However, depending on what type of fax machine this is, this could be a pretty involved job. If you are pretty comfortable with taking covers off, you might try it, but if its a pretty expensive fax machine, I would call a professional.
hope this helps!!!
chad
Oct 08, 2008 | Sharp UX 510 Plain Paper Thermal transfer...
Poor Quality
If you can copy ok you have effectively ruled out your machine as you have used both the scanning and printing mechanism of the machine.
It will probably be the fax on the other end as if it sends a poor quality page that's all your machine can receive, a poor line can also cause problems if it is from multiple faxes. If so have your provider check the line (you probably hear static on the line).
Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
Print Size Changes
This maybe down to the other persons fax machine if your copy is coming out perfect try sending it to a different fax number to see what happens.
If the same thing happens press the menu key and you are looking for a heading call setup or machine settings within one of those will be TTI settings and make sure that reduction send is not on.
Hope this helps sorry a little vague but have manual at work
Thanks J
Nov 22, 2007 | Brother IntelliFAX 560 Plain Paper Fax
Panasonic KX-FL511 Plain Paper Laser Fax Logo
187 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
